CANADA Canada
Old 08-08-2020, 03:36 AM   #1
SeratoBeats
Herbie The Love Bug
Drives: BRaz
Need BRZ 2013 engine asap
Looking for a new used or rebuilt 2013 subaru fa engine
Located in Toronto
Pm me!
Thanks guys
SeratoBeats is offline   Reply With Quote
Old 08-11-2020, 10:51 AM   #2
wparsons
wparsons's Avatar
2013-2016 is a direct swap in, just have to use the coilpacks from your original engine if it's 2015+. 2017+ requires more work, more sensors have to be swapped over (manual only, 2017+ automatic is the same as 2016-).
You can look on car-part.com to search wreckers too.
flickr
SeratoBeats (08-17-2020)
Old 08-11-2020, 11:09 AM   #3
SeratoBeats
Herbie The Love Bug
Drives: BRaz
Thanks
Whats the difference between the short block and the long block?
Also, would you ever trust purchasing an engine from someone online. The pictures they are sending md of the motor are in mint condition but how can i know if the think knocks? Is it a gamble?
Old 08-14-2020, 11:03 AM   #4
wparsons
wparsons's Avatar
Short block doesn't include heads, and probably none of the timing parts either (chain, tensioners, etc). Long block will be a complete engine, but might not include accessories (alternator, AC compressor, etc).
flickr
Old 08-14-2020, 12:32 PM   #5
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
And you might want to double check the PCV (IIRC). According to the shop who swapped it for me the previous engine must have been set up with a catch can. Filled the engine with oil on startup. They fixed the issue, pulled the brand new plugs, and cleaned out as much as they could. Smoked like a B*tch for quite a while before I could drive it home. (think bond smokescreen levels, my profile pic is after running for ~20+ minutes and at idle - middle of august last year).
Don't mean to be an alarmist or anything but can't hurt to check it.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Need BRZ 2013 engine asap SeratoBeats Want-To-Buy Requests 6 08-11-2020 03:50 PM
NEED BRZ 2013 engine SeratoBeats Want-To-Buy Requests 0 08-07-2020 08:02 PM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 06:16 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 10:03 PM
