, dpfarr
Old 09-07-2020, 12:22 AM   #3851
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Thanks @AKITA . I think the hose on the passenger side that connects to SC is molded, I think at a 90 degree angle right by the supercharger connection. Are the provided hoses flexible enough to make that turn? Does that entire Edelbrock hose just get discarded?
BR-ZED is offline   Reply With Quote
Old 09-07-2020, 01:38 PM   #3852
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
No... the passenger Radium used 3/8 hose like the one that comes in the Edel kit (driver side uses 1/2 inch which is the same in the Radium kit) .. Like I said it requires some planning and trimming to fit. So from the SC using the Edelbrock hose, cut and use a barbed coupler (you can securewith black plastic zip ties if nothing else) then run to can. I originally said disconnect from SC which I would still do after I measured to do the trimming and fitting the coupler then reconnect after assembly. This would be the return. I would probably do the same for the PCV to can.
AKITA is offline   Reply With Quote
The Following User Says Thank You to AKITA For This Useful Post:
BR-ZED (09-07-2020)
Old 09-07-2020, 02:21 PM   #3853
BR-ZED
BR-ZED's Avatar
Oh ok. So you are saying reuse both the LH PCV (51-4247) and RH PCV (51-4246) I'm their entirety, just splice both to insert catch can in line with them?
It just seems tough to disconnect the RH side (passenger) because getting in there with all the harnesses/ supercharger in the way will be tough with big hands.
Old 09-08-2020, 12:27 AM   #3854
AKITA
AKITA's Avatar
I sent a pm.. but yeah if they're too big and you might have to anyway.. remove air intake and maybe throttle body.. if so ugh.. changes my opinion maybe a little when you should do this.. because I did redo all my hoses before putting the air intake on.. but still doable. just a little more PTA like everything else
BR-ZED (09-09-2020)
Old 09-09-2020, 06:24 PM   #3855
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Alright so I've recently started having really bad idle problems with my car so much so the car is practically stalling at lights. The car can't hold constant rpm's under load either. So if I try to load the engine to say 2500 rpm in neutral the rpms will bounce around from 2000 rpm to 2500 rpm. My engine is pretty old having 160k miles with about 7k of them being boosted. Tune is fine considering I've put 7k miles on it without issue until now. Car is tuned to run on 93 pump gas and I have a full exhaust system including headers.
I'm thinking my engine is starting to lose compression due to the added stress and its age. What do you guys think? I don't think I have any Vacuum leaks but its on my list of things to check come the weekend.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 09-09-2020, 06:25 PM   #3856
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Check the dreaded bypass valve. Pinch the hose on the back of the supercharger. That would be the first suggestion overall.
Sent from my Pixel 4 XL using Tapatalk
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
brandonblt2 (09-09-2020)
Old 09-09-2020, 06:34 PM   #3857
brandonblt2
I have the latest Edelbrock kit from Edelbrock themselves. Wasn't that fixed when they upgraded the kits? I'll still give it a shot though.
Old 09-09-2020, 06:34 PM   #3858
Mad1723
Mad1723's Avatar
Comes with a new bypass? Did you verify?
Old 09-09-2020, 06:44 PM   #3859
brandonblt2
Yup I checked it. It came with the new one. I tested it anyway just squeezing it seemed fine no loss of pressure.
Old 09-09-2020, 09:07 PM   #3860
AKITA
AKITA's Avatar
Let's do a check list
Fuel Injectors: after the BO valve verify, this is my first place to look @160k then changing tune and require them to spew more fuel than they've done for 150k miles.. could be drippy dirty injectors. (easy fix)
Spark plugs and Coil Packs: would have changed those before SC install , but if either have significant wear.. could be (PTA)
Air filter: shouldn't be that unless it's leaking somewhere but doubt it if no initial issues which you didn't have for 7k
PCV valve:... sticky?? 160k miles on it?.. that's gonna be a really PTA to change now. I would isolate to test by pulling and plugging at the SC .
EGR valve: the one that gets modded.. pulled off the OEM manifold.. could be but not likely if it's doing right at start up.. plus a faulty one I'd think would trigger a code.
Head Gasket: doubt that's it for jumpy idle (dye test rule that out but hopefully not)
Fuel pumps : could be but the demand on them shouldn't have changed much.
MAF sensor: dirty or not seated well.. both? MAF sensor cleaner!
O2 sensors: yeah check those( but again, I would hope significant failure would cause a code).. after the above
All that good? compression test
somewhere in all the above a problem will be found I would think.. hopefully it's not the compression test
Old 09-09-2020, 10:58 PM   #3861
toast
Drives: 14 BSP Edelbrock BRZ
Do you have a Dbox?
toast is offline   Reply With Quote
Old 09-10-2020, 11:40 AM   #3862
brandonblt2
Ok how would I go about testing these? I would just visually check for clogs?
Changed the spark plugs before I installed the SC. I didn't change the coil packs since the rubber boots seemed to be in good condition and they're expensive. I'll recheck them to see if any damage has occurred.
Air Filter is clean South Jersey air is pretty good and I don't drive on dirty roads.
PCV valve:... sticky?? 160k miles on it?.. that's gonna be a really PTA to change now. I would isolate to test by pulling and plugging at the SC.
This could be it also. Car runs extremely rough on startup some times then it smooths out and gets better as I drive. I've seen people recommend the WRX PCV because we are boosted. Is this worth an upgrade or is oem fine?
I haven't noticed any coolant disappearing. But I'll do the engine block leak test since it seems simple enough
I have let my fuel run low before to actually having it trigger a CEL. But that was years ago. I imagine my fuel pump may be struggling a little bit now.
I cleaned the MAF Sensor while installing the SC. I'll still double check it tho. Thanks for the list I'll try to run through most these to narrow down whats going on.
Old 09-10-2020, 11:42 AM   #3863
brandonblt2
Originally Posted by toast View Post
Do you have a Dbox?
Nope. I was thinking of getting one tho. But with the rough idle and weird power loss problems I don't think it would help my situation.
Old 09-10-2020, 11:45 AM   #3864
toast
I would not, just wondering if you did because the harness for the Dbox goes to the MAP sensor and people have had issues with it.
Can you get a log?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
