Old 09-03-2020, 01:57 PM   #72353
JD001
JD001's Avatar
Drives: Subaru BRZ
My life revolves around "assumptions", I'm kinda of a "glass half full " type. This played out recently at work, I'm in a pool of 3 going through the redundancy process. I suggest to the other 2, why don't we put forward reduced working week.. this way we can save one job. The suggestion initially met with a damp, lukewarm response. I then offer to take the greater hit ie I work 2 days whilst my "pool" colleagues work 4 days thus we save 5 days a week... Again a rather negative but a reluctant agreement!! My pool buddies much rather see one person out instead of looking at a reduced income and keeping the 3 employed.. it's not as if we would be part-time for a long period.. Only until the work picks up..
Anyway, find out this week if the company will entertain part-time hours or one of us is out... Again "glass half full", if it's me then great as it gives me an opportunity to do something else... Go fruit picking or something..
Well, that is a tough call. My thought is that it would be better for all three of you to take reduced hours, rather that one get laid off. That's what "team" work is all about.
That's was my thinking too.. but the other two aren't of that thinking.. I sensed that they begrudgingly considered my suggestion. I have a feeling that as I'm the new kid in their team, just joined back in March, they're of the mindset that I am the weakest therefore will be out.. Who knows.. It's times like this that one sees the true and varied colours that is the tapestry of life...
It would depend on whether the 1 is a furlough (going to be called back) or a reduction in staff. Salary isn't the only thing to consider. Keeping 3 part time employees but retaining their benefit and government payments (Social Security, Medicare, Unemployment, etc) isn't really a 1/3rd reduction in cost.
Lol it's going to be whoever gets paid the most. Doesn't matter how long you worked there.
I think that the company is restructuring, using the current situation as an excuse to drop employee numbers. In the bigger scheme of things, the drop they are wanting is circa 6.5%... it just doesn't make sense but as soon as you factor in change of structure then things fall into place.
I have a feeling that I may be the most expensive in my little pool. Anyway, either way I'm not concerned. Keep you all posted with developments.
A letter from HR dropped into my Inbox... My pool no longer at risk therefore we carry-on as normal... Workload fluctuations coming into play.
Obviously I didn't know how my pool faired, so what's normal for me, I ask the others if they've heard.. yep they got the "good" news too but didn't think of instigating the reach out!! "Team" players for sure!!
JD001 is offline
The Following 4 Users Say Thank You to JD001 For This Useful Post:
Dadhawk (09-03-2020), NoHaveMSG (09-03-2020), Sapphireho (09-03-2020), Spuds (09-03-2020)
Old 09-03-2020, 02:07 PM   #72354
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Progress bars, the engineer's version of "working".
ScoobsMcGee is offline
The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post:
NoHaveMSG (09-03-2020), p1l0t (09-03-2020), soundman98 (09-03-2020), Spuds (09-03-2020)
Old 09-03-2020, 02:41 PM   #72355
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'm pretty sure that actually happened at my last job.
Spuds is offline
Old 09-03-2020, 03:08 PM   #72356
spike021
spike021's Avatar
Resistance, noise, timing, other things. Every wire is a resistor, antenna, etc, and Im not sure that the OBD standard accounted for anything but a single device connected to the computer. So no, I can't tell you exactly what is going on, but it's not too surprising that the configuration you have the wires in matters.
We really take consumer electronics for granted these days, forgetting that a shit ton of work and testing went into the standards and interface hardware that lets most products be mostly idiot-proof.
Yeah I was wondering more in terms of technical factors like this. As a software engineer a lot of what I go through with debugging shit is something like the following:
* what you expect to happen
* what is happening
* etc.
So it's weird that different combinations of factors have different outcomes.
The factory connector isn't designed for frequent connect-disconnect cycles. Using an extension moves the eventual failure mode to a relatively inexpensive replaceable part. My extension has held up well. I have it glued into the little box in front of the gearshift.
Yeah, totally. I get that part about the factory connector. Was mostly just wondering why different combinations of connections work and others don't, seemingly at random (@Spuds point makes good sense of that, though).
Instagram: @spike.grc
spike021 is offline
The Following 2 Users Say Thank You to spike021 For This Useful Post:
Spuds (09-03-2020), Ultramaroon (09-03-2020)
Old 09-03-2020, 04:00 PM   #72357
Maybe they weren't sure that you got the good news memo - that maybe you were cut and they didn't want to make you feel bad -
Oh, OK, that seemed funny, when it was in my head -
humfrz is offline
JD001 (09-04-2020), soundman98 (09-05-2020)
Old 09-03-2020, 05:56 PM   #72358
ls1ac
ls1ac's Avatar
My favorite was:
This program is no good.
This is what you asked for.
It is not what i wanted.
ls1ac is offline
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
NoHaveMSG (09-03-2020), soundman98 (09-03-2020), Spuds (09-03-2020)
Old 09-03-2020, 06:05 PM   #72359
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I think my connector is not working in my car. My P3 stopped working, and I cannot connect with my OBDII dongle. So bummed.
Sapphireho is offline
spike021 (09-03-2020)
Old 09-03-2020, 06:15 PM   #72360
spike021
spike021's Avatar
Maybe try the extender trick? But if not I’m guessing you’ll need to have someone rewire/replace it.
The other guys probably know way better than me though.
spike021 is offline
Old 09-03-2020, 07:35 PM   #72361
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
* what is happening
* etc.
Resistance is weird man. I had full LED replacements in all exterior lighting. I ran it both with and without a changed relay. No issues. I install Tom's tail lights and when I hit my blinker both signals would go off and my radio would brighten/go dark in sync. I had to take the LED out of my front turn signals to get it to stop
finch1750 is offline
spike021 (09-04-2020)
Old 09-03-2020, 09:34 PM   #72362
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My extended range solution worked out perfect. For the most part, didn’t even notice it was there.
NoHaveMSG is offline
The Following 9 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (09-04-2020), humfrz (09-04-2020), JD001 (09-04-2020), MICHAEL450f (09-04-2020), ScoobsMcGee (09-05-2020), soundman98 (09-05-2020), Spuds (09-04-2020), Stephen W. (09-04-2020), Ultramaroon (09-03-2020)
Old 09-03-2020, 11:45 PM   #72363
I hear it's also futile.
Ultramaroon is offline
The Following 7 Users Say Thank You to Ultramaroon For This Useful Post:
finch1750 (09-04-2020), NoHaveMSG (09-04-2020), ScoobsMcGee (09-05-2020), soundman98 (09-05-2020), spike021 (09-04-2020), Spuds (09-04-2020), Tcoat (09-04-2020)
Old 09-04-2020, 04:55 AM   #72364
Tcoat is offline
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
finch1750 (09-04-2020), NoHaveMSG (09-04-2020), p1l0t (09-04-2020), ScoobsMcGee (09-05-2020), soundman98 (09-05-2020), spike021 (09-04-2020), Spuds (09-04-2020), Ultramaroon (09-04-2020)
Old 09-04-2020, 06:52 AM   #72365
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
There's no capacity for humour here.
Captain Snooze is offline
The Following 6 Users Say Thank You to Captain Snooze For This Useful Post:
Old 09-04-2020, 06:57 AM   #72366
Captain Snooze
Drives: Red Herring
This is my younger sibling. Transistor
p1l0t (09-04-2020)
