Old 07-29-2020, 12:25 AM   #1
GCFSA
Drives: Toyota 86
Question about installing sandwich plate
Hey guys, probably a bit of a stupid question but I've just done an oil change and will be installing a sandwich plate soon for oil temp/pressure gauges. (I know, should've done that first before the oil change)
Just wondering if it's ok to remove the oil filter, install the plate then reinstall the same filter?
Thanks!
GCFSA is offline   Reply With Quote
Old 07-30-2020, 03:57 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Thanks!
Will be fine.
But you don't need a sandwich plate for that. There is a bolt I removed on the top of the engine for my oil temp and you can T off or replace the stock oil pressure switch since it's just a dumb light.
Clueless
YamahaR86 is offline   Reply With Quote
The Following 2 Users Say Thank You to YamahaR86 For This Useful Post:
Grady (07-30-2020), soundman98 (07-30-2020)
Old 08-06-2020, 10:07 PM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Originally Posted by YamahaR86 View Post
Will be fine.
So, what runs the gauge on the dash? Just curious as I am new to the platform.
JohnH is offline   Reply With Quote
Old 08-07-2020, 07:32 AM   #4
7 skulls
Drives: 2014 scion frs
Go with the sandwich plate for a simpler, more easily returned to stock, set-up. No problem on removing and reinstalling the filter, just lube some oil on the O-rings of the sandwich plate.
However, my own set-up is a Pivot dual gauge (plugs into the OBD port under the dash) for oil/water temp.
https://www.ebay.com/itm/Pivot-Dual-...W/263955166799
For oil pressure (not available through the OBD), I have a Cusco oil pressure gauge mounted in a vent pod right above the vent-mounted Pivot. The Cusco sender is remote-mounted from the oil gallery port at the engine top with a length of braided line. The sandwich plate would be a simpler approach for oil pressure.
7 skulls is offline   Reply With Quote
Old 08-07-2020, 02:07 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
There is a built in pressure gauge but it's just a dummy switch. The light comes on when the oil pressure is low but by then, it's already too late. So you'd be plugging in an aftermarket one that you can monitor the pressure with in it's place.
You can T into it so keep the light off.
Clueless
Old 08-07-2020, 04:17 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine is disconnected, no light
I am running aftermarket pressure sensor in that location, left the stock oil temp sensor so I could log it on my OFT.
Old 10-05-2020, 10:46 AM   #7
chipmunk
Drives: _
I'm in the same boat as well - looking for a sandwich plate to install a pressure sensor. However, I don't even know where to get these parts. I saw a TRD adapter, but it's well over $150.
For those who have installed the sandwich style adapter and sensor, what did you buy? Is your gauge connected to the battery, or mechanical? If battery, how did you tap into the fuse box? Are there any holes in the firewall, or did you drill one to run the cables?
chipmunk is offline   Reply With Quote
Help with oil sandwich plate BIRDMAN408 Engine, Exhaust, Transmission 3 03-15-2018 01:00 AM
Oil Sandwich Plate Strife26 Want-To-Buy Requests 0 12-19-2017 09:28 PM
Sandwich plate Strife26 Engine, Exhaust, Transmission 3 12-10-2017 05:37 PM
Squirelly sandwich plate Grozniy Engine, Exhaust, Transmission 3 10-07-2017 02:31 PM
OFT + Oil cooler sandwich plate Sterling Doc Engine, Exhaust, Bolt-Ons 5 07-12-2015 12:45 AM
