Old 08-27-2020, 09:11 PM   #1
ScrubNubbyBRZ
Exhaust Re-tune - Turbo
Hi Guys,
I recently installed a Turbo Kit on my BRZ and got it tuned. I did not get the chance to have an aftermarket exhaust installed with the turbo due to financial restrictions at the time .
However, for future, will I need a re-tune if I installed aftermarket exhaust (overpipe, front pipe, catback exhaust) after the fact?
I know that a re-tune is recommended to get the most, but will it be safe to drive? Has anyone had any issues?
I tried to find answers in the forum but I only found this: https://www.ft86club.com/forums/show...exhaust+retune
Just wanted to make sure.
Thanks a bunch!
ScrubNubbyBRZ is offline   Reply With Quote
Old 08-27-2020, 09:14 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I wouldn't bother. A re-tune would just be to take advantage of the extra breathing room- it won't affect the tune negatively
Old 08-27-2020, 10:56 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
Only return for major things. Like new injectors, fuel pump etc.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 08-27-2020, 11:14 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
If you are custom E-tune minor revisions are 50-100$ not paying for an entire new complex tune. Is 50-100$ worth maybe 1-2% more optimized tune? Up to you.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
pallen (08-28-2020)
Old 08-28-2020, 01:29 AM   #5
ScrubNubbyBRZ
Thanks guys, much appreciated!
Just worried it might provide an issue with the current tune. Looks like it wont.
Old 08-28-2020, 03:09 AM   #6
jflogerzi
jflogerzi's Avatar
Monitor your afr and fuel trims. If they look out of wack then get an adjustment. If not don't worry bout it
2013 Series 10 FRS #553
Old 08-28-2020, 11:12 AM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by ScrubNubbyBRZ View Post
Hi Guys,
Thanks a bunch!
I would recommend a retune. You will be having less back pressure and possibly make more boost with the higher flowing exhaust (not tasing about major change, but some more).
Why chance it? given you are adding boost to a factory NA engine, best be safe.
Old 08-28-2020, 02:38 PM   #8
CSG Mike
CSG Mike's Avatar
If you're increasing flow, you're changing how the boost is delivered.
100% should get a retune, or at the bare minimum, evaluation.
Old 08-28-2020, 04:07 PM   #9
pallen
pallen's Avatar
Drives: 2017 Toyota 86
This. Talk to your previous tuner. If you're using ecutek, they will have access to the old tune and can just tweak it vs someone else having to start from scratch. They may charge a much lower rate to just make minor adjustments.
pallen is offline   Reply With Quote
exhaust, re-tune, turbo
OFT tune for JDL V2 Turbo kit?? Rekzer Software Tuning 10 09-25-2019 11:41 PM
Can i tune my BRZ with the OFT after i turbo it? Devin11498 Software Tuning 5 06-04-2018 01:25 AM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 10:04 PM
FRS/BRZ Turbo Tune teddydoggy Great Lakes 4 09-18-2015 12:17 AM
turbo tune dfw bjun Southwest 31 10-22-2014 01:10 PM
