| Northern California NorCal |
#29 | |
Weight Weenie
Drives: 15 FR-S
It looks incredible. How many hours into it and what coating did you use? I didn't know you could use it on plastics or in a hot engine bay. |
| The Following User Says Thank You to new2subaru For This Useful Post: | MyRx (08-10-2020) |
#30 | |
ProCrastinationConsultant
if the clearcoat on the housings is yellowed/foggy only, the previous process i talked about should take care of it. if the clear coat on the housing looks like cracked glass, or is flaking off, or appears to be missing in places while also looking like a matte, yellowish finish, than replacement of the coating like you describe is the best option. but it's extremely labor intensive wet-sanding, and many of the better coating options are more closely related to very fumy 2-part epoxy systems. so unless the headlamps have a lot of personal meaning, it's much easier to replace consider replacing either just the lens from another good headlamp, or to consider replacing the entire assembly with a factory-fresh headlamp. it is typically better to go with replacing the entire assembly, as when most housing lenses reach this point of degradation, it is extremely common that the oem components within the assembly have degraded to some extent as well, and all that work into the outer lens still won't benefit the end result as outright housing replacement. i've done a little of all of it with my past retrofitting hobby
#31 | ||
Undisputed El Presidente
Drives: Zenki 37J ZN6
![]() Quote:
| The Following User Says Thank You to finch1750 For This Useful Post: | humfrz (08-02-2020) |
#32 |
Too many hours spent unfortunately but that is expected when trying to polish BMW paint.
| MTEC Shifter Spring Questions & Comments | JohnAyySays | Engine, Exhaust, Transmission | 19 | 06-11-2018 08:09 AM |
| My S2000 vs GT86 Steering feel comments/questions. Anybody else own both? | GreenLightGo | FR-S / BRZ vs.... | 57 | 01-27-2018 01:37 AM |
| I joined the club! A few questions & comments... | Protege13 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 03-27-2017 03:12 AM |
| Crickets be gone! lucas oil deep clean fuel system cleaner | SliverBrz | Issues | Warranty | Recalls / TSB | 15 | 09-23-2013 08:22 PM |
| Getting questions and good comments | sweetfrs | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 04-15-2013 07:03 PM |
