Old 08-12-2020, 02:09 PM   #1
1234eher
Drives: 2014 FRS
Cool Engine Flush and Fuel system cleaner. Use or not to use
Has anyone ever had to use them? I know that there are detergents in the oil and gas, contemplating using it as cheap insurance. Any opinions would be great! thank you
1234eher is offline   Reply With Quote
Old 08-12-2020, 02:35 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Insurance against what? What are you afraid is in the engine that shouldn't be?
You need to know what problem you're trying to solve before you start trying to fix it, it'll help a lot in guiding yourself towards the right answer
Old 08-12-2020, 06:03 PM   #3
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Use good gasoline and change you oil often. No need for this BS.
Old 08-13-2020, 01:30 PM   #4
Not necessary nor recommended.
Old 08-17-2020, 10:21 AM   #5
Ernest72
No need, even ones that increase mpg like Lucas fuel treatment (I have tested it and can get 1-2 mpg more), the added cost evens out the with the added mileage. So no real savings.
Old 08-17-2020, 10:40 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
+1 not needed
Old 08-18-2020, 05:26 PM   #7
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Same here, never used those on any of my vehicles. I did however use the odd seafoam treatment once in a while when some of my cars started to show signs of age just to restore gas mileage and clean up internals.
SUSPECT_BRZ is offline   Reply With Quote
Old 08-18-2020, 05:36 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I put a couple teaspoons of Seafoam in the tank of my 2stroke weed whacker, but only the first time I start it up for the season.
Works for carbureted engines. Mostly useless for fuel injection.
Old 08-18-2020, 07:54 PM   #9
Halo_2
Drives: 2014 MY15 86 GTS
I’ve used oil flush just because the dealership I bought it off used shit oil.
Halo_2 is offline   Reply With Quote
flush, fuel system, gas, maintanence, oil
Does running e85 keep the engine cleaner? pcguru2000 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 08-18-2018 12:36 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Lucas Fuel Injector Cleaner Discoloration Eski Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 02-03-2015 12:57 PM
Crickets be gone! lucas oil deep clean fuel system cleaner SliverBrz Issues | Warranty | Recalls / TSB 15 09-23-2013 08:22 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
