Old 09-10-2020, 09:27 PM   #211
pallen
pallen's Avatar
Drives: 2017 Toyota 86
That’s what I was asking them...about their car.
Yeah, I’m a little curious if they actually tried to hit 500. I hope they filmed it...
pallen is offline   Reply With Quote
Old 09-10-2020, 10:54 PM   #212
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Maybe you are. This is what they posted:
Old 09-11-2020, 12:22 AM   #213
solidsnake11
Drives: brz
Originally Posted by IRitzCrackerzI View Post
Sorry for the late reply. I’m not sure what the percentage is. It’s typically 20% on most RWD cars. I’m probably around 18% with some lightened drivetrain parts.
591crank hp @20lbs is pretty good for a gtx3076
solidsnake11 is offline   Reply With Quote
Old 09-11-2020, 04:21 AM   #214
Irace86.2.0
What does it typically make?
Here is more info:
https://www.ft86club.com/forums/showthread.php?t=58935
Old 09-11-2020, 01:06 PM   #215
IRitzCrackerzI
IRitzCrackerzI's Avatar
Drives: Whiteout FRS
Next summer depending on what happens. You may see that stock block go to a 2.2L and the turbo go from the 3076 to a 6766.
IRitzCrackerzI is offline   Reply With Quote
Old 09-11-2020, 02:28 PM   #216
pallen
pallen's Avatar
That is nuts! How many miles has it run at that power now?
Old 09-11-2020, 03:41 PM   #217
Irace86.2.0
Now...that video is old like 2014 old, so the motor probably blew or the engine got built, but I'm curious as well. Obviously the car could be driven without ever using that power, so any years or mileage specified would need to come with specifics.
Old 09-11-2020, 04:30 PM   #218
pallen
pallen's Avatar
... Obviously the car could be driven without ever using that power...
Thats a good point. If you look at the curve, it mostly comes on fast at the high end. Its much more conservative down low. If you don't drive it to redline, you probably never see more than 300.
Old 09-16-2020, 10:18 AM   #219
evomike
Drives: frs
Blitz turbo kit uncatted
Tomei overripe and front pipe
Buddy club spec 2
Deatshwerks fuel pump
Grams 550 injectors
tune is on high boost spring (10 psi)
evomike is offline   Reply With Quote
The Following 2 Users Say Thank You to evomike For This Useful Post:
HaXx (11-04-2020), Wally86 (11-09-2020)
Old 11-04-2020, 01:15 PM   #220
SakuraEightySix
Drives: JDL Turbo Twin
JDL Turbo Kit DynoGraph
JDL Turbo Kit
GT2860RS
UEL Manifold
Open Dump
Turboback Exhaust
7psi wastegate spring
93 octane
Tuned by Zach @ CSG
Very impressed for the 7psi spring
SakuraEightySix is offline   Reply With Quote
The Following 6 Users Say Thank You to SakuraEightySix For This Useful Post:
anticubus (11-04-2020), DarkPira7e (11-04-2020), Drifter X (11-04-2020), pallen (11-04-2020), Pete (08-20-2021), Wally86 (11-09-2020)
Old 11-04-2020, 08:41 PM   #221
anticubus
Originally Posted by SakuraEightySix View Post
JDL Turbo Kit
GT2860RS
UEL Manifold
Open Dump
Turboback Exhaust
93 octane
Tuned by Zach @ CSG
I'm never disappointed when I see Zach's work, this time is no exception. Congrats on the tune, that looks fun as hell!
anticubus is offline   Reply With Quote
The Following User Says Thank You to anticubus For This Useful Post:
AldoRaine (11-10-2020)
Old 11-05-2020, 07:44 AM   #222
Hudzoyne
Drives: Turbo GT86 - Fensport Performance
From the UK, graph is BHP, engine power not at the wheels.
- "Stage 4" Avo Turbo kit but with direct fit replacement GTX3076 by Fensport Performance
- Stock pistons, machined Manley turbo tuff conrods, ton of oiling mods, 1.45mm head gaskets, Kelford valve springs. 11.6:1 compression, super simple build to test limits of stock pistons. Engine built by me at Fensport Performance
- Shell Vpower 99 Ron pump fuel with direct port, pre throttle and turbo volute methanol injection, replacing roughly 20% of fueling with methanol. Pure methanol no water.
- Tuned by me at Fensport Performance - www.fensport.co.uk
- higher run is 1.4bar with meth. Lower run is 1.3bar no meth.
The car is used daily, I'm now at 1.6bar with some more methanol so need to go back and see if we can crack 500bhp on the stock pistons but I am very happy with it so far.
Hudzoyne is offline   Reply With Quote
The Following 5 Users Say Thank You to Hudzoyne For This Useful Post:
anticubus (11-05-2020), DarkPira7e (11-05-2020), Drifter X (11-11-2020), pallen (11-11-2020), Wally86 (11-09-2020)
Old 11-05-2020, 06:33 PM   #223
WC-BRZ
Drives: Black BRZ
- Stock pistons, machined Manley turbo tuff conrods, ton of oiling mods...
Are you able to share details on the oiling mods? Thanks
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Old 11-10-2020, 02:19 PM   #224
SakuraEightySix
I have honestly never seen on a dynograph, someone crack 300whp on the 7psi wastegate spring. Air quality was good that day, air temp around 67F. The listed torque numbers seem to be around what most show on the 7psi spring, but the whp, I don't know if it was just the dyno, or what. Zach is an elite tuner. Very excited to have had the opportunity to be tuned by him.
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
