#29 |
Drives: '23 BRZ
If you replace RE71R when wear gets to the indicators, you're getting less than half the useful life out of them. I would also be at the indicators after 4 track days, but when I kept running them on the BRZ while Porsche was in the shop last year, I got 6 more track days out of them and didn't reach the cords or lose much if anything in terms of grip due to heat cycles.
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | captain awesome (09-01-2020), strat61caster (09-01-2020) |
#30 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'll snap some pics later, but my rear tread is almost gone. The fronts have a fraction more, so if I swapped to the rear I have maybe another half day on them. UNLESS you can run them with zero tread depth left. |
#31 | |
Wears Pants
I've had a couple friends order autocross compounds through JB and seemed to be pleased. I'll ask around to see if there's any that pop up. I know I can get some 255 40 17 Gforce 1s for cheap, but not sure those are worth snatching up over spending a little more for the r7s. |
#32 | |
Drives: '13 FRS - STX
We've run them down to this; They get edgier, much harder to get 10/10ths out of them, but they still feel like they have grip to my butt dyno. |
| The Following User Says Thank You to strat61caster For This Useful Post: | captain awesome (09-01-2020) |
#33 |
Wears Pants
#34 |
Drives: '23 BRZ
You can run them with zero tread depth left...
#35 |
If you were autoxing I'd say another event day or two depending on conditions via swapping, but assuming your TT offers HPDE levels of seat time (1-2 hours per day) fresh tires are relatively cheap.
#36 |
Drives: '23 BRZ
You need more camber!
You probably should have flipped them before it came to this... On my BRZ with -3.3 front -2.6 rear camber I never flipped them, just rotated every event. I ran them as "slicks" for at least 3 track days. Never showed cord. |
| The Following User Says Thank You to ZDan For This Useful Post: | ML (11-29-2020) |
#37 |
Wears Pants
Has anyone run the Falken rt660 yet?
#38 | |
#39 |
Interestingly I ran my rear tires like that at my last track day but with inner camber wear instead of outer. The tires (RS3's) felt the exact opposite. Loose but easy to catch in corners. Never felt like they had any real grip especially on throttle.
2022 BRZ Build 2013 FR-S Build |
#40 | |
I hear BFG's for example feel exactly the same, they just have less grip. |
| The Following User Says Thank You to strat61caster For This Useful Post: | DarkSunrise (09-01-2020) |
#41 | |
Is the consensus basically that tread depth has zero correlation to dry grip?
#42 |
Depends on the tire, some have layered compounds and along with the age/heat cycle changes of the compound you may hit a point where you've used up all the sticky stuff before the grooves are gone.
| Delicious Tuning - NA Development Thread | DeliciousTuning | Engine, Exhaust, Transmission | 75 | 06-14-2020 02:32 AM |
| Verus' Shop BRZ - Development Thread | VerusEric | Member's Car Journals | 266 | 12-19-2019 04:12 PM |
| FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 712 | 12-11-2018 10:13 PM |
| Raceseng | Development FT86 | Build Thread | Raceseng | Member's Car Journals | 17 | 06-06-2013 09:22 AM |
