Old 08-17-2020, 01:24 AM   #43
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by BlOody_BoOger View Post
Yea I'm on e85 and I think the problem with running in parallel is the surge. It's one of the things I spoke about with the developers of the toqueamp. They suggested that while the parallel set up does produce more air ultimately it's too much air for a 2 liter Engine, that a parallel set is best suited for 3.0 liter and above. So I ended up doing compound. Yes the spool up is quick and the tq is crazy downlow. Hopefully once it's all done I can do a comparison video of a buddy running a jrsc low boost pulley. Should be fair since we're both on e85 and both making peak 7psi only difference is I hit max boost at 3500rpm and taper down to 2psi redline and he hits max psi at 7000rpm.
With E85, I bet combustion temperatures can be cooled enough at 8 psi to not need an intercooler, but I would take more opinions.
Do that race!
Old 08-17-2020, 01:00 PM   #44
pallen
pallen's Avatar
Drives: 2017 Toyota 86
And you dont have parasitic loss...
pallen is offline   Reply With Quote
Old 08-17-2020, 01:16 PM   #45
86TOYO2k17
Drives: 2017 toyota 86
Film it sounds like a cool race.
I bet from a dig you pull on him pretty hard (assuming you have traction) and then he slowly reels you in and passes you around 100mph and pulls away. From a 40 roll you’ll get the jump but he’ll pass you sooner around 60-70mph and then keep pulling away on you.
Got any POV speedo 0-60+ pulls?
Old 08-17-2020, 02:27 PM   #46
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Not currently on this set up I do have some with a single phantom
BlOody_BoOger is offline   Reply With Quote
Old 08-17-2020, 02:28 PM   #47
BlOody_BoOger
The Following 2 Users Say Thank You to BlOody_BoOger For This Useful Post:
86TOYO2k17 (08-17-2020), airrick (08-18-2020)
Old 08-18-2020, 03:20 PM   #48
airrick
Drives: TRD R.S. 1.0 FRS
where is this at? this is totally sacramento. flat farmlands, no many twisty roads nearby. I usually drive around the sac river on route 160. would love to know where this is at.
airrick is offline   Reply With Quote
Old 08-18-2020, 04:58 PM   #49
bfrank1972
Drives: 2013 FR-S Argento
Definitely would be interested to see as well. I remember somewhere on here a video of an original Phantom kit, think it might have been a 1.5 kit but not sure, vs a vortech sc. If I remember, the phantom got the jump from a standing start but the vortech caught up and passed pretty quickly. I would like to see how this new setup compares.
Sent from my SM-G965U using Tapatalk
Old 08-19-2020, 12:35 AM   #50
dholloway543
Software Hobbiest
Drives: 2015 FRS
You could have the filter sit behind the fog light bezel and just put like a half circle plastic on the top end of the filter to make it look like there's a fog light there.
That is my first idea but wouldn't it scoop up water with that placement
dholloway543 is offline   Reply With Quote
Old 08-19-2020, 01:08 AM   #51
86TOYO2k17
Originally Posted by dholloway543 View Post
Sbd500x
14psi max
130f or 55c at worst
I want to pull air from out of the engine bay but idk how to do it without being obvious because I'm in California
https://datazap.me/u/dholloway543/ec...o=39&mark=2220
Fog light is an option, no cop is going to have any clue. Remove windshield washer reservoir and replace/relocate with chase bays mini reservoir to clear out all the space. Remove both fog lights so it’s symmetrical and place grille mesh guard inside to cover the hole to block big rocks/bebris and make it look oem but still allow airflow. With the mesh and location of foglight bezel no-one will have any idea what’s going on behind it. Then either run a longer pipe down into that area behind new opening can even now fit a much larger filter and now the filter is out of engine bay and getting cool air or You could get an air duct behind the fog light bezel opening and run a large hose from the air duct to your current intake location and build an intake filter box for the hose to go to. 1st option will have better air, 2nd option might look more stealth and have less filter exposure to the elements.
Old 08-19-2020, 07:26 AM   #52
WNDSRFR
Drives: FR-S,GTI
Try doing a run shifting at 5000 rpm. It seems like the most power is in the 3-5k rpm range. At least that's what I have discovered. It seems like the torque dip occurs at about 5k with the ESC.
Old 08-19-2020, 03:26 PM   #53
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
My IATs run about 21 degrees over ambient on the Edelbrock supercharger.
B T is offline   Reply With Quote
Old 08-23-2020, 02:59 PM   #54
BlOody_BoOger
So quick update.....I did a few things to try and bring temps down. Now while I really didn't make my charge temps lower I did notice operating temps went down roughly 5 degrees. So before during normal driving after driving around town temps would sit right around 130 (stoplight) at idle then while cruising go down to about 115 and under boost go back up to 120. This time around in similar 95-100 degree weather I noticed idle temps were around 125 would drop to around 110 and under boost go up to 115.
In 75 degree weather. Idle temps sat around 105 drop to 95 under cruising and back up to 109 under boost. Now in comparison with other conventional boost applications. 120 charge temps seems to be normal and for me on hot summer days seems to be my max given without an intercooler. So it's safe to safe I'm good to run without one. So a few of the things I did was wrap the pipes with gold heat wrap. Added a filter heat shield to the in bay filter. Added a heatsink on the maf sensor. And installed these fin pipes in place of where an intercooler would sit. those pipes act almost like a large heatsink.
Old 10-07-2020, 07:47 PM   #55
colin88
Drives: 2013 Toyota 86
Just curious how does your fi system. Work
Sent from my SM-N975F using Tapatalk
colin88 is offline   Reply With Quote
Old 10-07-2020, 07:57 PM   #56
BlOody_BoOger
It's electric, each supercharger has its own control box and set of 24v batteries. Under the gas pedal there is manual switch that's connected to the control box when I hit the throttle and hit the switch the superchargers come on simultaneously giving me up to 7.5psi of boost.
Sent from my IN2017 using Tapatalk
OFT FORCED INDUCTION lilred Software Tuning 6 03-13-2019 06:10 AM
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
