| CANADA Canada |
Drives: 2015 frs, 2000 Honda s2000,
Hub centric rings in Canada?
I'm looking for a set of aluminum hub centric rings from 73mm to 56.1mm,
i can't find anything on amazon that isn't 50+$, eBay only ships from china or is 20+$ shipping from USA. anyone know where I might be able to order a set? |
#2 |
Drives: 17 Asphalt 86
Why aluminum?
Plastic should do the trick and will generally be cheaper. I found them via Amazon from gorilla for $20. |
#3 | |
1. aluminum expands with heat and seals the wheel and hub better, makes the clearance basically 0mm so there will be no load transferred to the studs. 2. plastic will deform too easily, even if the tolerances are tight, I can't see it taking several hundred pounds of load without deforming to the point where the studs are carrying the load anyways. 3. Constant thermal cycles might crack the plastic and I'd be worried about high temps from braking possible melting the rings. IMO aluminum is better for track duty. |
#4 | |
Rice King
If you install your wheels correctly, you do not need hubcentric rings.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| The Following User Says Thank You to Jordanwolf For This Useful Post: | wparsons (08-11-2020) |
#5 |
Yes you do, the studs are not designed to take 100% of the load, if you use aftermarket wheels and don't have a hubcentric ring you're putting a massive amount of stress on the studs. It's why every OEM wheel in existence is hub centric, the hub is designed to take the load. I don't know who told you otherwise but they're wrong.
| The Following User Says Thank You to NotAMiata For This Useful Post: | Turbo (09-30-2020) |
#6 | |
Drives: 2015 Subaru BRZ Sport Tech
Sent from my Pixel XL using Tapatalk |
#7 | |
The hub ring is simply an alignment tool to make sure everything is centered prior to torquing everything down. Assuming you follow the proper torque procedure the wheel will center it self and you don't NEED centering rings. Conical lug nuts will center the wheel when you tighten. Following proper torque specs is important as well as tightening in the correct sequence. That said, I do like having centric rings if the wheel bore is larger than the factory hub bore. They're cheap and makes mounting wheels easier. I have used the same plastic rings for two winters now on my winter wheels, not a crack or issue with them. I always tighten wheels with least amount of load on the wheel as possible before final torque procedure. Your comment about melting plastic rings is understandable. In a tracking situation I've heard of plastic melting, but on the street I can't see that ever being an issue. Last edited by RToyo86; 08-07-2020 at 10:02 PM. |
| The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
#8 | |
Drives: 2013 WRB BRZ 6MT
You should learn a bit about the physics of how the wheel attaches to the hub before you say stuff like that. Here is some suggested reading: https://www.maximummotorsports.com/t...s_spacers.aspx Basically, the lugs and studs are only responsible for applying clamping force between the hub face and the seat of the wheel. All up and down, side to side, and rotational forces are transmitted directly between the hub face and wheel seat via friction applied by that clamping force. Forces applied to the studs while a vehicle is in motion don't change in any appreciable way. Consider the shape and size of the stud which is the part that would take those forces. If the stud was bearing vertical or rotational loads, the smart thing to do would be to design it wider than it is long, or have them install into the wheel sideways, in the same direction as the spokes, but they aren't designed like that, are they? OEMs use hub centering mostly because it makes wheels easier to install and provides fewer opportunities for mistakes when mounting the wheels, because mounting mistakes are what lead to broken studs. Basically, once all lugs are properly torqued, the load on the wheels is entirely a function of the friction between the hub face and the seat of the wheel and has nothing to do with the hub or studs/lugs. I should note that I'm not advocating for not running a centering ring, they are still useful and make mounting wheels way easier but the only real reason to use aluminum over plastic is if you are going to track the car because the heat generated will melt plastic. Last edited by Lynxis; 08-07-2020 at 10:19 PM. |
| The Following 3 Users Say Thank You to Lynxis For This Useful Post: |
#9 | |
Rice King
Some small ring isn't going to carry the entire weight of a car, let alone a fraction, so I don't know who told you that, but they're wrong.
Glorious Honda.
#10 |
Wes
I haven’t used rings in 3 years lol. Still fine, switching wheels twice a year myself
Instagram: @gt86ws
| The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: | Jordanwolf (08-07-2020), Lynxis (08-09-2020) |
#11 |
Rice King
I like to use them, just makes install that much easier.
Glorious Honda.
| The Following User Says Thank You to Jordanwolf For This Useful Post: | Lynxis (08-09-2020) |
#12 |
Wes
Honestly this is the first time I hear about the install. I just put them on and torque them. They center themselves lol
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Lynxis (08-09-2020) |
#13 | |
#14 |
Drives: Raven FR-S 6M
You should be able to walk into any retail outlet that sells/installs aftermarket wheels and pick up a set. They install 1000s and usually have most common sizes in stock.
“The World is Flat”
[||•]=(86)=[•||] |
| Are hub centric rings mandatory? | Impureclient | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-03-2019 01:46 AM |
| Hub Centric Rings Fitment? | Hentai | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-20-2015 01:42 PM |
| WTB: 65mm to 56.1mm Hub Centric Rings | alexvc | Want-To-Buy Requests | 1 | 01-24-2015 05:57 PM |
| SSR Type C RS hub centric rings | Justkiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 02-14-2013 08:34 PM |
| FS: Hub centric rings 63 > 56.1 mm | JDMSushi | Australia Classifieds | 3 | 02-09-2013 08:52 PM |
