#43 |
Drives: hyper blue
a few peeps toss their junk in bad weather ie rain or wet roads. all season or summer, wet grip characteristics should play into your choice. (22% of all accidents are due to weather) silica based compounds are my preference.
edit....and gold connectors because it is gold Last edited by thomasmryan; 09-21-2020 at 07:49 PM. |
| The Following User Says Thank You to thomasmryan For This Useful Post: | ZDan (09-22-2020) |
#44 |
Drives: '23 BRZ
I picked the GMax AS-05 out for wife's Mazda3. Surprisingly good road feel for an all-season tire, good wet and dry grip, and not bad in the snow either. Previous generation were great as well. Would recommend...
#45 |
Drives: '23 BRZ
Not a thing wrong with those tires, but as long as we're on it...
Looking at more "upscale" UHP summer tires, the Firestone Indy500 is the most expensive UHP summer available from Tire Rack in 215/45-17, and it's generally highly regarded. Test results: https://www.tirerack.com/tires/tests...y.jsp?ttid=235 Whaddya know, the Falken Azenis FK510 you turned your nose up at outperforms it at a lower price. And here are some more "upscale" UHP all-seasons tested on the same car (2017 430i) if you don't like the GMax AS-05 (which is a very good tire): https://www.tirerack.com/tires/tests...y.jsp?ttid=241 Feel free to peruse and compare actual measured wet and dry performance between the categories. Interesting to note that while the all-season tires are only ~0.5 second behind the UHP summer Firestone Indy500 benchmark in dry laptimes, they're ~3 seconds faster in wet laptimes. Last edited by ZDan; 09-22-2020 at 07:46 AM. |
| The Following User Says Thank You to ZDan For This Useful Post: | soundman98 (09-22-2020) |
#46 | ||
Only happy when it rains.
Drives: series.blue
Let's be clear, the stock tires the car comes with are good enough for the majority of drivers to enjoy the car with. Most people are not able to find their limits before they hit the limits of their own driving ability. |
| The Following 2 Users Say Thank You to why? For This Useful Post: | mrg666 (09-22-2020), soundman98 (09-22-2020) |
#47 |
Don't know what to tell you, my experience has been the opposite.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | why? (09-26-2020) |
#48 | |
Drives: 2016 Scion FR-S
stock tires suck
And since I drive in a place where during the winter months certain roads are required to have the M+S designation, I got the AS/3+ and while a bit noisy they are much grippier (in a predictable way) and they are overall a decent tire. Would I take them to a track? No. But for my DD they are great...the stock tires were not in the same league as the AS3s. |
#49 |
Drives: 2014 GT86
BTW, today nice review of all season tires got released:
Though he obviously mentioned in it that even best handling feel all-season tire lagged feel wise behind summer tire. There is no way around due having those many sipes (for snow/ice traction) vs larger thread patches of summer tire that moves around less. Imho that's very big drawback if tire is considered for car such as ours, that frequently is bought for good handling & driving fun unlike generic family hauler. Grip is there, but feel .. not so much. Hence imho best bet for hours would still be getting proper summer or winter tire depending on weather, instead of getting compromised feel wise all-season, when not forced to by weather. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | albert (11-13-2020), Ohio Enthusiast (09-22-2020) |
#50 |
Drives: 17 Asphalt 86
Prioritizing what you want a tire to focus on at a set budget is probably a good start point.
The main issue I see with the majority of all season for my preference is worse turn in response due to mushier sidewalls. A friend runs Pirelli p zero A/S and likes how they feel. Might be a viable performance A/S for somebody looking for stiffer sidewalls. For somebody who will use the car to go to the shops and never push the car that isn't a problem. I know the FK510s were on my radar when shopping as the performance per dollar is good. They were actually more expensive than RT615k when I looked. Reviewers that road tested them back to back with other UHP tires all said the same thing, they are softer feeling tires aimed more at sport luxury segment. That doesn't fit how I want my tire to feel but it doesn't mean it's bad or somebody else may not care about the slight difference in feel. I would just stick with the primacys if I wanted a fun feeling not so grippy tire. They're dirt cheap "used" as everyone seems to have a near new set sitting somewhere in their house. in fact that's my plan, to keep the stock wheel/tire setup the same and play with different tires with my aftermarket set. I have 3 sets if you include winter wheels/tires. Even the pirelli tires I use for winter handle excellently on dry pavement. Last edited by RToyo86; 09-22-2020 at 08:51 AM. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | why? (09-26-2020) |
#51 | |
Drives: '23 BRZ
Handling feel and steering responsiveness are also a function of tire internal construction, not just tread block size and siping. If handling feel and responsiveness is a big deal, you should *definitely* check out specific test results and ratings before *assuming* that a "summer" tire is going to always be better in this regard vs. a UHP all-season. For sure if this is a big priority for someone, to the point that they wouldn't even consider any UHP all-season tire, at that point you may as well skip over the entire UHP summer category and about half of the Max Perf summer tires as well and go straight to "Extreme Performance Summer". Actually that's what I normally do but this year I went with "Max Perf" Conti ExtremeContact Sports for classification purposes for time trials. But then I bought Hoosier A7s to run 2 classes higher anyway... Last edited by ZDan; 09-22-2020 at 09:39 AM. |
#52 |
I think we have two different conversations going on here. @Mrt1990 in the OP specifically said the car is never tracked. So, basically he is looking for street only performance on the tires. This a world away from having different tires to handle specific track conditions are to run in specific classes.
It's all good info, but I'll reiterate that if you live in a relatively moderate climate, I believe you can find a set of all-seasons that actually are good for 12 months out of the year, and meet street performance criteria. Living in Georgia as I do, or S. California as @Mrt1990 does, separate summer/winter tires don't make a lot of practical sense for a street car. Heck, I drove my FRS for 60,000 miles with the original Primacies through 3 winters and really only had an issue on 1 day of those three years. The day after Snowmeggedon, they were absolutely fine. Of course, YMMV and probably does, or at least your opinion of it.
| The Following 4 Users Say Thank You to Dadhawk For This Useful Post: |
#53 | ||||
Drives: '23 BRZ
And I would say do not *assume* that going with a specific category of tire is going to give you the desired handling and feel you want! More research than that is required... Quote:
I look at Tire Rack tests for objective data on tire performance, and also subjective feedback on *feel*. And while I wouldn't trust customer survey results for ultimate performance limits, IMO they do provide a good source of subjective impressions on things like cornering stability and steering response. You do also have to take into account that a "high" rating in one of the UHP categories isn't going to equate to the same rating in the Max or Extreme Perf categories as expectations are different. But still worth looking at this stuff if handling feel is a biggie. See below... Quote:
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#54 | |
Drives: 2017 toyota 86
But they are directional so had to switch when i went staggered. and do have a lower tread life vs others like MPS A/S. Still at the price point solid tire. |
#55 | ||
I'm a bit spoiled with my current set of PS4S which cost me a couple hundred bucks. I don't want to pay $1200 for another set, which means I'll be compromising in some way when I shop in the spring. Quote:
I drop down to a 205/55/16 for winter use, and they still amazed me at how composed they feel on pavement wet/dry. They had great snow traction above 70% tread wear. Once they got down to 55-70% range I noticed a drop in snow traction. Now they're around 40-50% range and I'm not liking the grip levels. I am about to order a fresh set to replace them, if that's any indication of how much I liked them. |
#56 | ||
Drives: '23 BRZ
| Summer or All season? | Flame9020 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 02-04-2017 09:00 PM |
| Thoughts on tires? A great all-season or a great summer tire? | OUGrad05 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 47 | 05-06-2016 09:39 PM |
| Which type of tires should I get? All-season or Summer? | FatFree | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 02-23-2014 11:05 PM |
| summer or all-season tires? freezing temps? | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 04-07-2013 01:11 PM |
| Summer preformance VS All season performance | ScionFamily | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-06-2013 08:11 PM |
