Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 01-01-2020, 08:37 PM   #43
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
I’ve done about 600 or so kms since the recall and no issues. Car runs really well, in fact it seems to rev freer. I just did the Black Spur this morning, red lined it several times. Have done so before that too. No regrets going in for the recall and can recommend Glen Waverley Subaru if you’re out that way.
Dirty Harry is offline   Reply With Quote
Old 02-28-2020, 02:53 AM   #44
RJ_
RJ_'s Avatar
Took my BRZ in for the recall yesterday. Fingers crossed.
RJ_ is offline   Reply With Quote
Old 03-01-2020, 09:59 PM   #45
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Been 600 kms since valve spring replacement, had it back in the shop for Toyota to look over after it sounds like my timing chain was a little lose on startup, and what seems to be a slight oil leak. Toyota couldn't find anything (they pulled the pan and said it was clean).
So just took her for a dyno - stock baseline. Pulled 6 times, 108, 110, 111, 112, 112, 111. Good enough numbers, trent at chequered identified no issues in the logs.
The 5th pull had a knock detection, which brought the mapping back a little to make the 111 on the last run, but that seems pretty normal as it was part of the ecu learning once the dyno runs started.
Runs amazing really (car also has no cabin noises, which I thought was odd for a 7 year old car). I will keep checking for oil leaks, but I have heard that there is a chance that leak is was just temporary.
I'll give it another month or two just to be sure about the recall, then the mods are going to start going in! Very exciting.
Blighty is offline   Reply With Quote
Old 03-04-2020, 01:12 AM   #46
RJ_
RJ_'s Avatar
Money light came on 200 km after the recall work. P0020. Back to the shop tomorrow.
Old 03-04-2020, 02:48 AM   #47
AlbertoSmith
Drives: Subaru BRZ Limited
Mine will be ready in two days. The current day is march 3rd of 2020. I dropped mine 2 weeks and a half ago and it will be ready at the of this one. They sent me to Enterprise and I got an SUV (Hyundai Tucson) is a comfy car and it wastes a little more gas than my BRZ. They will change the sparkplugs, the Flywheel, Clutch, Pressure Plate, and TOB. I asked them for that because I had issues with the transmission. The only thing I'm paying is for the parts. Labor is included. I hope they don't screw up the engine.
A did a little research about that and I found out mostly FR-S in small towns were affected because Toyota mechanics don't have experience with boxer engines. I hope Subaru dealer does a good job as is my only car. Good luck with yours!!
AlbertoSmith is offline   Reply With Quote
Old 07-24-2020, 06:15 AM   #48
alan.chalkley
Drives: 4wd zooks
What if a car was sold to a reputable car dealer and the reputable car dealer sold it to another person months ago , and the recall letters keep coming.
#6 arrived today.
I feel sorry for whoever sees the money light!
alan.chalkley is offline   Reply With Quote
Old 07-31-2020, 07:50 AM   #49
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
My car has had the recall done over 16 months now and NO issues. How’s everyone else’s recall been since the had it done?
If you have had issues have they been sorted to your satisfaction?
Bodalenko is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
