| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: 2013 Scion FR-S (Whiteout)
Guys, these 2 corners are they also going up a bit on yours or did they sit flat?
#16 |
Drives: 2013 Firestorm FR-S AT
#17 |
@Agent 86
Thanks for scanning and uploading the instruction images. Figure 2.5, keeping the gap between the brackets at 135 mm is very important. Without instructions I held the brackets against the console while drilling the other holes. This worked out ok because my armrest slides smoothly and engages in the 3 positions, but if I installed it again I would follow the instructions. Also figure 5.1 shows the correct orientation of the plastic clips in the armrest base. It looks like I guessed right. |
#18 |
Drives: Moped
Great resource guys, thank you.
#20 | |
Drives: 2017 Cayman S
The good thing is that it does not interfere with the movement of the armrest. It seems to be caused by the crown of the center console that armrest straddles. If it bothers you, I imagine this could easily be fixed with the careful application of heat from a heat gun.
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
#21 |
Drives: 2016 BRZ
Awesome
Thanks for the info guys easy install works great! My kit came with no instructions so this was very much needed thanks again!
#22 |
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
How much would a dealer/ shop charge to install this? I am sure I could do it myself but It looks a bit more involved than I thought at first. I test drove a car and was disappointed that the used one I am going to buy doesn't have an arm rest
#23 |
Drives: 2015 Ultramarine Scion FR-S
Thank you for the guide, followed it and got my armrest in without any problems!
![]() Sent from my ONE E1005 using Tapatalk |
#24 |
Drives: Toyota 86
I just installed my armrest. I didn't want to drill any holes so I just used double sided tape. The whole thing mounts securely. You apply the tape to the underside of the armest rails (the side that mounts to the console), mount the rails to the included plastic cover/trim piece, apply tape to the sides and rear portion of the cover, then mount to the console. No need to use the template, takes only 5 minutes and is completely reversible
At first I thought the armrest wouldn't make any difference since I never found myself needing a place to rest my arm in this car, but I was wrong. It really feels good and does make driving (especially in traffic) more comfortable
| The Following 2 Users Say Thank You to HRTROB For This Useful Post: | KoreanJesus (12-11-2018), PerCompLLC (06-08-2023) |
#25 |
Drives: 2017 86
Thanks for all the input, I just did this and am very happy.
Car should have come with it stock IMHO. |
#26 |
Drives: 2022 MT Neptune GR86 Prem.
Anybody know if this will fit a 2020 BRZ?
#27 |
Drives: 2019 BRZ with Performance Package
Yes, it will fit the 2020 BRZ.
#28 |
Drives: 2019 86 TRD SE
Thank you for this. I bought my new 86 in December, from a dealer in AZ, and drove it back here. The armrest is a $199 option, but they couldn't get one in time. So, I bought one from a local dealer for a little more than that for the part only. No installation instructions included. It was too complicated for me to figure out, so I asked them how much to install it, and they quoted me almost $250. This is a huge help, and I thank all of you who contributed.
| *GB FR-S/BRZ Center Console Armrest $45.99 | Massdrop | Groupbuys | 0 | 10-14-2013 09:06 PM |
| TRD Center Console Armrest | zzabbas | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-22-2013 06:44 PM |
| JDM Center Armrest | K2 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 10-09-2012 12:08 AM |
| DIY Center Armrest | BRZranger | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-19-2012 11:04 AM |
| Center Armrest | Sovran | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2012 12:49 AM |
