Old 08-07-2020, 05:00 PM   #43
norcalpb
norcalpb's Avatar
Forgot to knock on wood so I think I have this issue now.
Does this sound like the issue to anyone?
I hear it from the engine bay too, but the noise seems much lower than my Pedders front suspension mounts.
Old 08-09-2020, 07:27 PM   #44
uras300
^^ I have similar noise coming from lower front passenger side. It only happens when I put it in reverse and turning right though.
uras300 is offline   Reply With Quote
Old 08-12-2020, 02:14 PM   #45
ermax
ermax's Avatar
Even after replacing my coupler I still get the thump when turning left/right while stationary so that isn't a definitive test. If you can do 15 - 25MPH over small bumps (I like to test on road reflectors) and not hear knocking then you are probably fine.
Old 08-18-2020, 09:32 PM   #46
Hayseed
Drives: Scion FR-S
Originally Posted by Outlander View Post
These additional pictures were very helpful thanks a lot 86Kenshin, and also a big thanks to Ermax for starting the thread. I really think Toyota needs to stock this part for this model. Heck should have been a recall for everyone that has the problem. The dealer said that they would not be able to fix this without replacing the entire EPS motor. The tech that was working on it kinda pointed me in the direction of this topic. (not here specifically)
Update: Got it working thanks again.
Just my small contribution
For a couple of steps in ermax walkthrough that helped me.
Remove column nuts
Using a 12mm socket with extension remove the two bolts which hold the column to the chassis
and
Remove EPS motor
Using a 12mm socket with extension remove the two bolts holding the motor to the EPS unit (Green Line is where the separation is) Which I used a flat head screwdriver to carefully pry open.
Regarding the two "bolts" holding the column to the chassis:
I found they are 14mm "nuts" on bolts as some have said. But also how would everyone rate how hard was it to get those nuts loose? Mine do not budge and I am in danger of rounding the nuts off.
Possible my socket isn't deep enough. Going to get another one to be sure, but I stopped at this point because I'm a bit freaked out the nuts were starting to round. I triple checked I was using a 14mm socket also.
Hayseed is offline   Reply With Quote
Old 08-19-2020, 11:01 AM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I impacted mine on and off. Didn't try it with a hand tool. If you take the dashboard out you can skip those 2 14s ha.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Opie (08-19-2020)
Old 08-19-2020, 11:01 AM   #48
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This is almost surely a slightly loose metal undertray. Just go tighten all those 12s and 10s real good.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-19-2020, 11:14 AM   #49
Hayseed
Drives: Scion FR-S
Thanks, Dave-ROR. I'll try the impact gun also.
Cheers!
Old 08-19-2020, 05:51 PM   #50
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Dave-ROR makes a great point, the entire dash comes out pretty quickly (like under an hour) and you can then get the EPS apart without meddling in the floorboard...much easier in my opinion.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-19-2020, 05:52 PM   #51
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I don’t know, I did the EPS from underneath in <45min.
Old 08-19-2020, 07:28 PM   #52
Hayseed
Drives: Scion FR-S
Well that was a fail. Impact wrench finished the job rounding off those nuts (one is worse than the other).
They didn't budge.
So I saw someone say that alternative is take the dash out? Meaning instrument cluster?
This is getting disappointing.
Old 08-19-2020, 07:54 PM   #53
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They didn't budge.
They had to be rounded off and/or wrong socket (not deep enough) before hand. I've had those two nuts off and impacted back on a couple times dealing with my track car build and they don't have a mark on them.
Dash is easy really, just a lot of crap to take off. Center console, hvac, radio, a pillar trim, speaker covers, lower dash panels, OBD2 plug, pass airbag, etc.
After doing it a few times it's easy. The OBD2 plug sucks the most. Now my dash is held in with 6 screws.. obd2 sits where hvac was. Makes taking out the dash a 1 minute job
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-19-2020, 09:45 PM   #54
Hayseed
Drives: Scion FR-S
Yeah, the initial error was a socket not deep enough.
I bit the bullet and headed to the store for an extractor set. Got them off. They are toast, but they are off.
The Following User Says Thank You to Hayseed For This Useful Post:
Dave-ROR (08-19-2020)
Old 02-28-2021, 05:50 PM   #55
HimBRZ
HimBRZ's Avatar
Drives: 2013 BRZ Limited
THANK YOU! THANK YOU! THANK YOU! This solved my rattle and steering is like new!
This is what owner forums are for!
HimBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to HimBRZ For This Useful Post:
ermax (02-28-2021), JesseG (03-04-2021), Opie (01-18-2023)
Old 03-04-2021, 12:06 PM   #56
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
I think I may have this issue on my 2016 FR-S. I hear a small clunking or rattling sound at lower speeds, it sounds like it’s on the drivers side. The steering feel isn’t quite as sharp either. I was thinking it might be something in the suspension, but after reading this I’m not sure. I’m worried about doing this fix and messing up something else. I’m only at 33K miles
JesseG is offline   Reply With Quote
Is building a motor necessary for FI on this motor? Irace86.2.0 Forced Induction 44 02-27-2018 01:19 PM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 04:29 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 02:39 PM
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) Sportsguy83 Engine, Exhaust, Transmission 11 06-18-2014 11:29 PM
