Old 08-01-2020, 04:14 AM   #925
Scotty-B
Drives: 2015 FR-S
STI strut tower bar (with spacer) installed with Harrop SC pics
Originally Posted by kuczynskika View Post
Known Front Strut Tower Bar Compatibility:
1. Cusco
2. STi
Name:  Fr-s STI flexible strut tower brace installed pic.jpg
I don't remember seeing any pics of this product installed with a Harrop SC , and most of the info that is posted seems to be scattered amongst the dozen?hundred?gazillion? posts on the subject.
One important bit of info that is absent from the majority of the post is that a spacer is required to obtain the clearance between the top of the SC and this strut bar. Thank you to whomever previously mentioned this fact(?-is there another way). I experimented a little, and eventually decided it was easier to buy spacers already on the market, and modify to fit. All the ones I found were marketed toward rallycross to raise the vehicle. Plenty of companies making/selling different versions. I originally intended to use this ABS version as a template for modifying a similar aluminum spacer, but so far it seems to be holding up.
Name:  Fr-s STI flex bar spacer subtle solutions pic.PNG
Name:  Fr-s STI flex bar spacer thickness pic.jpg
Size:  43.3 KB,Name:  Fr-s STI flex bar  Harrop SC clearance pic.jpg
These spacers are intended to be installed under the strut towers, so when installed above the strut towers, material must be removed to clearance the strut tower braces and protruding body panels to which the braces attach. OEM brace pictured below to show that they are "in the way", as are the Raceseng braces I have installed. (and if your going to freehand with a Dremel, expect it to be ugly)
Name:  Fr-s strut tower brace OEM pic.PNG
Size:  151.7 KB,Name:  Fr-s strut tower brace Raceseng pic.PNG
Name:  Fr-s STI Flex bar spacer  tower brace clearance pic.jpg
Size:  62.3 KB,Name:  Fr-s flex bar spacer  body panel clearance pic.jpg
This version of spacers came with mounting hardware which seems to fit with OEM shock mounts. If you have Raceseng CasCam plates, then you gotta get longer bolts. I bought 35mm long replacements which give plenty of thread protrusion (can't have the nutplates falling off/lost as I make adjustments 5 minutes before hot laps begin...thats how I roll).
Name:  Fr-s STI flex bar  shock strut hardware pic.jpg
Size:  30.2 KB,Name:  Fr-s STI flex bar  shock strut hardware thread protrusion pic.jpg
All Hail Harrop
Scotty-B is offline   Reply With Quote
The Following 2 Users Say Thank You to Scotty-B For This Useful Post:
grumpysnapper (08-01-2020), Irace86.2.0 (08-01-2020)
Old 08-01-2020, 04:55 AM   #926
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Bodalenko View Post
Been thinking of doing similar but very difficult to get a fluid container that is identical to the Edelbrock. If you’ve found one that’s suitable would appreciate a link.
Why not the Edelbrock one? I used a file to easily sand off the Edelbrock logo, so it didn't mess with the OCD.
Old 08-04-2020, 02:43 AM   #927
byun
byun's Avatar
Drives: 2015 BRZ CWP
Decided to push the limits of the stock block and see how long it lasts. Switched from the 85mm to 75mm pulley and had Neal @theracersline and Zach @Counterspacegarage dial it in on E85. Pretty impressed with the results
byun is offline   Reply With Quote
The Following 6 Users Say Thank You to byun For This Useful Post:
bhmax (08-07-2020), FunnyGopher (08-04-2020), Irace86.2.0 (08-04-2020), Kiske (08-04-2020), pallen (08-04-2020), Side (08-04-2020)
Old 08-04-2020, 01:38 PM   #928
Irace86.2.0
Nice! What injectors are you using, what was your peak boost, and what exhaust mods do you have?
Old 08-04-2020, 02:12 PM   #929
dakine001
Drives: 17 BRZ PP
Waiting on my Harrop kit to arrive along with Jackson DROC, fuel pump, injectors, and new clutch. Currently on e85, waiting is the hardest part!
dakine001 is offline   Reply With Quote
The Following 2 Users Say Thank You to dakine001 For This Useful Post:
grumpysnapper (08-05-2020), Irace86.2.0 (08-04-2020)
Old 08-04-2020, 08:45 PM   #930
byun
byun's Avatar
DW700cc, ace a350 header/ace front pipe, CSG touring catback. hitting 16psi at redline.
The Following User Says Thank You to byun For This Useful Post:
Old 08-05-2020, 09:31 AM   #931
Calum
That Guy
Drives: 2013 asphalt FRS MT
Where do you buy the smaller pulled from?
Old 08-05-2020, 10:13 AM   #932
pallen
pallen's Avatar
Drives: 2017 Toyota 86
More than the max, I'm impressed with that curve. Almost perfect, linear power delivery. No dips or spikes, just constant pull. Must be a blast on the street.
pallen is offline   Reply With Quote
Old 08-05-2020, 01:01 PM   #933
Irace86.2.0
They can be purchased from Harrop of course:
https://www.ft86club.com/forums/show...&postcount=797
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Calum (08-05-2020)
Old 08-05-2020, 01:30 PM   #934
byun
byun's Avatar
I have the 85mm pulley i'm selling and also a 90mm as well.
Old 08-07-2020, 01:37 AM   #935
Irace86.2.0
Power is addicting. The 75mm pulley looks appealing, but then again, so does the 70mm pulley, or even better yet, the 65mm pulley. I find myself thinking of how far I could press my luck too.
Old 08-08-2020, 11:47 AM   #936
byun
byun's Avatar
Yea it is, I haven’t even had a chance to drive it yet since the switch. Have to wait until I can get it out to the track. Hope it lasts a track day. If not will be figuring out what kind of swap/build I’ll be starting.
Irace86.2.0 (08-14-2020)
Old 08-14-2020, 05:24 PM   #937
Irace86.2.0
Originally Posted by Kiske View Post
@kuczynskika
Here is an updated list of Harrop's Pulley and Belt pairings they currently offered.
Each pulley is $110 AUD ($103 USD) and Belts are $55 AUD ($38 USD) + Shipping directly from Harrop AU.
Boost Level --- Pulley Size --- Part No. --- Belt Part No.
8.psi -----------95mm --------99-PLY12901 --6PK2465
10psi ----------90mm --------99-PLY12655 --6PK2465
11.5psi --------85mm --------99-PLY11622 --6PK2453
13psi ----------80mm --------99-PLY11623 --6PK2445
14.5psi --------75mm --------99-PLY11624 --6PK2445
16psi ----------70mm --------99-PLY11625 --6PK2440
17.5psi --------65mm --------99-PLY13099 --6PK2440
Currently the remaining goodies that are employed on the Project 86 are track-only bespoke parts, not in development for consumer purchase.
Where did you get this data? From Harrop? Is this their belt sizes or your estimation of what belts would be needed?
I bought a used kit with a Gates belt that made noise, so I bought the Continental/Goodyear Poly-V Elite/Gatorback in size 4060970, and the belt squeal immediately went away. I can't recall if I changed belt sizes when going to the 85mm pulley from the 95mm pulley, but the belt was obviously easier to get on. I haven't had any belt slippage at all. I know other superchargers have had belt issues, but I haven't had any problems, so I was curious if anyone else has had problems when switching between pulleys and with different belt sizes.
If we look at the change in belt pitch length, we don't see a huge difference:
95mm...6PK2465...2465mm = 97.0in
Alternatives...4060970, 5060970, K060970, 970K6
Difference = 0
90mm...6PK2465...2465mm = 97.0in
Difference = 12mm or 0.47inches
85mm...6PK2453...2453mm = 96.6in
Alternatives...4060966, 5060966, K060966, 966K6
Difference = 8mm or 0.31inches
80mm...6PK2445...2445mm = 96.2in
Alternativers...4060962, 5060962, K060962, 962K6
Difference = 0
75mm...6PK2445...2445mm = 96.2in
Difference = 5mm or 0.19inches
70mm...6PK2440...2440mm = 96.0in
Alternatives...4060960, 5060960, K060960, 960K6
Difference = 0
65mm...6PK2440...2440mm = 96.0in
I seem to be having a problem finding the size belts listed. Like I can't find 4060962.
Old 08-14-2020, 07:58 PM   #938
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
It's directly from Harrop when I ordered my 65mm and belt. ***Harrop AU as Harrop USA is annoyingly out of the loop.***
Be warned they require a wire transfer for payment, which most banks charge you a fee to do so. Shipping was about 1.5 weeks.
Specifically from Julian over email whom was very helpful, even kicked a "Harrop TVS Supercharged" emblem my way.
Julian Patane | Aftermarket Sales & Service Supervisor Harrop Engineering Australia Pty Ltd
96 Bell Street, Preston, Melbourne, Victoria, 3072, Australia
t: +61 3 9474 0900 | f: +61 3 9474 0999
e:julian@harrop.com.au | w: www.harrop.com.au
The Following 2 Users Say Thank You to Kiske For This Useful Post:
Calum (08-14-2020), Irace86.2.0 (08-14-2020)
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
