Old 07-24-2012, 12:00 PM   #1
FRiSson
Drives: FR-S MT
Why you are always driving uphill
http://web.mit.edu/newsoffice/2012/p...ires-0523.html
The researchers found that the weight of your vehicle on asphalt surfaces causes the pavement to deflect slightly downwards. As a result, you drive in a continual trough and the wheels are always going uphill.
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
Snoopyalien24 (07-24-2012)
Old 07-24-2012, 02:00 PM   #2
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Perfect! Now we can invent hover cars!
Snoopyalien24 is offline   Reply With Quote
Old 07-24-2012, 02:52 PM   #3
Nothing new here. I learned this the first season of "Ice Road Truckers".
Old 07-24-2012, 03:56 PM   #4
FRiSson
Drives: FR-S MT
Actually very little research has been done on deflection in asphalt. Deflection on surfaces such as ice is not exactly equivalent, since the substrate is sometimes unfrozen water or soft materials such as gravel. Track deflection has been observed in railroads for 190 years. However, because freight railroads lack suspension systems, the deflective surface acts as a kind of shock absorber to save the train from being rattled to pieces.
The implications of this current line of research is that we have built our highways using asphalt because it is cheap, but using harder materials would save us around 3% a year in fuel use. That may offset the higher costs of using harder pavement materials such as concrete instead of asphalt.
Old 07-24-2012, 04:01 PM   #5
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I dont know about you guys, but I tend to like asphalt. Since its much softer than concrete and other typical road materials, it usually results in a less jarring ride (if maintained properly.) The rubberized asphalt that phoenix is currently using on all of the ring roads/freeways/etc is just delightful to drive on because it is so soft.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 07-24-2012, 04:11 PM   #6
motofan
Drives: 10 VW GTI
that may help, but here people don't maintain road...
motofan is offline   Reply With Quote
Old 07-24-2012, 07:22 PM   #7
86X86
86X86's Avatar
Drives: '13 GBS BRZ Ltd (MT)
I actually kinda miss the "thump-thump" going over the expansion joints of a concrete freeway-- gawd I gotta get out of Alaska...
86X86 is offline   Reply With Quote
Old 07-24-2012, 07:37 PM   #8
SkullWorks
Drives: SSM LT MT BRZ
this is the problem with PHD's, they literally can't think, they are too busy "understanding"
without tires that deflect less than the road, no real effect will be made.
where does all of this energy go that is used to deflect the road, does it not equally react at the backside of the tire?and effectively propel you? Does asphalt actually have time to compress while covering 1 mile per minute or approximately covering the tires effective contact patch width 264 times per second?
(5280/60=88' per second or 1056" per second/~4" long contact patch=264)
how bout we focus on the real traffic issues that could gain/cost 10-20% like stop light sequencing. staggering work hours for industries to limit max usage of highways, fix ACTUAL road problems like uneven roads, pot holes, poor civil engineering ETC.....
GRRRRR
/rant
The Following 3 Users Say Thank You to SkullWorks For This Useful Post:
Dadhawk (07-25-2012), Infernal (07-25-2012), Laika (12-17-2012)
Old 07-25-2012, 07:19 AM   #9
peter
Drives: BMW
Yes I agree with you post, really expose the idea very well.
peter is offline   Reply With Quote
Old 07-25-2012, 07:37 AM   #10
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
needing to slow down for speed bumps, traffic lights and traffic in general probably causes mor pollution, fix these, then we'll talk about harder pavements!
Infernal is offline   Reply With Quote
Driving Shoes ZetaVI Other Vehicles & General Automotive Discussions 77 09-13-2012 01:42 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
Driving in the Rain! 5hairpins Scion FR-S / Toyota 86 GT86 General Forum 7 06-26-2012 02:38 AM
Will driving ever dissapear? LexusFman Other Vehicles & General Automotive Discussions 5 10-02-2011 10:38 PM
