Old 08-21-2020, 05:14 PM   #1
DatChinchilla
DatChinchilla's Avatar
Drives: Turbocharged 2015 Subaru BRZ
Push Start Acting Weird.
So I just installed a new turbo with some gauges on my 2015 auto BRZ and now the car won't start. This happened today right after I installed my gauges. Whenever I press the start button, regardless of whether or not the brake pedal is pressed, the gauge cluster acts as if the car is being turned on even though it isn't. This happens with the brake pushed down as well. The car also beeps thinking the door is open when in reality, the door is shut. The infotainment system doesn't even turn on anymore. I've checked the fuses and none of them seem to be blown. This all happened today after I installed the gauges, the car was working great before with the turbo installed. Any suggestions?
Last edited by DatChinchilla; 08-21-2020 at 05:16 PM. Reason: Added more symptoms.
DatChinchilla is offline   Reply With Quote
Old 08-21-2020, 05:33 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Will it start if you disconnect the gauges? What gauges did you install?
Old 08-21-2020, 05:43 PM   #3
DatChinchilla
Interesting. So an additional problem I had was my headlight stock literally wouldn't work and disconnecting the power to gauges seemed to fix my door beeping and my headlights. However, my engine still didn't turn on. Going into accessory mode seems to bug my gauge cluster into thinking my car is turning on.
Old 08-21-2020, 06:16 PM   #4
dragoontwo
dragoontwo's Avatar
Sounds like some sort of installation issue.
Old 08-21-2020, 11:27 PM   #5
DatChinchilla
I'm an idiot. Apparently the battery was dead. Guessing this happened since I had 2 add-a-fuses with 4 15 amp fuses for the gauges and that was just too much. Going to switch some fuses with lower amps.
The Following User Says Thank You to DatChinchilla For This Useful Post:
humfrz (08-22-2020)
Old 08-21-2020, 11:59 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
fuses don't work that way...
Old 08-22-2020, 01:06 AM   #7
Welp, like ol @soundman98 said, "fuses don't work that way".
If you have 4 15 amp fuses in your dash light circuit, you might as wire them direct for all the good they would do.
I reckon a 10 amp fuse should regulate all of them OK.
I'm thinking you may consider taking your car into a auto electrical shop and have them straighten it out.
Also, you should find out what drained the battery and fix that situation.
Did you hear about the ol boy from Washington that was out hunting with his buddy in his old pickup truck. It was getting dark and the headlights wouldn't work. His buddy suggested he check the fuse. He did, found out it blew. His buddy suggested he insert a .22 shell in the fuse slot, so he did.
About 2 miles down the road, a shot rang out and the .22 round hit his buddy in the leg. His buddy shouted out - I meant for you to put a spent shell casing in the fuse slot!
soundman98 (08-22-2020)
Old 08-22-2020, 08:07 AM   #8
DatChinchilla
Haha! Thanks for the hospitality! Yeah I was running the gauges and and all the electrical systems in my car for around an hour which is probably why. Well, that and the fact she's been on jack stands for the past week and a half. I emailed Glowshift whom I purchased the gauges from and they recommended a 5 amp fuse and a 15 for the add-a-fuse slots. Odd how that wasn't on the instructions so I didn't know.
humfrz (08-22-2020)
Old 08-22-2020, 08:16 AM   #9
DatChinchilla
Yeah, I'm really new to electrical stuff so I really don't know haha, thanks though! So I'm pretty sure my battery just simply died from being left untouched for almost a couple weeks along with the fact my car was on accessory power for over an hour.
Old 08-22-2020, 10:45 AM   #10
soundman98
soundman98's Avatar
fuses are a limiting device. think of it like a cop with a radar gun. if the speed limit is 15mph, there is nothing limiting you from going any speed from 0-15mph, but anything over that limit, the cop/fuse will put a stop to the 'fun'.
typically, one should fuse a device for just over what it needs. this is done so that there is an allowable margin of error in power draw(if it draws a little more than it's supposed to, NBD), but if something goes wrong and the device starts drawing significantly more power, the fuse is there to stop it before the device can start on fire and cause more significant problems.
humfrz (08-22-2020)
Old 08-22-2020, 03:50 PM   #11
Well, they probably were, but the print was soo small you couldn't read it with the unaided eye. -
Old 08-23-2020, 12:03 PM   #12
Grady
Grady's Avatar
Yes try some 1 amp fuses they use a lot less. If your battery still goes dead just keep putting lower ones in. Try 1/2 or see if you can find 1/4 amp. Soon your battery will never go dead!
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Stock 2014 is headunit acting weird Thehermdawg Electronics | Audio | NAV | Infotainment 0 05-26-2015 06:35 PM
Engine is acting weird natesparxxx Engine, Exhaust, Transmission 31 09-05-2014 12:30 PM
OFT - First E85 tank in my car. Acting weird. SloS14 Software Tuning 37 06-01-2014 11:37 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
