Old 07-20-2020, 11:55 AM   #1
dei.rz
Tofu Runner
dei.rz's Avatar
Drives: 2015 Dark Metallic Gray BRZ Limited
Keyless Lock Chirping Device
[SOLVED] by pope (1 post below)
Does anyone know the part number or name of the chirping device that goes off when you lock your car? I'm looking to hook an Arduino up to it to control headlight/drl/underglow lighting profiles when I use the oem key to lock my car.
dei.rz is offline   Reply With Quote
Old 07-20-2020, 03:42 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
Buzzer
Part Number: 88021FG011
https://parts.subaru.com/p/Subaru_20...8021FG011.html
pope is offline   Reply With Quote
Old 07-20-2020, 04:13 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I did other way. Installed mirror auto-fold module, to provide visual cue that is easier to notice then turn signal single flash.
Old 07-20-2020, 04:57 PM   #4
dei.rz
Tofu Runner
dei.rz's Avatar
Thanks pope, also the autofold module unfortunately isn't available in the US market. I'm just going to tap into the lock chime circuit to trigger the microcontroller.
Old 07-29-2020, 08:03 AM   #5
Circa85
Drives: 2017 Toyota 86
I installed the Diode Dynamics Smarttap CF18 module for the lane change function, but also use it to leave the turn signals on for a minute after locking which gives me ample time to check that the lights are illuminated as I walk away.
Circa85 is offline   Reply With Quote
Old 08-05-2020, 11:22 PM   #6
caffeinejunky
hella stock
caffeinejunky's Avatar
Drives: BRZ Limited
Where would the buzzer be located?
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR
caffeinejunky is offline   Reply With Quote
Old 08-06-2020, 07:29 AM   #7
pope
has a funny hat
above/next to the washer bottle, behind the front bumper, on the left side of the car.
The Following User Says Thank You to pope For This Useful Post:
caffeinejunky (08-07-2020)
adruino, beep, chirp, key fob, lock
lock to lock in relation to steering rennlistuser3 BRZ First-Gen (2012+) — General Topics 8 07-10-2019 09:48 PM
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 08:41 AM
Keyless lock not turn off headlights bleakhand Issues | Warranty | Recalls / TSB 4 12-18-2013 05:04 AM
HKS Flash Device xwd Software Tuning 1 11-23-2013 09:29 PM
Keyless Lock Problem bdbx18 Electronics | Audio | NAV | Infotainment 5 01-18-2013 12:29 AM
