Old 08-23-2020, 05:41 PM   #72185
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I installed something completely on my own physically today, which felt pretty good other than a couple minor mishaps:
I'm not really a DIY-er but wanted to give it a shot, and I seem to have done a decent job.
Those are cool, but my normal hand position would cover it. I’d like to have a normal oil temp gauge since my innovate dual gauge is just a graph on the outside of my pressure gauge.
NoHaveMSG is offline
spike021 (08-23-2020)
Old 08-23-2020, 05:41 PM   #72186
I think you read that wrong.
Oh, I factored in my AARP, Military and Senior discounts -
humfrz is offline
Old 08-23-2020, 05:44 PM   #72187
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Those are cool, but my normal hand position would cover it..
100% true. My only complaint about mine.
Sapphireho is offline
NoHaveMSG (08-23-2020), spike021 (08-23-2020)
Old 08-23-2020, 06:37 PM   #72188
spike021
spike021's Avatar
Yeah. Actually drove with it installed for the first time earlier. I do have that issue as well. But I kinda figure I can shift my hand quickly enough to glance at it anyway.
Will need to drive more and experiment.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
Old 08-23-2020, 06:39 PM   #72189
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Random Thoughts - Part Deux
I usually only glance at my gauges on long straights so it’s not insurmountable. I’m out of room though so vent mount is my only other option.
Old 08-23-2020, 08:00 PM   #72190
soundman98
ProCrastinationConsultant
soundman98's Avatar
can do a scangauge ii that does similar. and you can mount the scangauge anywhere. it's about the size of a radio display.
i don't seem to have a pic, but i put mine in that cubby in front of the shifter, under the hvac-- with a little work, and some spray paint.
i'm currently monitoring intake air temp, water temp, oil temp, and battery voltage. i never got the trans temp codes to work despite trying every posted subaru/toyota variation.
soundman98 is offline
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (08-23-2020), spike021 (08-24-2020)
Old 08-23-2020, 08:06 PM   #72191
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
No room in front of the analog speedometer?
Spuds is offline
Old 08-23-2020, 09:08 PM   #72192
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Nope.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
p1l0t (08-23-2020), ScoobsMcGee (08-25-2020), spike021 (08-24-2020), Spuds (08-23-2020)
Old 08-23-2020, 09:28 PM   #72193
Spuds
The Dictater
Spuds's Avatar
Nope.
A-pillar?
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
p1l0t (08-23-2020)
Old 08-23-2020, 09:33 PM   #72194
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A-pillar?
I’m an asshole not a douchebag.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
MICHAEL450f (08-28-2020), ScoobsMcGee (08-25-2020), soundman98 (08-23-2020), spike021 (08-24-2020), Spuds (08-23-2020)
Old 08-23-2020, 09:44 PM   #72195
Spuds
The Dictater
Spuds's Avatar
Spuds is offline
Old 08-23-2020, 09:50 PM   #72196
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I had no idea the difference comes down to gauge placement. Learn something new everyday.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
NoHaveMSG (08-23-2020), p1l0t (08-23-2020), spike021 (08-24-2020)
Old 08-23-2020, 09:53 PM   #72197
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just one part of the “look”. Usually seen in conjunction with overly loud exhaust, huge flashy wheels with too much offset, and window cracked just enough for the vape to escape.
bcj (08-24-2020), p1l0t (08-23-2020), Sapphireho (08-23-2020), spike021 (08-24-2020)
Old 08-24-2020, 01:40 AM   #72198
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is cool, haven't seen one of them before. I would want to put it somewhere the info is right in my face. Maybe 3D print an enclosure to mount it on top of the dash or the top section of the cluster.
I have my switch panel for my trac box mounted in that cubby already.
