Old 09-20-2020, 01:45 AM   #1
Wubble
Hot Air coming outside passenger side air vent
Hey peeps
Noticed an issue in my 2013 BRZ now that weather is warming up in Australia and I have to start using A/C!
The passenger side air vent is putting out hot air despite the dual climate control being off and the temperature dial set to low with A/C on. I have cold air coming on the drivers side vents and I am able to switch that between hot and cold air.There's also a clicking noise coming from the dash when I attempt to change the air temperature controls.
What's the issue here? Is this an easy fix?
Wubble is offline   Reply With Quote
Old 09-20-2020, 06:21 AM   #2
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
I had it the other way round. Passenger side (RHD car) was blowing colder. Was due to a leaking cooling coil.
Brzerker is offline   Reply With Quote
Old 09-20-2020, 10:39 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Enable the dual zone control and try to change the passenger side temp, if that reproduces the clicking, you've most likely got a failed blend door actuator.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
humfrz (09-20-2020), nitro_alltrac (09-22-2020)
Old 09-22-2020, 03:39 AM   #4
Wubble
Okay, this seems to be it. Have no idea where it's located in the car though.
Old 09-22-2020, 12:02 PM   #5
This may help*
https://demos.starbase7.net/t3Portal/
* thanks to @Ultramaroon
Kris86 (09-24-2020), Ultramaroon (09-22-2020)
Oil leak coming from passenger side scion fr-s Engine, Exhaust, Transmission 19 04-26-2019 07:31 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 04:53 PM
Passenger door raddle and squeak coming from around speaker Peschi Issues | Warranty | Recalls / TSB 6 03-08-2015 02:58 PM
Fumes coming out from the vent? Moss Scion FR-S / Toyota 86 GT86 General Forum 22 10-11-2013 12:31 PM
Relay Sound Coming From Passenger Side jjkerr626 Issues | Warranty | Recalls / TSB 0 10-06-2012 10:29 AM
