Old 08-12-2020, 04:37 PM   #1
85258
Drives: 2013 FRS
720 Form GTF1 Wheels, stock lug nuts or tuner style?
Looking at buying 720 Form GTF1 17x8 et35 wheels.
1010tire.com cant tell me if the stock lugnuts will work. Anyone with a set that can chime in?
85258 is offline   Reply With Quote
Old 08-12-2020, 06:07 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
I had GTF1 and eventually switched to GTF2.
They do require tuner nuts.
Old 08-14-2020, 09:16 PM   #3
85258
Drives: 2013 FRS
Thanks.
Old 08-15-2020, 06:40 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
as "tuner nuts" usually are referred 60deg conical seat lugnuts. Stock lugnuts of twins also are 60dg conical seat ones. I don't know for sure what seat your wheels have though. Then again, most aftermarket wheels have such lugnut seat shape. In most cases one may need aftermarket lugnuts (eg. longer ones, or open-ended ones), if one has installed extended length wheel studs to enable usage of thicker slip-on wheel spacers.
why? (08-15-2020)
Old 08-15-2020, 08:56 AM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Stock lugs nuts are tuner style, they’ll work.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
why? (08-15-2020)
Old 08-15-2020, 11:28 AM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Almost all aftermarket wheels the stock lug nuts work. Every so often an aftermarket wheel has smaller openings for the lugs, which is annoying. I ran in to this on some used Moteki wheels I bought.
why? is offline   Reply With Quote
720 Form GTF1 BBK fitment?? Jordanwolf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-31-2018 09:51 PM
f/s 720 Form GTF1 17x8 +35 w/PSS 215-45 wbradley Canada Classifieds 22 05-14-2018 07:34 PM
720 Form GTF1 Stock Height - Wheels are on!! Jordanwolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 04-23-2018 06:50 PM
72o form GTF1 quality dostoyevsky Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-08-2018 01:08 PM
