Old 06-26-2020, 05:10 PM   #141
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Thanks! I figured it out.
e30cabrio is offline   Reply With Quote
Old 06-27-2020, 04:01 AM   #142
Compelica
Compelica's Avatar
Drives: 86 GT
Anyone knows if there is a 'reboot' function on our headunits? I have a DDX918WS and once in a blue moon the Android Auto function freezes and I have to turn the car off and on to reboot the head unit. Obviously a bummer when this happens in the middle of a highway, we can't just stop anywhere...
My Android Auto is on the latest version, with the latest firmware on the Kenwood head unit.
Compelica is offline   Reply With Quote
Old 06-27-2020, 09:14 PM   #143
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
From the 919 manual:
Old 06-27-2020, 09:32 PM   #144
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks, but that merely turns off the screen and does not actually reboot the entire head unit... I'm looking to see if it's possible to power cycle - and subsequently show the Kenwood splash screen.
Old 07-05-2020, 03:23 AM   #145
Halo_2
Drives: 2014 MY15 86 GTS
New unit is Kenwood DDX920WDABS or DMX820WS which one should I get
Halo_2 is offline   Reply With Quote
Old 07-05-2020, 03:46 AM   #146
gpvecchi
gpvecchi's Avatar
DDX920WDABS
Old 08-29-2020, 03:42 AM   #147
Halo_2
Anyone know the what the 3.5mm jack is from the custom harness from carbon car system is for?
Also there was a green plug that doesn't get plugged into the harness and no spare connector for it, what's it for?
2014 MY15 86
Old 08-30-2020, 04:23 PM   #148
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
2014 MY15 86
3.5mm male jack or female plug? Just curious.
This is just a guess, but the 3.5mm could be for the steering wheel controls on some models or it's for the microphone.
Some connectors aren't used.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Halo_2 (08-31-2020)
Old 08-31-2020, 08:03 PM   #149
Halo_2
Got a answer for anyone else
Ignore the green plug thats factory GPS antenna.
3.5mm is steering controls
Old 11-04-2020, 02:19 AM   #150
zippee
Guest
Posts: n/a
Old thread I know but,
How did you figure out the backup camera solution without Carbon's harness?
Also, I'm in Canada, where could I get the current headunit? Seems like the ones that fit aren't North American...
Does anyone know which wire to tap for the speed sensor?
I looked at the wire harness and it seems it's pink/green at the ECU but I am not comfortable tapping it there.
Figured it & reverse out.
Houston we have backup camera!
I guess Carbon did me a favor blowing me off, I did 'er myself & saved $.
Old 11-04-2020, 04:24 AM   #151
Halo_2
My backup camera works fine no modded needed to the carbon harness
Old 11-04-2020, 05:54 PM   #152
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
There's definitely some wiring difference between the Australian and North American cars that carbon isn't aware of.
Both myself and many other people on this forum (Canada/USA) reported backup cam issues when using the carbon harness. Mine just didn't work at all. I'm not very wiring savvy so I took mine to a local shop, and they had to add the 6v/12v converter before it would work.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Halo_2 (11-05-2020)
Old 11-04-2020, 06:17 PM   #153
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
My issue was the reverse wire was loose. I have since replaced the OEM camera with a Kenwood that was P&P with the HU.
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 10:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 05:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
