Old 09-18-2020, 04:27 PM   #3893
Jaunt86
Drives: Black 2014 FR-S Monogram
Originally Posted by Gloonge View Post
Check around and make sure you don't have any fuel leaks and that you didn't install the Mas airflow backwards.
Plug should be toward the driver side.
MAS looks right
The bottom of the fuel banjo bolt is damp. No pooling or noticeable drips.
Jaunt86 is offline   Reply With Quote
Old 09-18-2020, 04:33 PM   #3894
Gloonge
Drives: 2013 frs raven
Originally Posted by Jaunt86 View Post
MAS looks right
This a brand new unit or second hand? Peek around by the injectors and did you secure all 3 bolts for the computer on the passenger side head?
Gloonge is offline   Reply With Quote
Old 09-18-2020, 04:58 PM   #3895
Jaunt86
Brand new... Sorta, been sitting around for 18 months waiting on me.
It threw a lean bank code after I let it warm up. I reset the code and now it won’t fire again. Not even a hint of it this time.
Everything seems tight on the passenger side. I’ll have to remove the ECU to check the injector bolts, though it seems tight, no play.
Old 09-18-2020, 05:00 PM   #3896
Gloonge
For shits and giggle see what your boost reading with just the ignition turned on. You might have a bad map sensor.
Old 09-18-2020, 06:35 PM   #3897
Jaunt86
MAF is 1.2 when just sitting here and jumps between 2-3 when cranking.
Old 09-18-2020, 06:39 PM   #3898
Gloonge
Yea that's likely gonna be the issue. Are you using edelbrocks tune or custom? I had the same problem when I installed mine. The map had to be scaled to where resting was closer to zero (mine is .33)
Old 09-18-2020, 06:45 PM   #3899
Jaunt86
Custom tune.
So it’s a bad sensor? The one on the intake?
There are two, right? One (original) on the intake and one supplied by edlebrock on the super charger.
Old 09-18-2020, 06:46 PM   #3900
Gloonge
Custom tune.
No sorry I mis spoke. I assumed you were using the edelbrock. Send the info over to your tuner and they should be able to scale it to a more appropriate level so you can get it started.
Old 09-18-2020, 06:52 PM   #3901
Jaunt86
Thanks for your help. I captured data when it was running and not, so we should have what we need.
I’ll update next week.
Old 09-18-2020, 08:31 PM   #3902
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
So you'll want to look at the MAP reading and compare to your atmospheric pressure. Depending on elevation you should be seeing right around 1 bar with the engine off. If the MAP has a different reading than that, it will definitely cause an issue. I had a similar issue but it was just dumping fuel because my MAP was seeing 2.5bar because of a cut wire in the harness.
aKaGorganZola is offline   Reply With Quote
Old 09-18-2020, 10:37 PM   #3903
Jaunt86
I’m seeing 6.24 psi, so not even .5 bar
Old 09-19-2020, 06:50 AM   #3904
aKaGorganZola
The importance thing is that they're the same. If they are I'd say the sensor is fine.
Old 09-21-2020, 12:17 PM   #3905
Smaay
Drives: 2013 FRS
Im sorry I keep coming into this thread at random times. Can someone please educate me on how the bypass works or whats its job is? Im not new to the FI world, And I understand how the bypass functions.
under vacuum the actuator pulls the bypass valve open allowing air to go around the SC? WHY?
Then when on throttlw, there is no vacuum, the bypass is spring loaded so it should close on its own?
When these bypass valves fail, the Vacuum cant hold the valve open? and it leaks?
When under full boost it sounds like the bypass valve is open, how is that possible? if its under spring tension? What is causing the P0171 codes? its all metered air going in so whats making the lean condition?
Smaay is offline   Reply With Quote
Old 09-21-2020, 01:24 PM   #3906
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
So you're cylinders aren't starved of air. It's like having the car operate on a non FI basis while at light throttle. Air recirculates through the supercharger while letting the throttle body do all the idle control.
That's right, it closes when there is adequate air volume to meet demand on the intake runner side of the supercharger.
When the bpv fails, it will no longer open at high vacuum conditions.
Under boost, there is no longer a vacuum, so the bpv closes.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
AKITA (09-21-2020)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
