Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-22-2020, 02:49 PM | #1 |
Drives: 2018 Premium Black silica BRZ
How to line up banjo bolt with spiegler.
Hey how is everyone doing! I was really hoping to get some help on how to line up the banjo bolt properly to my Spiegler in order to reinstall my brake calipers.
I keep trying to tighten it but it’s fails to line up with the spiegler. Sent from my iPhone using Tapatalk |
09-22-2020, 03:25 PM | #2 |
Drives: 22 BRZ limited
Do you mean you're having issues lining up the brake hose? I haven't looked at the hoses for this car, but isn't there an alignment pin on the hose end that fits into a slot on the caliper?
09-22-2020, 03:27 PM | #3 |
09-22-2020, 04:45 PM | #4 | |
The Dictater
Drives: '13 Red Scion FRS
09-22-2020, 04:50 PM | #5 |
09-22-2020, 05:00 PM | #6 |
The banjo head is designed so the fluid moves around the bolt, meaning bolt position is not of consequence.
The Following 4 Users Say Thank You to ls1ac For This Useful Post: |
09-22-2020, 05:37 PM | #7 |
ProCrastinationConsultant
the trick is to never tell the fluid!
The Following User Says Thank You to soundman98 For This Useful Post: | pher.da.rico (09-22-2020) |
09-22-2020, 09:46 PM | #8 |
Sorry I didn't make it back sooner, but it looks like everyone covered it. It doesn't need to be lined up. The fluid doesn't care.
The Following User Says Thank You to dragoontwo For This Useful Post: | pher.da.rico (09-22-2020) |
Similar Threads | ||||
Help! Brake line leakage after steel braided line install. | ysu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 02-09-2020 10:38 PM |
Spiegler brake lines (front and rear) | peaches | Brakes, Suspension, Chassis | 2 | 08-06-2019 08:53 AM |
Rotrex C38 Compressor Banjo Bolts | itsbenlol | Forced Induction | 2 | 09-04-2018 11:23 PM |
Rear brake caliper banjo bolt size? | ChrisD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-22-2016 06:51 PM |
FS: Spiegler SS lines front and rear | ayau | Brakes, Suspension, Chassis | 2 | 12-29-2013 02:33 AM |
