Old 09-21-2020, 03:21 PM   #15
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by DarkSideFRS View Post
I see a part out coming. I did the recall with no issues, but I absolutely don't trust my motor now. In the process of selling my car as we speak
Smart. The issues can come thousands of miles later. The more sealant in the oil and the harder you push the car the sooner it's done. When they tore my engine down after it failed there was an absolutely LAUGHABLE amount of sealant in it. Almost like they tried to see how much they could get in there.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
gravitylover (09-21-2020)
Old 09-21-2020, 04:27 PM   #16
JD001
JD001's Avatar
Drives: Subaru BRZ
My recall was done with the car wearing an UEL, tune and CAI. I even had the Subaru dealer install a set of STi Group N engine and transmission mounts whilst at the garage. No issues, and the car has been running fine with the tune intact.
Old 09-21-2020, 05:29 PM   #17
jiffyjhn
Drives: White FR-S kosei k4r 17x8
sigh... I don't know what possessed me to do the recall. Really regretting it now
jiffyjhn is offline   Reply With Quote
Old 09-21-2020, 07:25 PM   #18
TommyW
TommyW's Avatar
If you don't need it for registration you should never get it done. The BRZ's have a lot better luck as they have experience with this motor. FRS and you're married to Toyota who, for the most part is very inept
Old 09-21-2020, 08:24 PM   #19
jiffyjhn
In california I think I needed it to get done for my next registration, but from what I'm reading depending on different DMV's you can get around that.
Getting ready to sell the car once I have it back. Too bad too as I've just finished all modifications I wanted for this car, car only has 25k miles too.
On the bright side, time to shop for a new daily driver. Will probably pick up a AP1 S2000 for modding or a recent year used 86/brz or ND Miata
The Following User Says Thank You to jiffyjhn For This Useful Post:
humfrz (09-22-2020)
Old 09-22-2020, 01:51 AM   #20
I thought you lived in Canada?
Old 09-22-2020, 07:36 AM   #21
Originally Posted by TommyW View Post
..the BRZ's have a lot better luck as they have experience with this motor. FRS and you're married to Toyota who, for the most part is very inept
Not really. This engine is unique to the 86 so Toyota actually has more experience with it than Subaru at this point, since they sold more copies. As mentioned ad nauseum here, the gasket seal is unique to this particular motor. While the recall covered more vehicles in general at Subaru (multiple models) the others all used real gaskets, not sealant.
I completely agree at this point if you haven't had it done, don't do it, but in the end the success of the repair is completely dependent on the care taken by the one mechanic working on the car. It has nothing to do with the logo on their shirt.
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
guitarman (09-25-2020), humfrz (09-22-2020), nitro_alltrac (09-22-2020), Tcoat (09-22-2020)
Old 09-22-2020, 09:47 AM   #22
gravitylover
The tech at the Subaru dealer where mine was done ruined my motor so no, just because it was done at a Subaru dealer doesn't mean there's a better chance of success.
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
Clipdat (09-26-2020), Dadhawk (09-22-2020)
Old 09-22-2020, 10:14 AM   #23
TommyW
TommyW's Avatar
that sounds realistic. Toyota selling more cars hence the higher recall and failure numbers makes sense. I have no idea why someone hasn’t made a gasket for these yet I never understood the sealant theory however the must be a reason behind it.
humfrz (09-22-2020)
Old 09-22-2020, 11:19 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Less parts in the BOM for manufacturing.
Tighter tolerancing, do not have to account for variation is gasket thickness and "squishiness".
More consistent torque, and better torque retention for fasteners between parts do to gasket squishiness.
Less chance of shifting between surfaces since there is no gap created by a gasket.
Old 09-22-2020, 11:47 AM   #25
TommyW
TommyW's Avatar
I guess blown motors because of uneducated techs is much more cost effective and more mechanically sound. With Toybaru footing the bill it seems like they’d put some effort into remedying the issue
Old 09-22-2020, 11:56 AM   #26
Why not use both? Back in my wrenching days, I used both. I used the sealant mainly to hold the gasket in place till the piece got bolted down -
Clipdat (09-26-2020), TommyW (09-22-2020)
Old 09-22-2020, 12:04 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think manufacturers plan on the engine needing taken that far apart during it's expected life so it is not a consideration. If it wasn't for the valve spring recall nobody would be having this conversation about the FA20. I prefer the sealant over gaskets, even with it's PITA quirkiness I honestly think a lot of the failures have less to do with the techs being uneducated, and more to do with lack of care and trying to rush to make book time.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Clipdat (09-26-2020), Dadhawk (09-22-2020), nitro_alltrac (09-22-2020)
Old 09-22-2020, 12:11 PM   #28
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Excepting the timing cover and A/T pump delete cover,
it's all good. Right?
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
