Old 08-13-2020, 06:37 PM   #71
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Dzmitry View Post
per say
per se
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Dzmitry (08-14-2020), Spuds (08-13-2020)
Old 08-13-2020, 06:42 PM   #72
Lantanafrs2
Drives: 2013 frs red
The project didn't get shelved. That's a good thing
Lantanafrs2 is online now
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
mike2100 (08-13-2020), mrg666 (08-14-2020)
Old 08-13-2020, 07:08 PM   #73
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
Yep, definitely looking like it just has the current car's ac condenser behind the grille, no intercooler. However, keep in mind that sidemount intercoolers are a thing too, the Nissan S13,S14, and ER33 all used sidemounts, and it could explain the need for the functional side vents, so I wouldn't completely rule out forced induction quite yet.
That being said, if it is turbocharged, I'd love for it to be the 3-cylinder from the GR Yaris.
BRZ tS 160/500
yurikaze is offline
The Following 2 Users Say Thank You to yurikaze For This Useful Post:
gymratter (08-16-2020), mazeroni (08-13-2020)
Old 08-13-2020, 07:25 PM   #74
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
I'm guessing the tail lights will be a similar design to the GR Yaris'
"Why must everything that is broken be fixed?"
GhostRai is offline
The Following 2 Users Say Thank You to GhostRai For This Useful Post:
Bristecom (08-13-2020), gymratter (08-16-2020)
Old 08-13-2020, 07:31 PM   #75
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
First clear look at GR86 / BRZ prototype during testing
I would. Those intakes aren’t nearly big enough to feed a side mount, and they’re too outboard. They simply feed air into the wheel well, and the fender vent lets it out. It reduces profile drag by modifying the boundary layer flow.
Yoshoobaroo is offline
The Following 7 Users Say Thank You to Yoshoobaroo For This Useful Post:
Bristecom (08-13-2020), Lightened (08-13-2020), mazeroni (08-13-2020), NaturallyAspirated (08-13-2020), Ohio Enthusiast (08-13-2020), Ryephile (08-13-2020), Spuds (08-13-2020)
Old 08-13-2020, 07:54 PM   #76
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Veloist View Post
Not really a pro on tires but do those look like Michelin Pilot Sport 4's?
If those are then it looks like the whole platform is moving more toward what the BRZ tS is all about.
Yes, those are definitely Michelin Pilot Sport 4S tires. And they appear to be 225/40/18, which will enhance the comfort/stability over bumps and give it more grip while still being agile. With the increase in torque from a presumably 2.4 liter engine, they could use a slightly taller and wider tire and still get it to slide a bit. I have the PS4S in stock size on my BRZ and can still get it to slide when I want but it has plenty of grip in the dry or wet so it's a very good fit for the car in my opinion.
It seems this car is very similar to the current models. However, it does look just a bit larger this time, possibly to compensate for a turbo model. However, there's no way this particular model has a turbo. There would be a cutout for the intercooler on the hood if it was top mounted or it would be more obvious in the front. But judging from the size of that opening, they may be considering a front mount intercooler in the future. They would also likely use bigger rear tires as a performance 2.4L turbo in a light car would be a beast, even with good tires (Porsche Cayman territory).
I hope they make a proper STI turbo model this time. I still have mixed feelings about turbos but I do kind of miss that mid range torque and noise that turbos make. But the 2.4L will likely address that torque dip and make the engine feel a little more inline with other performance cars.
Toyota + Subaru =
Bristecom is offline
Old 08-13-2020, 07:59 PM   #77
mike2100
mike2100's Avatar
Drives: 23 BRZ
Could have a top mount intercooler. Fed via scoop like the other FA24DIT vehicles (Ascent, Outback). Would require a taller hood...which some of you have pointed out looks like it got taller.
The hood would also have to be taller because the engine would need to sit a little higher than 1st gen, because of the low mount turbo.
My bet is still FA24 N/A with 240hp and 180 ft-lb.
My hope is for quality tires to tame the unenlightened YouTube reviewers.
mike2100 is offline
Old 08-13-2020, 08:00 PM   #78
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I also noticed the wider tires.
I think the goal of the second generation is “a better handing car.”
Veloist is offline
Old 08-13-2020, 08:02 PM   #79
mike2100
mike2100's Avatar
Drives: 23 BRZ
Scoop not required for TMIC. See Outback XT, Ascent, and previous generation Forester XT
mike2100 is offline
Old 08-13-2020, 08:11 PM   #80
Bristecom
Bristecom's Avatar
Those cars still have scoops but they're just integrated into the front air dam and run under the hood. On a car like this with a low hood, I would think it'd still need an opening unless they raise the air dam to ridiculously high levels.
Toyota + Subaru =
Old 08-13-2020, 08:39 PM   #81
Veloist
Veloist's Avatar
That’s right here is the FA24 in the Outback. A setup like this on the twins would add weight to the hood and wouldn’t be the most efficient in terms of air flow.
Veloist is offline
The Following 4 Users Say Thank You to Veloist For This Useful Post:
Bristecom (08-13-2020), gymratter (08-16-2020), mrg666 (08-14-2020), Spuds (08-13-2020)
Old 08-13-2020, 08:39 PM   #82
Lantanafrs2
If it has 217 wheel horsepower it will be much quicker than the current gen car. All depends on where they're measuring output
Old 08-13-2020, 08:48 PM   #83
Yoshoobaroo
TRACKBREAD
I think it’ll be ~217 at the crank. Manufacturers never reference WHP. I do think we will get much more torque though.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Lantanafrs2 (08-13-2020), NoHaveMSG (08-13-2020), WildCard600 (08-13-2020)
Old 08-13-2020, 09:09 PM   #84
surfwaxsmitty
Drives: '14 BRZ 6MT
I think this is gonna look much better than we are feeling right now. Front wheel bulges drawn all the way down to the front. Tail lights draw farther up the side of the car make for a nice rounder shape - feels a bit merc GT coupe with some m coupe, and with connected reflector which is on a lot of great cars, 911, FD.. The side mirrors rounder more elegant, and the side looks pretty decent overall. I like that lower angle on the rear side window.
If it performs better, retains its driver feel, and has a stronger engine we're in good shape.
surfwaxsmitty is offline
The Following 3 Users Say Thank You to surfwaxsmitty For This Useful Post:
mrg666 (08-14-2020), StE92ve (08-14-2020), Yoshoobaroo (08-13-2020)
(GR86) Second Generation FR-S/BRZ insider info... ThaBigUnit GR86 General Topics (2nd Gen 2022+ Toyota 86) 2589 04-05-2021 08:53 PM
Video: Toyota GR86 SPIED for the First Time! gymratter GR86 General Topics (2nd Gen 2022+ Toyota 86) 567 01-25-2021 09:04 AM
