Old 09-26-2020, 07:44 PM   #603
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by serialk11r View Post
It actually never occurred to me to go look at them in person LOL. I tend to think about stuff theoretically at home. If a 1x prism is truly non-magnified, it should behave exactly like a red dot with an equal size window, since the light rays should have unaltered direction, and your eye has to be directly behind the lens to see the reticle in both cases. I wouldn't be surprised if in practice, the image deteriorates as you move your head away from a scope.
The obvious theoretical advantage I can think of for red dots is that you can find bigger ones (giving a bigger eye box) easily, while I can't find a 1x scope bigger than 30mm diameter.
Red dots you don't need to be directly behind. You can be off center. The cheaper dots will experience something called parallax. I've seen as bad as like 12 MOA shift with the lesser quality stuff. EOTech has pretty much zero parallax, and Aimpoint is very close as well; which are big advantages when having to shoot in any position other than perfectly upright and static.
So long as your dot is covering the target, you'll hit the target. Regardless of where the reticle is in the optic window (assuming your mechanics/fundamentals are good).
If it's a TRUE 1x PRISM scope, then the eye relief won't be an issue like LPVOs and magnified optics. Like you mentioned above.
My Aimpoint T2 is a micro red dot. 25mm window. At first, I wasn't sure I liked it that much.
I always liked the EOTech for the larger window and the reticle, with the 68MOA circle and 1MOA dot in the center. It always felt faster and allowed me to have better situational awareness of my surroundings while shooting. The only downside was really the weight. Like 10oz for the EXPS compared to like 3oz for the T2.
After shooting the T2 quite a bit, I've grown to really like it. Especially after going to a 1.93 height mount. I still prefer the EOTech overall, but I've gotten to be much quicker and more comfortable with the T2. So much so that I actually prefer it now compared to the EXPS in some instances/scenarios.
If EOTech could find a way to cut a couple oz of weight from the EXPS, like down to 6oz or something, and then improve the battery life, it would be an instant winner. Aimpoint T2 has 5yr battery life compared to like 25 days with the Eotech.
Old 09-26-2020, 10:30 PM   #604
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Fiber optic + tritium = no batteries and operates day or night...
Had an Eotech that I did like, but yeah they kind of go through batteries fast. The M21 is always on day or night for at over a decade and has about as nice a reticle (better clarity/definition but just a tad less quicker acquisition.) It does weigh a little bit more.... but again, always on and ready to go along with just as rugged construction as an Eotech.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 09-26-2020, 11:01 PM   #605
soundman98
ProCrastinationConsultant
soundman98's Avatar
Too bad tritium only has about a 10 year lifespan
WildCard600 (09-26-2020)
Old 09-26-2020, 11:24 PM   #606
WildCard600
WildCard600's Avatar
Drives: 2020 86
Yep. Had a tritium sight go kaput a few years back. Got dimmer and dimmer as the years went on. Made it absolutely useless at night. Into the trash it went.
WildCard600 is offline   Reply With Quote
Old 09-27-2020, 02:16 AM   #607
serialk11r
Drives: '06 AM V8V Coupe
If I'm not mistaken, the simple dot reticles are power efficient since it just focuses the light from the LED into one point which is easily visible, while the other patterns use a mask that wastes a lot of light output.
Theoretically, it should be possible to arrange some small laser diodes in the shape of the reticle for higher efficiency, but I imagine it would cost a fortune.
IMO a "shake to wake" feature with a larger battery is not a bad solution if you want it ready to go without any buttons to press. An AAA sized battery should be able to go a few thousand hours. Solar charging would be icing on the cake.
The Following User Says Thank You to serialk11r For This Useful Post:
soundman98 (09-27-2020)
Old 09-27-2020, 10:43 AM   #608
TylerLieberman
Drives: '24 GR86
Yeah the shake awake feature is one reason why a lot of people really like the holosun stuff
Old 09-27-2020, 11:39 AM   #609
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
AR15 and a pistol. Done.
Yup!
shiumai is offline   Reply With Quote
The Following 3 Users Say Thank You to shiumai For This Useful Post:
NoHaveMSG (09-27-2020), soundman98 (09-27-2020), TylerLieberman (09-27-2020)
Old 09-27-2020, 11:50 AM   #610
TylerLieberman
Drives: '24 GR86
Originally Posted by shiumai View Post
Yup!
Good stuff there. Those ADAC Ambi lowers are cool.
Which IR illum is that? It looks a lot like a DBAL, but slightly different on the top
Old 09-27-2020, 12:42 PM   #611
shiumai
shiumai's Avatar
Thanks - it's an original (pre-Steiner) DBAL A2. It might have been updated since then.
Old 09-27-2020, 12:53 PM   #612
TylerLieberman
Drives: '24 GR86
Nice. The shrouds surrounding the dials on top are a bit different, but that seems to be it.
Have you tried a PEQ/ATPIAL-C in comparison? I haven’t used a DBAL but have a lot of experience with PEQs.
Old 09-27-2020, 12:55 PM   #613
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I love AKs. Fun, simple, accurate, and inexpensive Russian ammo.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
IceFyre13th (09-27-2020), NoHaveMSG (09-27-2020), soundman98 (09-27-2020), Spuds (09-28-2020)
Old 09-27-2020, 01:20 PM   #614
shiumai
shiumai's Avatar
I haven't used a PEQ/ATPIAL-C. It looks like the MAWL is the one to get nowadays, but that's $$$. The DBAL works very well with the Surefire SR07-D-IT dual switch to activate it, and the vis Scout light.
Old 09-27-2020, 02:35 PM   #615
soundman98
soundman98's Avatar
i've got a few tritium-lit watch faces, and a keychain--because watches and keychains are cheaper than guns . bought all of it around 8-10 years ago. they are all noticeably dimmer than when i first bought them. as cool as they are, i couldn't imagine using them for anything more than the novelty capacity that i use them in.
to use them in an expensive optics system that needs to be replaced every 10-ish years just seems like a waste of money.
WildCard600 (09-27-2020)
Old 09-27-2020, 02:35 PM   #616
TylerLieberman
Drives: '24 GR86
Yeah the MAWL definitely seems to be the one to beat. DBAL has me curious just because of the cost. ATPIALs have surged in price by a few hundred in the last couple months. They’re like $1,600 now which is pretty wild. Another $1,000 gets you a MAWL, so the question is to just bite the bullet and spend the extra on a MAWL? Or realize the ATPIAL is probably more than good enough and just stick with that?
Or buy a DBAL for less than both? Lol
No Politics or Religion discussions please Hachiroku Off-Topic Lounge [WARNING: NO POLITICS] 1 01-07-2021 12:50 PM
Product Showcase - Auto Finesse Tripple - All In One DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 11-16-2012 04:28 PM
Product Showcase: Menzerna Fast Gloss 400 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-16-2012 09:14 AM
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
Are politics off limits? Longhorn248 Site Announcements / Questions / Issues 35 05-16-2012 10:24 PM
