Old 09-10-2020, 12:26 PM   #15
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Originally Posted by Tristor View Post
No, it does not require a spacer to clear. I do have a spacer though in those photos in order to have the exact same (to the mm) track width on my car when I change wheels or change camber settings. I run spacers with all of my wheels for this reason, but I can verify that a spacer is not necessary to clear the calipers... the APEX BRZ wheels clear most aftermarket brakes for this platform without any issues as they are.
That’s good to hear. Thanks for the update. I tried a paper template and found at least the wheel does not clear the GT caliper. I have a hard time to find the correct template file for the BM4, so I purchased AP racing endurance kit instead.
zeroomega is offline   Reply With Quote
Old 09-24-2020, 01:43 PM   #16
Tristor
Tristor's Avatar
I don't bother using the templates, there are enough people running common track wheels with all the available BBKs you can find the answer online. In fact I gave you the answer previously. That said, the AP Racing Endurance kit is also a good choice, although I think their rotor design is very much focused no track use only and isn't as friendly on the street.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
CSG Mike (09-25-2020)
Old 09-25-2020, 04:50 PM   #17
CSG Mike
CSG Mike's Avatar
I'm fairly certain you were sent the BM4 template.
Any wheel that clears the AP Endurance kit will also also clear the BM4.
Old 09-25-2020, 05:23 PM   #18
zeroomega
zeroomega's Avatar
I printed the template you sent me but it has the same spec of the GT4 caliper where I can find online. And yes the template you sent me does not fit my wheels. I also printed the template from endurance kit and it fits fine.
Old 06-15-2021, 06:08 PM   #19
tonyfenng
Drives: Toronto
Just wondering, what is size of pistons in BM-4?
tonyfenng is offline   Reply With Quote
Old 06-17-2021, 11:45 PM   #20
FunnyGopher
Drives: 2015 BRZ Limited
Does this include the 17x9 +35 RPF1s?! :O
I've seen these on the CSG site, and I've been interested, but the AP Endurance kit has basically been the only kit that fits under that wheel, even if it's super close. I'll eventually get the itch to find the template and actually go figure out if it'll fit, but your words are encouraging.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 12-26-2021, 12:36 AM   #21
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Why do you think so?
According to their template, the caliper only sticks out 25.9 mm from the face of the rotor hat.
Pretty sure this is significantly less than that of the B-M4 caliper?
That means that certain wheels with spokes running closer to the face of the rotor will hit B-M4, but clear the AP Racing CP8350 caliper in their "Competition Endurance" kit.
Old 12-26-2021, 01:53 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Apologies, this was the wrong link (to the 300mm rotor).
Here's the link to the 325mm rotor:
https://www.essexparts.com/storage/w...l_template.pdf
Even in this kit, the caliper only sticks out 26.0 mm from the face of the rotor hat.
Old 01-05-2022, 06:59 PM   #23
868686frs
Drives: 2013 FRS
hi, I am also checcking this BBK for my 2013 FRS. However I am trying to find b rake pads size information about this BBK seems nowhere to find? does anyone have this information? it will be on a 326x30mm rotor. thank  you
868686frs is offline   Reply With Quote
Old 01-08-2022, 05:13 PM   #24
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
@CSG Mike: How does the BM4 performance (Thermal capacity, rotor and pad life) compare to the OEM PP's (assuming the same pad mat'l?
Originally Posted by CounterSpace Garage View Post
Thermal capacity is a function of mass. 1pc discs are physically simple compared to a 2pc system (disc, hardware, bell). Because of additional parts, you can expect a cost difference. 2pc Brembo GT kit is about $1500 more than a 1pc Brembo GT kit.
Discs can vary in quality based on the metallurgy and manufacturing processes. While the base materials are the same elements, the quality control of the material is different. As a result, different manufacturers have different characteristics inherent in their discs. Based on the origin of the disc, you can almost spot where the discs are manufactured. Is that a bad quality to have? Not necessarily. If price point is what people are looking for as their number one criteria, then parts need to be manufactured in specific locations to bring the price point down. If quality is what you're looking for, you'll find that the engineering involved and the metallurgical characteristics will be superior.
Consistency is what drives the cost up and what people pay for. You'll find that the factory OEM system is quite capable and people tend to throw in much lower quality products at it hoping it will provide benefit. The friction material is one of the most important aspects in brake performance. Adding that component to a high quality kit will further maximize the potential of the brake system.
We have tested a majority of brake systems and compounds available in the market. If you have any questions on brake systems and goals to improve brake performance, you may contact us via PM or e-mail.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 01-08-2022, 08:24 PM   #25
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Does anyone have a photo of the back of the caliper / brake line when installed on the car?
Old 01-08-2022, 09:58 PM   #26
CSG Mike
CSG Mike's Avatar
Thermals are similar. The BM4 has a significantly stiffer caliper, which leads to better pedal feel and a much higher resistance to radial taper wear.
The best illustration is how much larger the BM4 is compared to the OEM PP, while using the same dimension rotor and pad shape.
The BM4 can also use thicker pads than OEM.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Pat (01-09-2022), timurrrr (01-08-2022), treedodger (01-09-2022)
Old 01-30-2022, 07:15 PM   #27
callisto
Drives: 2019 Subaru BRZ
Can the BM4 calipers be swapped in on Performance Brakes by a mechanic/tuner, or is it necessary (or at least a very good idea) to just buy the full brake kit?
callisto is offline   Reply With Quote
Old 02-07-2022, 05:51 PM   #28
CSG Mike
CSG Mike's Avatar
No, you need the full kit.
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
WTB: Rear Brembo STI caliper. grostoine Want-To-Buy Requests 2 07-16-2014 05:26 PM
STI Brembo caliper mounting bolts... SkAsphalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-13-2014 07:24 PM
The price of one Brembo Caliper. chuttney1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-18-2013 04:32 PM
