go_a_way1, MisterSheep
Old 09-18-2020, 07:58 AM   #22331
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by FLIPDADY View Post
Installed this little guy. Best $25 spent so far on this car.
Sent from my LM-G900 using Tapatalk
I installed one and hate it. I ended up grabbing one of these:
https://www.camincstore.com/shop/universal-trunk-handle
I just installed it at the top of the plate (since we don't have holes in the bottom) and it works well without having to pull my hand out of the way of a closing trunk.
EDIT: You can just barely see it here.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 09-18-2020, 08:38 AM   #22332
Now that makes sense!
Wally86 (09-18-2020)
Old 09-18-2020, 09:15 AM   #22333
Agh! Never realized that was a problem looking for a solution.
Great if you want to slam your hand in the trunk. Would end up pulling it down and then pushing from above anyway.
Edit: What Wally said!
Dadhawk (09-18-2020), Wally86 (09-18-2020)
Old 09-18-2020, 10:09 AM   #22334
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
When I had my car in to get the ceramic coating done the owner showed me two Mustangs that had the trunks scratched to heck. I never thought about it but yes, people sliding their hands up and then back down to shut a trunk can make a mess out of plastic or painted panels.
My '06 STi had an inside grab handle from the factory. I got used to using it quite quickly. Never injured myself once in 13 years of ownership.
Old 09-18-2020, 10:44 AM   #22335
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I've always closed my trunk just touching the license plate.
Kaotic Lazagna (09-27-2020)
Old 09-18-2020, 10:54 AM   #22336
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I didn't want to touch the paint or push against the paint with the plate. I thought about a plate surround that has a handle at the bottom but...
Old 09-18-2020, 11:17 AM   #22337
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The car comes with two round rubber/foam pads glued on the trunk under the bottom of the plate.
Old 09-20-2020, 04:27 AM   #22338
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Backroad
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following 2 Users Say Thank You to Cedric For This Useful Post:
Dadhawk (09-20-2020), MJones_RB (09-21-2020)
Old 09-20-2020, 08:22 AM   #22339
jflogerzi
jflogerzi's Avatar
Originally Posted by Cedric View Post
Backroad
Where? Damn fires
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Cedric (09-20-2020)
Old 09-20-2020, 08:24 AM   #22340
Cedric
Cedric's Avatar
Originally Posted by jflogerzi View Post
Where? Damn fires
Livermore, California.
Old 09-21-2020, 07:28 AM   #22341
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
No quicker way to wear it out than by interacting with it all the time
Old 09-21-2020, 08:06 AM   #22342
Geeez how often do you people close your trunk? I was in and out of mine 4 times a day for 5 years. Either pushed on the spoiler or plate but had zero scratches in the paint and did not wear out the rubber pads.
The parts are not made out of sugar!
Dadhawk (09-21-2020), soundman98 (09-21-2020)
Old 09-21-2020, 08:22 AM   #22343
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
They're not?!
The Following User Says Thank You to Wally86 For This Useful Post:
Tcoat (09-21-2020)
Old 09-21-2020, 11:33 AM   #22344
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Sure. They will only last 35 years instead of 40. I'm sure the pads will still be there when the car is long dead.
Wally86 (09-21-2020)
