Old 08-15-2020, 02:56 AM   #1
jiffyjhn
Drives: White FR-S kosei k4r 17x8
Mis shift 6th to 3rd
I was driving today on the highway and cruising in 6th. Wanted to overtake a car in front and I rev matched to go to 5th but misshifted from 6th to 3rd. Not sure how fast I was going but revs went up to 6000 before I reacted and pressed the clutch again. I regularly take the car up to those rpms on canyon drives, and as I understand this is no different? I didn’t hear any noise during the mishift other than engine revving higher, car still pulls strong after. Anything to worry about? Wasn’t worried at the time but after reading some forums posts about misshifting starting to get a little paranoid.
Thanks.
jiffyjhn is offline   Reply With Quote
Old 08-15-2020, 03:21 AM   #2
gg1978
Drives: 2016 Subaru BRZ Limited Ice Silver
As long as the Tach didn't go swinging by the redline when it happened, i would expect your engine to be fine.. Not the greatest thing for the clutch, but on the balance about the best way for a misshift to happen.
gg1978 is offline   Reply With Quote
Old 08-15-2020, 08:08 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I in few cases even intentionally downshift from 6th to 3rd for very fastest acceleration for overtake on highway (the faster the acceleration, the shorter the overtake time, the safer overtake is due spending less time in opposite lane and more time/distance to opposite traffic left to return to own lane).
As gg1978 wrote, if it hasn't revved past redline, no issue, it's not what's called "money shift" (when you already had revved out till redline previous gear and instead of upshift misshift down). If one rev-matches, there is not even extra load/wear on clutch & synchros. Of course, if you had not just cruised normally in top gear, but had driven by speeding a lot, and with high enough rpms in previous gear, so that 2 or 3 gears lower downshift would make it overrev too high, then issues may pop up, including drastic ones like broken engine. But that's not your case, and at most you had slight one-time extra wear on synchros, reduced though by partial revmatch (for 5th), so just forget about/ignore, nothing to be paranoid of.
churchx is online now   Reply With Quote
Old 08-15-2020, 11:51 AM   #4
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
what's 6th? 4th is good to 108.
thomasmryan is offline   Reply With Quote
Old 08-15-2020, 02:11 PM   #5
milanojess
milanojess's Avatar
Drives: 2013 FRS
Yup as long as you are inside rpm range, you are within normal parameters.
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 08-15-2020, 03:47 PM   #6
Thanks.
Welcome to our forum -
First off, don't do that no more -
I reckon if your car is still running OK, you are OK.
Old 08-15-2020, 05:03 PM   #7
jiffyjhn
Ok that’s what I figured. Thanks for clarifying. The reason I was worried was because I did not rev Match for 3rd but for 5th. If I intentionally go from 6 to 3rd I would give a much bigger rev match. So like u said I partially rev matched. The 3rd gear in a 13’ I think goes to 82 mph or something like that and I’m pretty sure I was going slower than that so I couldn’t have hit redline even if I let out the clutch completely. Like u said I likely wear the synchro or clutch slightly, but that’s like having to brake hard and putting a bit extra wear on pad/ rotors. My concern was for the engine and the force put on it from rapid climb in revs from the momentum of the car as it felt quite violent. But the concensus seems to be that if I didn’t hit the redline it’s ok. I feel better now.
This is the first time I’ve done this in 15 years of driving manual. Felt super dumb when I did it
Old 08-15-2020, 05:54 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Of course it will feel violent, as wheels via transmission/gearbox need to quickly spin up engine few K rpms more, which takes quite some energy. Less of issue on tarmac with good grip in straight line, more of issue if grip is limited, eg. in rain or in winter or mid quickly taken curve on track, where such sudden shock to driveline/wheels may result in rear loosing grip. That's why revmatch also is among handling skills worth learning, and it's pleasant to hear that you are using of (unlike majority, who just rely on synchros doing job and at most are able only let out clutch longer).
Old 08-15-2020, 05:58 PM   #9
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Skipping gears when downshifting is not a good idea.
TommyW is offline   Reply With Quote
Old 08-15-2020, 07:17 PM   #10
jiffyjhn
Yup I always rev match on downshifts. It just feels wrong not doing that when the car jerks. Not to mention the shift will be slow.
However that’s not the way I was taught by the instructor when I learned driving manual in my teens. The way I was taught was: downshift then apply throttle slowly while letting clutch out slowly. Hopefully instructors are giving proper instructions these days to new drivers.
Old 08-15-2020, 07:36 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Driving instructors often give simplified instructions that may still somewhat work but require less time to learn and need less attention to dedicate when performing. After all, newbie learner has many other things to pay attention to and often suck at multitasking. The simpler driving methods, the more attention can be dedicated for road situational awareness and reading signs, and less what to mess up with and start panic about. So no throttle blipping, dual clutching, heal & toe downshifts, treshold and left foot braking, countersteering, clutchless shifts, flat foot shifting, clutch kicks and so on . Newbie already spent some time to get at least minimal initial muscle memory to start driving with hopefully not stalling. It seems understandable why instructor may have decided to reuse that tought clutchwork for other shifts too.
Old 08-15-2020, 11:07 PM   #12
Decep
Drives: 2013 FR-S Series 10
I did the same thing once but caught it pretty quick with the clutch. No damage done.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 08-17-2020, 08:46 AM   #13
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
It certainly isn't bad in any way if you know what you are doing.
Dzmitry is offline   Reply With Quote
Old 08-17-2020, 10:44 AM   #14
TommyW
TommyW's Avatar
It isn't bad until it is. On the street if you're very careful it can be ok however in a more track oriented situation Heel toe and rev matching, no.
FS: Shift Solutions weighted shift knob in Candy Gold - Sold! Ohio Enthusiast Interior Parts (Incl. Lighting) 2 07-22-2020 07:08 PM
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-08-2017 11:51 PM
SOLD: Whiteline Positive Shift Kit Bushing, Moddiction Shift Knob immaculate Transmission and Driveline 4 12-30-2016 06:52 PM
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
