Old 09-18-2020, 12:48 PM   #1
Wryvin
Wryvin's Avatar
Drives: 2013 Scion FRS
Looking to bench test a Instrument cluster
I did some work to a test instrument cluster and want to test the part before I put it back in a car. I was browsing through the schematics for the 2013s, and haven't found anything yet.
I was curious if anyone had already figured this out yet. I searched the forums and what I found is mostly just LED swap jobs and re installations. I will keep looking through the schematics, and if I find it I will update here.
Wryvin is offline   Reply With Quote
Old 09-18-2020, 12:58 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Maybe a silly question, but why not test in the car? You don't need to put it back in, just hookup the connector to it.
I would imagine a test bench would need to supply much more than just 12V to get anything meaningful from the cluster.
Ohio Enthusiast is online now   Reply With Quote
Old 09-18-2020, 01:17 PM   #3
Wryvin
Wryvin's Avatar
I haven't taken mine out of the car yet. I wanted to do quick ops check, without swapping them out. My ESD workbench isn't at home so I just wanted to test while I worked it.
I have a programmable Power supply that can support this, I have used it for much larger projects.
Old 09-18-2020, 02:18 PM   #4
Ohio Enthusiast
Drives: 2018 BRZ
I'm pretty sure you'll want the Combination Meter, starting at page 326 here: https://www.ft86club.com/files/BRZwiringi.pdf. That would be connector D7, a straightforward 2 row 40 pin connector. Looks like it's mostly controlled via CAN, so not sure how easy it would be to get it working outside of the vehicle.
Good luck, though!
Old 09-18-2020, 03:16 PM   #5
Wryvin
Wryvin's Avatar
Thanks I'll check that out. I really just need power, shouldn't need any of the signals.
Old 06-25-2024, 02:43 AM   #6
zapp
Drives: Toyota 86 gts
@Wryvin
hey mate, how did you go with this?
I am hoping to run mine outside of the car too. i want to make some changes and test before reinstalling. did you manage to get yours running?
Any chance you have a pinout/diagram for the pins on the back on the unit?
Cheers
zapp is offline   Reply With Quote
Old 06-26-2024, 01:18 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by zapp View Post
@Wryvin
Cheers
That member hasn't had any activity here for almost three years.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
zapp (08-04-2024)
Old 01-04-2025, 09:54 PM   #8
Phantomworks78
Drives: 16 Challenger Shaker 13 FRS
Hello, bumping this old thread because it pops up on a google search, I was able to bench test my cluster with just a 12V input.
This will illuminate all the bulbs (lamp check mode) and displays (along with showing cluster mileage)
You need to do the following;
Pin 1 - Input 12V
Pin 2- IGN
Pin 20 - GND
Bridge pin 1 & 2 with +12v
When looking at the back of the cluster (round side to the sky), pin 1 is the very top right, pin two is the next pin to the left of that (top row).
Pin 20 (ground) in the very top left pin.
Hope this helps others.
Phantomworks78 is offline   Reply With Quote
electrical, instrument panel, wiring diagram
Instrument cluster mystery Qwimby1 Scion FR-S / Toyota 86 GT86 General Forum 17 09-27-2018 11:07 AM
Single DIN Instrument Cluster Aussie DIY (Do-It-Yourself) Guides 0 04-01-2018 07:44 PM
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 05:02 PM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 02:31 PM
Scuderia Ferrari fires up V6 turbo on test bench quik1987 Other Vehicles & General Automotive Discussions 0 08-28-2012 07:31 PM
