| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Master Collaborator
0W-16 Oil
Has anyone with forced induction tried this new 0W-16 oil developed specifically for boosted, direct injected engines in any of their cars yet?
I'm suspecting it may not work quite right with the VVT system in the FA20/4U-GSE and may cause some codes to start appearing concerning the cam timings. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | humfrz (08-28-2020) |
#2 |
Why would anyone ever dream of going DOWN in oil weight from the already light weight 0W20?
| The Following 7 Users Say Thank You to Tokay444 For This Useful Post: | alphasaur (09-20-2020), DarkPira7e (08-28-2020), meWant (09-09-2020), PulsarBeeerz (08-29-2020), soundman98 (08-28-2020), Spuds (09-01-2020), timurrrr (09-02-2020) |
#3 |
Drives: 2018 Subaru BRZ Limited with PP
#4 |
Master Collaborator
#5 | |
#6 |
Drives: 17 Asphalt 86
Might not be a bad idea of those of us seeing winter conditions. Those -20 cold starts.
#7 |
Drives: 2014 FR-S Monogram
I imagine those engines are specifically engineered to run 0W-16. The FA20 isn't. Using thinner oil than what is recommended by the manufacturer is almost universally a bad idea.
#8 |
Rust bucket enthusiast
I doubt 4 points would make a difference in a cold start. Not worth the trade-off with risk, since pressure is really important on cold starts where everything is drying out
#9 |
Drives: 2014 MY15 86 GTS
They are both 0 it would make zero difference in cold start......
#10 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Hold on a sec. Did I read you correctly? Honda are recommending 0-16 to COMBAT oil dilution? So their thinking is adding gasoline to a 0-16 will transform it into a 0-20?
Slow is smooth, and smooth is fast
#11 |
Drives: Q5 + BRZ + M796
Manufactures want thin oil for better fuel economy. That's all.
I went 5w30 when I added forced induction because all Subaru engines that are forced induction come with 5w30. If I was tracking the car then I would consider an oil cooler and a heavier grade oil. The GT86Cup manual has the oil listed as ELF HTX 825 10W60. There is an oil cooler option. This is for "stock" cars, so no forced induction, which means less heat and less forces pushing down on those bearings. https://racing.tgr-europe.com/wp-con...anual_EN-1.pdf
#12 |
Seems like an oxymoron to go thinner to combat dilution.
Is their reasoning that it’s already as thin as gasoline, so adding more of the same can’t hurt? |
#13 |
To make myself more clear, though I was mostly joking, it does make a difference. 0W-20 will have a lower viscosity than a 0W-40 oil at startup. In the case of 0W-16 vs 0W-20, the difference is probably quite insignificant to care about, which is why I intended it to be a joke.
#14 |
Drives: 2022 GR86
