Southern California SoCal
Old 07-29-2020, 06:19 PM   #1
jflogerzi
jflogerzi's Avatar
Shop to install Trac Spec Hood vents
Anyone know of a place to do this install properly... in the SoCal area. I don't trust myself cutting the OEM hood
2013 Series 10 FRS #553
Old 07-29-2020, 07:48 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
Any body shop, but you do have slight room for error. Lots of painters tape and measurements. Go slow it’s more scary than hard. Can make “practice” cuts in the center part you are cutting out. Worst case it’ll give you an excuse for a carbon fiber hood lol.
Old 09-01-2020, 10:44 PM   #3
jflogerzi
jflogerzi's Avatar
Tried 2 local shops. 1 would not try and other told me 500$. At that price might as well just buy a carbon fiber hood but I like the look oem hood + vents more
Old 09-03-2020, 02:12 AM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
It just takes time. I cut mine just fine, just measure measure measure and drill holes & cut. I added 3mm rivnuts to mine versus using the supplied rivets so i can add rain guards. Harbor freight sells a cheap cutoff tool that works really well.
Decimus is offline   Reply With Quote
Old 09-03-2020, 02:20 AM   #5
ellaavery
Drives: old models
nice
ellaavery is offline   Reply With Quote
Old 09-03-2020, 10:22 AM   #6
jflogerzi
jflogerzi's Avatar
Link to tool. Everyone keeps saying the same thing
Old 09-04-2020, 09:55 PM   #7
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Here you go!
https://www.harborfreight.com/3-in-h...ool-63023.html
The Following User Says Thank You to Decimus For This Useful Post:
jflogerzi (09-04-2020)
Old 10-21-2020, 10:08 PM   #8
jflogerzi
jflogerzi's Avatar
Well I am finally attempting this install over the weekend
Old 11-18-2020, 06:10 PM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
So how did it go?
The Following User Says Thank You to Lonewolf For This Useful Post:
DarkPira7e (11-18-2020)
Old 11-18-2020, 06:19 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
So how did it go?
He's still taping
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Code Monkey (11-24-2020), jflogerzi (11-24-2020), soundman98 (11-19-2020)
Old 11-24-2020, 01:26 PM   #11
jflogerzi
jflogerzi's Avatar
So how did it go?
got lazy... Will be trying over the holiday break in December. I have 2 weeks off due to budget issue for my institution
Old 11-24-2020, 03:53 PM   #12
BROSEIDON3
Drives: 18 brz
With the help of a friend I was able to cut mine. Measuring took ALL DAY to make sure it was lined up correctly. We tried using the linked tool but it wouldnt cut deep enough and once we switched to a jigsaw it was very easy
BROSEIDON3 is offline   Reply With Quote
The Following User Says Thank You to BROSEIDON3 For This Useful Post:
jflogerzi (11-25-2020)
Hood Vents djezlee Engine, Exhaust, Transmission 28 05-25-2020 08:18 PM
Wtb: hood vents or carbon fiber vented hood Pooponwindows Want-To-Buy Requests 0 05-25-2018 01:24 PM
WTB. Trac Spec hood xxGiXxeRxx Want-To-Buy Requests 0 04-16-2017 08:47 PM
Shop recommendation for hood pin install? Colin86 Great Lakes 0 09-02-2016 10:48 AM
Best way to seal off vents in cf hood so they are for looks? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 04-01-2014 01:25 AM
