Old 09-27-2020, 10:39 AM   #155
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Checkout any of the diecast forums. There is a ton of info out there.
A quick search revealed this one:
https://www.diecastxchange.com/forum...rt-ae86-again/
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
Kaotic Lazagna (09-27-2020), shiumai (09-27-2020)
Old 09-27-2020, 12:38 PM   #156
StraightOuttaCanadaEh
Wes
Originally Posted by Kaotic Lazagna View Post
I know it's not plastic, but has anyone ever repainted a diecast model? Specifically AutoArt ones that are NIB?
Yes. Check my instagram, @Stratoswrc_jdm
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 09-27-2020, 02:40 PM   #157
soundman98
ProCrastinationConsultant
soundman98's Avatar
from past experience trying to do what you want to do, practicing is highly recommended. the paints got to be a little thinner, and masking is even more critical at the level of detail required.
Old 09-27-2020, 02:51 PM   #158
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
...and don't use regular home depot masking/painters tape - it will bleed. Get the Tamiya yellow masking tape.
shiumai is offline   Reply With Quote
The Following 3 Users Say Thank You to shiumai For This Useful Post:
Kaotic Lazagna (09-27-2020), soundman98 (09-27-2020), Tcoat (09-27-2020)
Old 09-27-2020, 04:44 PM   #159
Wes
Here are some pics.
First use any paint stripper you can find at your local hardware store. You can use a metal bristle brush by hand or use a similar dremel attachment to get the few stubborn flakes of paint off. Then scuff with sandpaper to create a good binding surface for the primer.
Scuff the primer, making sure not to go through it. Then it's time for base coat. This particular one was painted with Tamiya TS spray cans. Multiple mist coats over a course of 10 mins or so, until the desired depth was reached.
Then clear. I used 2K automotive clear from splash-paints.com
It's even safe to use over decals. Can't say the same for Tamiya clear
Instagram: @gt86ws
Old 09-27-2020, 04:47 PM   #160
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by shiumai View Post
I have not had a good experience with Duplicolor for models. The issue I had with metallic colors was that the metal flake in Duplicolor wasn't to 'scale'. It would look fine on a real car, but on a model it didn't look right - the flakes were too large. Solid colors should be fine, but I just stick to Tamiya or Testors for models.
Lots of great videos on YT about painting model cars.
Tamyia makes a whole line of Model auto paints with metal flake that is almost to scale. They are lacquer so a bit harder to work with but they have most of the Subaru and Toyota colours.
Tamiya it is. The color looks very similar to the Nissan color. It's a mica/pearl paint. I've watched a few videos, and everyone always strips the paint, so that's what led me to my original question here. haha. I also don't have one of those mini sprayers, so everything will be done by can.
Old 09-27-2020, 04:58 PM   #161
Kaotic Lazagna
Drives: GR Corolla
Excellent work!
Now that you mentioned decals, I might have to reconsider this project since I don't have a way to obtain new decals. I think I read that AutoArt uses some different kind of decal??? I'd end up painting over all the emblems.
And in the end, I might end up spending more than I want to. Maybe I should just be content with one of the colors that's available on the AutoArt. I did order a 1:43 Ignition model in the color I wanted, but then was later contacted and refunded by the store saying their inventory count was wrong and they actually didn't have it in stock.
Old 09-27-2020, 05:23 PM   #162
Wes
Excellent work!
What model are you interested in anyway? And yeah they don't use decals, they use what's called tampo printing which is more expensive and better than decals (unless the decals are clear coated). Just keep in mind that some of their latest models are plastic, in which case no need to strip. Just sand like Tcoat mentioned
Instagram: @gt86ws
Old 09-27-2020, 05:32 PM   #163
Kaotic Lazagna
Drives: GR Corolla
You actually have one of them from what I saw in your IG. The R32 GT-R "Tuned" version. I was gonna get the matte black one since that seems to be the least expensive out of all the colors, and figured if I did do the sanding down method only, it would serve as a good "base" for the mica red. I contacted AutoArt and asked if they have plans to produce it in mica red, and was told no. haha
But then I never factored the hot glue gun and respirator masks at the very least of additional items I would have to buy to repaint. Hot glue gun since I know some of the plastic pieces will have to be broken off, and that respirator for 2k clear. I'd also have to get various grits of sand paper and blocks since I read diecast models have super thick layers of paint (I've ran out of sand paper).
Old 09-27-2020, 05:41 PM   #164
Kaotic Lazagna
Drives: GR Corolla
After my Ignition order was cancelled, I thought about picking up a 1:24 Tamiya Nismo "custom" kit, and some how retrofitting BBS LM wheels on it. But I'd have to buy various paint brushes and paints (I threw out my kit long, long ago), and anything else required. So I assumed in the end, it's going to cost me over $150. I might return to this idea vs possibly messing up an AutoArt model. Just crazy how the BBS LM wheels cost as much, if not more than the actual car model.
Old 09-27-2020, 06:13 PM   #165
Excellent work!
Take a look online. You may be able to find the decals you want. There aren't many subjects they don't make them for.
Old 09-27-2020, 06:15 PM   #166
DON'T try to paint red over black! Get white or as said strip and use a white primer. Red over black would take many many coats.
Old 09-27-2020, 07:17 PM   #167
Kaotic Lazagna
Drives: GR Corolla
If I were to do it on an AutoArt, I kind of wanted to stick with the decal type they used since it looks more realistic than normal decals.
Ah, and here I thought black would have been a good base. I think I'll probably just stick to my Tamiya idea. Sounds like less of a headache and chance of messing things up.
Old 09-27-2020, 08:05 PM   #168
soundman98
soundman98's Avatar
in the past, i've met a few guy's in passing in hobby shops that do this sort of thing as a side business/hobby. i believe most of them are on scale modeling forums. if it's too big a job for you to do, you could consider checking some scale model forums for what some of those guys might charge to do it for you to a level that i know i couldn't achieve.
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
