Old 08-17-2020, 10:18 PM   #1
padillaricardo48
padillaricardo48's Avatar
Engine Failure! 2013 Scion Frs. Recall was made
I went to pick up my car at the dealership they didn't put the oil pan and oil tube back because they found metal debree in the pan so they refused to repair the engine, and i came across this on the oil tube silicone on the oil tube so what should i do?? I left the car at the dealership because I cant move it , my batter was dead witch idk why its brand new. But what should i do ???? Fight for it???? Make them pay for something I didn't do and caused engine failure, note: that the dealership what to charge me 10k
Sent from my SM-N975U1 using Tapatalk
padillaricardo48 is offline   Reply With Quote
The Following User Says Thank You to padillaricardo48 For This Useful Post:
humfrz (08-19-2020)
Old 08-17-2020, 11:27 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
how about some more info leading up to everything? mileage? service history? mileage after recall?
padillaricardo48 (08-18-2020)
Old 08-17-2020, 11:38 PM   #3
padillaricardo48
123k miles on the recall and after the recall is 138k and history engine was perfectly fine dealership told me i had basically a new engine recall was made on april of last year didnt use it for 3 months due to family emergency. Warranty was 1 year or 12k miles witch ever comes first
Old 08-17-2020, 11:40 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'd say I'm surprised, but that'd be a lie.
Fight them, this is a well documented issue. Unless your engine waited year and 16,000 miles to go, I'd battle
Edit: you went quite a long while before something happened, that'll be tough to prove. I'd still bring the fight to them.
Old 08-17-2020, 11:43 PM   #5
padillaricardo48
Well they told me that it was 1 year or 12k miles witch ever comes first but yet they refused to take full responsibility so I called again so make another claim.
Old 08-17-2020, 11:59 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Irvine Toyota ruined my car and are unresponsive. I’m having a new motor installed at a Highly reputable shop. You can buy a used engine for 4K and have it installed for around 3k. I’m using a new block from IAG that’s rated for 550hp and all the trimmings to build a bulletproof motor. 11k.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Old 08-18-2020, 01:40 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They charge 3k to do the swap
I can do it in about 8 hours without a lift or a normal engine hoist. WTF.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
e1_griego (08-18-2020), mswbrz (08-19-2020), padillaricardo48 (08-18-2020)
Old 08-18-2020, 02:33 PM   #8
If I read this right, you had the repair done in 04/2019 at 123,000 miles.
Your engine failed in 08/2020 at 138,000 miles.
So, by either measure you are out of warranty unfortunately. I doubt they will repair it for you at no cost unless you can prove negligence and they do it to avoid a court case. Bringing in a factory rep might help, but probably not. It won't cost you anything but time.
Old 08-18-2020, 02:48 PM   #9
padillaricardo48
My car failed on 6/11/2020 toyota ad my car for all this time and they didn't mention on the invoice that silicone was involved they just said metal debree
Dadhawk (08-18-2020)
Old 08-18-2020, 03:14 PM   #10
Unfortunately still after the warranty period, it seems. I'm sorry @padillaricardo48 that sucks. I know I'd be pissed to no end.
Old 08-18-2020, 03:17 PM   #11
TommyW
TommyW's Avatar
For new short block. Used Long block is half that
NoHaveMSG (08-18-2020)
Old 08-18-2020, 03:22 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oh that makes way more sense.
Old 08-18-2020, 09:55 PM   #13
padillaricardo48
I went to the dealership with the service manager and I was waiting for almost 4 hours and he just left and he knew I was gonna talk to him like what kind of customer service is that.... like how is our fault if rtv gets trapped in the oil tube ?
Old 08-19-2020, 12:41 AM   #14
I'm confused. When in this story did they find the metal in the oil pan? Why was the car taken into the dealership when they took it apart and found metal shavings?
