Old 02-21-2019, 08:08 AM   #43
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by HaXx View Post
Will open end really cause it to rust that bad?
Yes, as soon as water gets in them (strong rain, sprinklers) they will trickle rust tracks over your wheels.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tanstin (09-09-2020)
Old 09-05-2020, 09:41 PM   #44
daniloneil8
Are the OEM lug nuts inferior?
Like the 2-piece kind that get stripped on the outer cap?
I prefer the OEM look, what should I buy?
I want zero tuner flash, just quality that is more reliable and not likely to get stuck.
What brand ? Gorilla? McGard?
daniloneil8 is offline   Reply With Quote
Old 09-06-2020, 12:18 PM   #45
HaXx
Drives: jrsc_brz
basically the gold standard are gorilla spline close ended lugs, i think theyre 25$. In your scenario, i would opt for close ended lugs, it will not allow road grime/salt to reach the studs and potentially cause a crossthread problem down the road. im using gorilla closed spline currently. the "spline" refers to the special key that you use to take them on an off, its supposed to help with theft prevention, i keep it in my glove box, but every shop on planet earth has these keys in their toolbox's.
Just to reinforce how much of a staple the gorilla splines are, if you buy wheels/tires from tire rack, gorilla splines come free
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 09-06-2020, 03:16 PM   #46
soundman98
ProCrastinationConsultant
soundman98's Avatar
Since when? The last 2 sets of wheels I've ordered have not had splined lug nuts
Old 09-06-2020, 03:31 PM   #47
ZDan
ZDan's Avatar
Drives: '23 BRZ
Either of those is gonna be fine.
Old 09-06-2020, 03:32 PM   #48
HaXx
Drives: jrsc_brz
the enkies i got in spring 2019 from tirerack came with them
The Following User Says Thank You to HaXx For This Useful Post:
soundman98 (09-06-2020)
Old 09-06-2020, 04:39 PM   #49
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe I'm crazy, but I definitely never had this happen that I'd notice, and I've driven through a lot of rain on my car with junk aluminum open ended lugnuts
Old 09-06-2020, 04:57 PM   #50
churchx
churchx's Avatar
Drives: 2014 GT86
I stopped using alu lugnuts, as powertools are simply too comfortable for someone as lazy as me, to spend lot of care tightening them with hand. As for openended ones, due extended studs installed i have to use such. But for DD i simply install plastic caps over, for dirt to not get in.
Old 09-06-2020, 08:15 PM   #51
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I like McGards. The floating seat saves some paint on the wheels and they fit perfectly on standard length lugs.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 09-09-2020, 10:34 PM   #52
Chuckls
Moutain Runner
Chuckls is offline   Reply With Quote
Old 09-09-2020, 10:55 PM   #53
Misfit714
just bought the project kics r40 lug nuts in neo chrome!
Misfit714 is offline   Reply With Quote
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 10:47 PM
Lets talk lug nuts Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-23-2014 04:42 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 02:37 PM
Car talk calis5nest FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-02-2013 03:04 PM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 12:32 PM
