Old 08-22-2020, 06:28 PM   #1
AlexBRZ2
Drives: 2020 BRZ Blue Pearl
Greddy Supreme SP causing CEL?
Hi everyone,
I was looking into getting a cat back exhaust soon and really like the Greddy Supreme SP catback. I want a rumble but not something crazy loud and not too much drone. The only mod I have so far is a UEL ftspeedfactory header.
My concern/question: I found a YouTube video (link:
) and they have the same header as me as well as the catback system I want. Only difference is that they have a Motiv catted front pipe, which I plan to keep stock. They said they got a CEL about 7k miles after install and was able to remove it with an OFT. I don’t believe I would have a check engine light but I am hoping to not have to get an OFT at this time if I wanted this exhaust. Does anyone have any kind of insight in if I would have to expect a CEL if I got thuan exhaust? I was thinking as long as I kept cats on, I wouldn’t have to really worry about a CEL with what I am doing.
Thanks in advance!
AlexBRZ2 is offline   Reply With Quote
Old 08-22-2020, 06:35 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
"The only mod I have so far is a UEL ftspeedfactory header." is it catted?
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
AlexBRZ2 (08-22-2020), Lightened (08-22-2020)
Old 08-22-2020, 06:50 PM   #3
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
No - aftermarket exhausts alone do not cause the Check Engine Light (CEL) to turn on.
An aftermarket header without a Catalytic Converter may cause the CEL to come on.
Lightened is offline   Reply With Quote
The Following User Says Thank You to Lightened For This Useful Post:
Old 08-22-2020, 06:55 PM   #4
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
Originally Posted by AlexBRZ2 View Post
Hi everyone,
Thanks in advance!
Did you tune your car after installing the headers?
Toyota 86 in the building!
Gamace is offline   Reply With Quote
The Following User Says Thank You to Gamace For This Useful Post:
Old 08-22-2020, 07:10 PM   #5
AlexBRZ2
Realized a couple more details I may have left out, sorry. My header isn’t catted and I did not tune it after. I know ftspeedfactory said that no tune was needed. I am kind of hoping to avoid tuning my car until the factory warranty lapses in the instance something wild happens to my engine and the warranty will cover it and the dealership won’t try to blame it on the tune. That’s the main reason why I am hoping a tune isn’t necessary for the Greddy Supreme SP catback.
I am planning on keeping cats on my exhaust as well.
Old 08-22-2020, 07:20 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
By "no tune needed" they meant it won't explode, but it is unequivocally the cause of your check engine light
Old 08-22-2020, 07:28 PM   #7
AlexBRZ2
I don’t have check engine light. My car is running perfectly. I just want to make sure I won’t need to tune my care if I decide to add the catback exhaust.
The check engine light that I brought up was because someone who posted a YouTube video had a CEL with the same header, catback that I want, but a Motiv catted front pipe. I plan to keep the stock front pipe.
The Following User Says Thank You to AlexBRZ2 For This Useful Post:
DarkPira7e (08-22-2020)
Old 08-22-2020, 07:31 PM   #8
DarkPira7e
DarkPira7e's Avatar
Sorry, I misunderstood! No, the catback won't change a thing
Old 08-22-2020, 07:45 PM   #9
AlexBRZ2
No worries, thank you!
Old 08-23-2020, 07:14 AM   #10
Joveen
Joveen's Avatar
Drives: Bone stock
Seems you just got into the modding game. A catback cannot and will not cause CEL. The header without a tune for sure will. Not sure why you would get an aftermarket header and not tune the car. With the oft you can always flash back to stock on the fly. Just a tune and forget the warranty that you might not even use.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 08-23-2020, 05:47 PM   #11
AlexBRZ2
Yeah, I’m definitely new to the modding game. I just cannot come to tune the car, void the warranty, and then think to myself if something wrong happens, have the thought that the dealer won’t help fix the issue by blaming it on the tune.
If the car has been running fine without a tune, would the tune only be necessary in order to increase the performance gains or would it potentially prevent something from happening that would have been a result of the header? Also, if I flash it back to stock, won’t the dealer see a change?
Old 08-23-2020, 06:20 PM   #12
alphasaur
friendly
Drives: 17' 86
I mean if they dealership really wanted to be ****heads and something happens to your engine they can likely tell that you swapped the header. Swapping the header can effect your AFR which can cause things to break. Is the likelihood high? No.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
AlexBRZ2 (08-23-2020)
Old 08-23-2020, 08:19 PM   #13
Joveen
Joveen's Avatar
Drives: Bone stock
Why buy the header and not get the most out of it?
The Following User Says Thank You to Joveen For This Useful Post:
alphasaur (08-23-2020)
Old 08-23-2020, 08:30 PM   #14
AlexBRZ2
My thought process was to get a bit of a gain now and then when the warranty is gone, tune it to get the remainder of the reliable potential out of it.
WTB- Greddy Supreme SP equachie Canada Classifieds 0 12-31-2019 07:40 AM
Greddy supreme sp vs. Perrin 2.5 Aluma007 Engine, Exhaust, Transmission 0 01-03-2018 04:57 PM
Greddy Supreme SP Senoko Engine, Exhaust, Transmission 20 07-14-2016 04:43 PM
GREDDY supreme sp phongtphan21 Engine, Exhaust, Transmission 29 02-19-2016 04:22 PM
New from JRP: Greddy Supreme Stav Canada Classifieds 14 10-01-2014 04:34 PM
