Old 08-31-2020, 12:03 AM   #22261
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by jflogerzi View Post
You can buy it. It's based on this I think
https://www.beatsonicusa.com/mobile-...ies/qbf13.html
Not quite. That phone holder is for two-piece dashes. I recently swapped to a one-piece dash, so there's no more gap in between to insert that mount.
On top of that, I previously had a phone holder from them and found that the rubber grips holding the phone wear down to the point they no longer hold effectively.
The Following User Says Thank You to KR-S For This Useful Post:
jcw99 (08-31-2020)
Old 09-01-2020, 12:37 PM   #22262
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I determined the dash was too heavy so I cut it up to save weight. Maybe.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
Cedric (09-01-2020), humfrz (09-01-2020), MJones_RB (09-01-2020)
Old 09-01-2020, 01:13 PM   #22263
Good move. Back in the day there was a purpose for a dashboard, no so anymore. Just think of all the weight you could save if you took all the glass out of the car -
JD001 (09-02-2020), ToySub1946 (09-01-2020)
Old 09-01-2020, 01:46 PM   #22264
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Heck, back in the day this was all we needed!
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
humfrz (09-01-2020), JD001 (09-02-2020)
Old 09-01-2020, 02:51 PM   #22265
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I did take the glass out of one of my other cars..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
humfrz (09-03-2020)
Old 09-01-2020, 04:05 PM   #22266
thekevinvo
Drives: 2014 Scion FRS
Installed the Perrin Oil Cooler today to take care of the oil temps at the track.
thekevinvo is offline   Reply With Quote
The Following User Says Thank You to thekevinvo For This Useful Post:
Cedric (09-01-2020)
Old 09-02-2020, 01:39 AM   #22267
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Broke the weld on my new Tomei front pipe. Luckily it wasn’t the actual front pipe, but the weld for the mount.
I know a guy who can weld titanium, so I’m not too worried, but it’s rattling like crazy now.
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following User Says Thank You to Cedric For This Useful Post:
humfrz (09-03-2020)
Old 09-02-2020, 11:00 PM   #22268
soundman98
ProCrastinationConsultant
soundman98's Avatar
doesn't look like a very good weld. looks like they cold-welded/spot-welded it to get the appearance of 'stacked dimes' at too low of a current...
Cedric (09-03-2020)
Old 09-03-2020, 12:11 AM   #22269
Bubba says to just jam an old screwdriver in there and wrap it up with baling wire till you can get it welded.
Old 09-03-2020, 03:14 AM   #22270
Cedric
Cedric's Avatar
Just seems strange. I’ve heard Tomei makes quality stuff. The welds on the actual piping seem extremely nice, I’m not sure how that weld snapped. I’ve also heard Titanium is super sensitive, but I don’t really know, I would have to do more research on it.
Old 09-03-2020, 09:01 AM   #22271
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Got this thing in the mail...
Unfortunately... it only mostly fit? lol
I assumed I'd either have to drill out the stock front pipe flange or buy some bolts in the correct size so off to Lowes...
I really wanted that quad tip look.
And thanks to cutting my hand, I didn't spend the time to loosen everything and straighten it up so... here's a picture of my crooked exhaust until I fix it LOL
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is online now   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
DarkPira7e (09-03-2020), MJones_RB (09-03-2020), trvth (09-09-2020)
Old 09-03-2020, 09:20 AM   #22272
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Any reason you can't use the stock bolts?
I was super happy with the fitment of my FT86SF x Remark exhaust- but I have an aftermarket frontpipe that isn't using the donut gasket
Old 09-03-2020, 09:29 AM   #22273
Stephen W.
Stephen W.'s Avatar
Look at it closely. The bead just runs along the edge of the "L" bracket instead of over it melting/fusing it and the base together. Look at the other "L" bracket and you can see that the bead clearly blends into the bracket. Welder may have had the correct settings just missed his/her mark. A good inspector would/should have caught this before shipping.
Cedric (09-04-2020), soundman98 (09-03-2020)
Old 09-03-2020, 10:30 AM   #22274
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
So the stock bolts... have that spring... and i did in fact take a clamp to it to make that work but bottoming out the spring still wasn't enough to bring the flanges together. lol
BUT, now that I think about it... that was BEFORE I removed the donut gasket. It's not in the instructions but that thing definitely is NOT compatible with an aftermarket exhaust. Hence the supplied third gasket, I'm sure but it would have been nice to know.
