Old 08-12-2020, 01:26 PM   #267
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Originally Posted by mazeroni View Post
There is no inbetween. If there was, there would be more cars like the 86 with turbos for $30K. But there aren't.
There theoretically could be an 'in between'. There could be a BRZ/86 with turbos. But it wouldn't sell for $30k. It would have to cost significantly more.
The closest thing to a BRZ/86 with turbos might (big might) be the upcoming Nissan 400ZX - with a lot of if's. IF it's actually produced, IF it comes with a manual transmission (important for me, maybe not to others, and otherwise it's just a Supra-esque car with an automatic only), and IF it's priced right (which likely won't be anything less than somewhere in the $40k's).
Even then it won't truly be a '86 with turbos', it will be bigger, heavier, less nimble, more expensive, etc. etc. etc. But it would still be the closest thing possible - a small(ish), Japanese sports car hopefully with a manual transmission.
At any price, there's the over-riding question of how many people would actually buy a BRZ/86 with turbos? I certainly would, but as you said, in the $40k's price range it would take to build it, most buyers want something else (more luxury, bigger size, etc.).
Ah, well, can't have everything (but can still wish for it).
AnalogMan is offline
The Following 3 Users Say Thank You to AnalogMan For This Useful Post:
gymratter (08-12-2020), mazeroni (08-12-2020), soundman98 (08-12-2020)
Old 08-12-2020, 01:28 PM   #268
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Yoshoobaroo View Post
They could pull a Mazda and have the smaller motor still around for more displacement restrictive markets. The ND has a 1.5L option in addition to the 2.0L.
Too difficult to offer 2 different engines, but it is true that the 2.0L option was a solution to sell in more markets. Offering just a 2.4L would mean its death in certain regions.
Sent from my SM-A105FN using Tapatalk
nikitopo is offline
Old 08-12-2020, 01:29 PM   #269
p1l0t
p1l0t's Avatar
Oh I see it's legal because we have the window light also.. I still like my low light though haha.
p1l0t is offline
Dadhawk (08-12-2020)
Old 08-12-2020, 01:34 PM   #270
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by gravitylover View Post
Sort of.
It seems to me that the 2.4 having beefier internals could have more than 217hp NA with a few tweaks.
You would think, but the FB25 has smaller rod journals and thinner rods. I know it is not the same engine, but just an example. I wouldn't assume the FA24 is beefier anywhere. My main concern would be does it have the 12mm oil pump or the 14mm that was in the FA20DIT.
NoHaveMSG is offline
Old 08-12-2020, 01:53 PM   #271
WildCard600
WildCard600's Avatar
Drives: 2020 86
Originally Posted by why? View Post
Have you driven them back to back? The BRZ drives so much better than the WRX that anyone who thinks handling is more important than power chooses the BRZ over the WRX. Just look around, many people here test drove both and chose the BRZ. The BRZ makes the WRX feel like a pickup truck.
Sure. And my 86 makes my Wrangler feel like a semi truck with trailer attached. But the 86 would still just barely wheeze past that 4200 lb brick if you floored both from a stoplight....
WildCard600 is offline
Old 08-12-2020, 02:02 PM   #272
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes, it’s legal as long as it doesn’t strobe.
Also these regulations cover most of the world. Nobody builds a car just for the US.
Yoshoobaroo is offline
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 08-12-2020, 02:04 PM   #273
Ohio Enthusiast
Drives: 2018 BRZ
The FB25 isn't turbocharged, but the FA24 is. I'd guess that running FA24 naturally aspirated would leave quite a bit of robustness from removing the turbo that could be directed at higher compression ratio and higher redline. Might be similar to the turbo FA20 in the WRX (and others) and the NA FA20 in the Twins (with the NA version having higher compression and redline).
Ohio Enthusiast is offline
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
gravitylover (08-13-2020)
Old 08-12-2020, 02:06 PM   #274
Originally Posted by dnieves View Post
Does that mean you can be stopped if you have an additional JDM brake light under the bumper? Or the more merrier as long as the USDM top mount brake light is present & functional?
Best to check your State/Province requirements as they can vary considerably and sometimes be bizarre.
Buckle up and get ready for this roller coaster ride for Ontario, Canada:
New cars (federal) - Covered by one set of legislation that requires all cars built for new sales in Canada to include (for the rear) two red tail lights, two red or amber directional signal lights with auto shut off, red reflectors in the Imeadiate vicinity of the lights and a third brake light centered between and at least 6 inches above the taillights. There is also a requirement for two headlights with both high and low beam capability, front signals and amber side markers. The detailed section of the requirements is about a page long.
Used cars (provincial) - All used cars must have all lights that are installed functioning. There is no requirement that it have all the lights required in a new car to be in place but if they are there they need to work.
Cars operating on the roads (provincial) - Here is the whole list of required lights as per the Highway Traffic Act.
HTA s.62(1)
  • A white or amber light on the front-left of the vehicle
  • A white or amber light or the front-right of the vehicle
  • A red light on the rear of the vehicle
These are the TOTAL requirements!
There is no disclaimer that lights required on new cars have to be there to drive on the roads.
You need two head lights and one tail light PERIOD
The one red light in rear does not have to be a brake light. You can have NONE.
You can put as many white lights on the front or as many red on the back as you want as long as they meet the minimum.
I could take all but one of the lights off the rear of my car and be legal.
There are of course different requirements for large and commercial vehicles.
Now, although legal I would not advise trying to drive around with no signals. For one you would almost certainly be hit, you are just asking for them to pull you over and check other things and unless you are really diligent at arm signals you could be ticketed for failure to signal a turn.
Tcoat is offline
MJones_RB (08-12-2020), p1l0t (08-12-2020), soundman98 (08-12-2020), Yoshoobaroo (08-12-2020)
Old 08-12-2020, 02:12 PM   #275
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
So your assuming an NA FA24 would get the same parts as the turbo version, yet we didn't get the same upgrades the turbo FA20 got
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
gravitylover (08-13-2020), Ohio Enthusiast (08-12-2020), Vides990 (08-12-2020)
Old 08-12-2020, 02:27 PM   #276
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I understand in Ottowa it's illegal for a donkey to own a gun.
MJones_RB is offline
The Following 3 Users Say Thank You to MJones_RB For This Useful Post:
p1l0t (08-12-2020), Tcoat (08-12-2020), Ultramaroon (08-12-2020)
Old 08-12-2020, 02:36 PM   #277
p1l0t
p1l0t's Avatar
Then why can't we get the good (rally) Focus?
p1l0t is offline
Old 08-12-2020, 02:36 PM   #278
p1l0t
p1l0t's Avatar
Funny story on that one..
p1l0t is offline
Old 08-12-2020, 03:26 PM   #279
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Originally Posted by Raven86Project View Post
Way too big. Too heavy, 5" taller than the 86 and aesthetically very unappealing. It has a lot of heritage but I really don't feel the connection with it. These are some of my honest reasons of why I would not consider the Mustang over the current or future 86. But ngl, I'm a JDM fanboy
I apologize for the distant pic (I'll get a good one at this weekend's C&C). The only mustang that really catches my eye is the Shelby GT500 (the Ford GT next to it is nice too!).
ROFL it's Waffle is offline
Old 08-12-2020, 03:38 PM   #280
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
But so do the Crosstrek, Legacy, and even up into the Outlander and Forester. Subaru loves their parts bin designs.
Much of the design and many of the systems (i.e steering directly transferred over) of the new Impreza is based on the developments made for the 86/BRZ so is it safe to say that the newest Impreza is just an upsized BRZ?
Oh I agree. I just think it’s funny because Subaru made it such a big deal as if the two didn’t share any structural parts, saying the two were completely different.
Yet under the bodywork, they’re still extremely similar just like they’ve always been.
I’m not saying they’re bad. I still enjoyed my STI. I just can’t help but laugh just a smidge at it.
TylerLieberman is offline
The Following User Says Thank You to TylerLieberman For This Useful Post:
2018 Toyota Camry Spied: Normalness in a New Generation gymratter Other Vehicles & General Automotive Discussions 95 10-12-2020 12:19 AM
Drift King Video Test: Gazoo Racing GR86 vs. BRZ STI TofuJoe Scion FR-S / Toyota 86 GT86 General Forum 1 03-15-2018 08:21 PM
2019 Toyota Avalon Spied For the First Time, Expect a Bolder Design gymratter Other Vehicles & General Automotive Discussions 6 08-05-2017 02:08 PM
Video: First time drifting! Shady195 Tracking / Autocross / HPDE / Drifting 3 04-20-2015 05:26 PM
