Old 08-23-2020, 02:43 PM   #141
soundman98
ProCrastinationConsultant
soundman98's Avatar
my girlfriend says she doesn't remember giving you permission to post that picture.
Old 08-29-2020, 05:15 PM   #142
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Update: Got all the armor bits on and filled in the lines with ink!
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Dadhawk (08-29-2020), Spuds (08-29-2020)
Old 09-26-2020, 05:02 PM   #143
Kaotic Lazagna
Drives: GR Corolla
I know it's not plastic, but has anyone ever repainted a diecast model? Specifically AutoArt ones that are NIB?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Tcoat (09-26-2020)
Old 09-26-2020, 07:53 PM   #144
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I've done some painting on a diecast Maisto. Treated it the same way as a plastic model.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Tcoat (09-26-2020)
Old 09-26-2020, 08:35 PM   #145
All the same principals apply. The materials are irrelevant.
Old 09-26-2020, 09:25 PM   #146
Kaotic Lazagna
Drives: GR Corolla
But stripping paint off metal is different than plastic models, right? Can't use paint stripper on plastic since it'll melt it?
Old 09-26-2020, 09:31 PM   #147
shiumai
shiumai's Avatar
I didn't strip paint when I painted the diecast - just sprayed over the existing color. You didn't specify to what extent you wanted to do the repaint (full disassembly, strip, repaint or partial disassembly, mask/paint).
Kaotic Lazagna (09-27-2020)
Old 09-26-2020, 09:44 PM   #148
No need to strip the paint. Just lightly sand to rough it up enough to take new paint.
Kaotic Lazagna (09-27-2020), shiumai (09-26-2020)
Old 09-27-2020, 04:00 AM   #149
Kaotic Lazagna
Drives: GR Corolla
I was going to fully disassemble everything and repaint it a different color.
What kind of paint should be used if sanding is used? Tamiya TS-line paint? Or automotive paint like Duplicolor? I'm assuming if I can use Tamiya, I wouldn't have to use a paint hardener/curer.
I should probably try practicing on one of my old Maisto models before ordering and spending over $250 on an AutoArt. lol
Old 09-27-2020, 04:51 AM   #150
JD001
JD001's Avatar
Drives: Subaru BRZ
Hi Weederr33, do you have any connections with East Africa? I note the giraffe in the background. I used to see them in households who had some connection with Kenya..
Old 09-27-2020, 08:42 AM   #151
Can use either a hobby paint or automotive touch up depending which has the colours you want. The tamiya paints are great and easy to work with.
Practicing is a good plan.
Old 09-27-2020, 08:43 AM   #152
weederr33
weederr33's Avatar
Nah. I'm just a man of class and world geography. Also they are kind of an inside joke.
JD001 (09-27-2020), Tcoat (09-27-2020)
Old 09-27-2020, 10:06 AM   #153
shiumai
shiumai's Avatar
I have not had a good experience with Duplicolor for models. The issue I had with metallic colors was that the metal flake in Duplicolor wasn't to 'scale'. It would look fine on a real car, but on a model it didn't look right - the flakes were too large. Solid colors should be fine, but I just stick to Tamiya or Testors for models.
Lots of great videos on YT about painting model cars.
The Following 2 Users Say Thank You to shiumai For This Useful Post:
Kaotic Lazagna (09-27-2020), Tcoat (09-27-2020)
Old 09-27-2020, 10:17 AM   #154
Tamyia makes a whole line of Model auto paints with metal flake that is almost to scale. They are lacquer so a bit harder to work with but they have most of the Subaru and Toyota colours.
shiumai (09-27-2020)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
