Old 08-25-2020, 01:42 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Misaligned Hood Help?
Originally Posted by evomike View Post
his is pushed up, clear indicator of this is the air box no longer fitting to the upper tie bar.
You’re right, I see it now.
Old 08-25-2020, 02:21 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by Jesxse View Post
A couple more photos of the latch and along the side of the front support.
Yeah you got damage. See where the resonator next to the air box should be connected to the crossbeam? There's a crease there that shouldn't be.
You could try loosening and sliding the latch downwards, but I don't think there will be enough adjustment room as-is. Did you get a chance to look under the car for damage? You might need a bit more than an alignment to put it right again.
Adding pics of mine for comparison.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Jesxse (08-25-2020), NoHaveMSG (08-25-2020), soundman98 (08-25-2020)
Old 08-25-2020, 04:52 PM   #17
Jesxse
Drives: 2015 BRZ
I broke the air box thing off myself when I was trying to adjust the latch...
I’ll have to look at the comparison pictures when I get to a computer. Any suggestions on how to realign this? Is that cross beam replaceable? I’m at work with a different car so can’t check it this moment.
Jesxse is offline   Reply With Quote
Old 08-25-2020, 05:17 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The upper and vertical brace are. The lower looks like it is welded. I haven't had the car torn down this far, yet. Hopefully the lower cross member is not damaged.
The vertical center brace is separate, I don't know why it doesn't show that way in this diagram.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Jesxse (08-25-2020), Spuds (08-25-2020)
Old 08-25-2020, 06:30 PM   #19
Jesxse
Drives: 2015 BRZ
Thanks everyone this has been extremely helpful. I’ll be going over everything and probably taking it to an auto body shop for a quote if I can’t seem to get it straightened out. I really appreciate all the input!
The Following User Says Thank You to Jesxse For This Useful Post:
NoHaveMSG (08-26-2020)
FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) iceblaze Southern California 1 04-14-2019 03:50 PM
Steering wheel column misaligned? 1future Issues | Warranty | Recalls / TSB 17 01-10-2019 08:16 PM
Misaligned Hood Shady195 Issues | Warranty | Recalls / TSB 2 05-29-2015 12:43 AM
BRZ Sagging/Misaligned Bumper TSB 12-139-12 kayoh Issues | Warranty | Recalls / TSB 3 06-04-2014 03:08 PM
Perrin Catback - Misaligned Tips white_knight Engine, Exhaust, Transmission 4 01-18-2014 08:38 AM
