Old 08-03-2020, 09:19 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by LimitedSlip View Post
@White142 Maybe get a spray can of fan belt dressing. With the engine idling CAREFULLY squirt some on the belt surface that contacts the pulleys. This helps eliminate any glazing on the belt and will instantly eliminate belt squeal.
Don't be cheap, buy an OEM belt.
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Ultramaroon (08-04-2020)
Old 08-04-2020, 03:54 PM   #16
After my perfectly good factory belt began squeaking over the alternator pulley, I discovered that tiny pieces of gravel had made their way into the grooves of the belt. I spent an hour carefully picking them out. Fixed it right up.
Old 08-05-2020, 02:14 AM   #17
................... Maybe get a spray can of fan belt dressing. With the engine idling CAREFULLY squirt some on the belt surface that contacts the pulleys. This helps eliminate any glazing on the belt and will instantly eliminate belt squeal.
Now, THAT brings to mind the grain harvest time back on the farm. One of my jobs as a child was to "dress" the drive belt that ran from the tractor to the threshing machine. Yep, the belt dressing came in a large bar of black stuff and as the belt was moving I would rub it against those sections on the belt that were squealing or slipping.
When it was running right, I would amuse myself by catching grasshoppers and putting them on the belt to see if they could jump off before the drive pulley squashed them. -
OK,OK, I was easily amused - times were different - yes, your right it IS my med time.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
soundman98 (08-05-2020), Ultramaroon (08-05-2020), why? (08-05-2020)
Old 08-05-2020, 09:25 AM   #18
Silviacrazed
Drives: 2016 Scion FR-S
Humfrz the serial killer
Sent from my SM-G960U using Tapatalk
Silviacrazed is offline   Reply With Quote
The Following User Says Thank You to Silviacrazed For This Useful Post:
humfrz (08-05-2020)
Old 08-05-2020, 10:50 AM   #19
ls1ac
ls1ac's Avatar
It was an art to get the belt back on while the tractor was running and not get a finger. They would not let me try until I was 16. A broken rake handle and a quick push. It looked so easy when done right.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
humfrz (08-05-2020), soundman98 (08-05-2020), Ultramaroon (08-05-2020)
Old 08-05-2020, 11:50 AM   #20
Yep, if it wasn't one belt coming off it was another -
When one part would stop running, things (like the cylinder) would jam up. My father would be busy digging trash out of the parts and my grandfather would try to figure why the belt came off and adjust that pulley. I would sit on the tractor and engage the PTO when they signaled me.
Then, like you say, my grandfather would use a hammer handle to "slip" the main drive belt back on. Then, I would run and get the jug of cold well water out from under a pile of lose hay along the fence row, we would all have a big slug - then back to work.
Old 08-05-2020, 12:56 PM   #21
Ohio Enthusiast
Drives: 2018 BRZ
Could y'all count to 10 without taking off your boots?
Ohio Enthusiast is online now   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
humfrz (08-05-2020), Ultramaroon (08-05-2020)
Old 08-05-2020, 01:03 PM   #22
Well, ya - but, counting above 10 took a bit longer -
compressor, maintenance, noise, pulley, squeal
Odd noise coming from the back Inteze Engine, Exhaust, Transmission 6 04-09-2020 01:03 PM
Rattling noise coming from car? YgRoshi Scion FR-S / Toyota 86 GT86 General Forum 8 04-22-2019 06:32 PM
Noise coming from rear of car B-R-Z BRZ First-Gen (2012+) — General Topics 9 05-30-2017 06:04 AM
Noise coming from the rear end... jm1681 Issues | Warranty | Recalls / TSB 17 03-13-2014 07:30 PM
Noise coming from the engine. Zoomryder Scion FR-S / Toyota 86 GT86 General Forum 11 01-26-2013 10:07 AM
