Old 07-24-2012, 12:55 PM   #113
Erroneous
Drives: Mitsubishi Eclipse
I thought the front badge had clips on it. Is that not the case?
Yep, it does. That's what makes it so tough. I just can't get up the gumption to jerk it out because I don't want to risk damage. There has to be a better way...
Erroneous is offline   Reply With Quote
Old 07-24-2012, 02:19 PM   #114
You mean short of taking the front bumper cover off, right?
That's one of the reasons I haven't pulled mine off to paint them. I'm not only concerned about damage coming off, but figure there must be a reason they used clips there (probably flex). Waiting to see if folks that have done it have any issues.
Old 07-27-2012, 01:14 AM   #115
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
maybe im a little OCD, but if you swap out the Scion logos for Toyota ones on the outside doesnt it look really retarded with the scion steering wheel still?
lbroskee is offline   Reply With Quote
Old 07-27-2012, 05:30 AM   #116
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
As much as I wish the steering wheel was mod-able (at least the logo portion), and it will bother me being the last Scion piece, I am still rebadging it Toyota on the front/rear and wheel caps.
Maybe eventually I'll give in and get the JDM steering wheel in red trim but not likely.
eriktherod is offline   Reply With Quote
Old 07-28-2012, 01:07 PM   #117
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by ahausheer View Post
I wonder if the lacquer thinner is too harsh for the paint. Ive used a product called goo gone (which may have lacquer thinner in it?) and had no problem with my paint for two plus years in S. CA sun. Use that heat gun carefully some heat guns will easily melt the paint completely off. Also I have used fishing wire and worked it back and forth under the emblem with good results. You can also paint the emblem with spray paint and put it back on if you want to mod your car and are annoyed with the holes.
I used nothing but a string and Goo Gone to remove the badges :happy0180:
Just poured Goo Gone over the top area and kept sawing back and forth with the string until I hit one of the pins. Did the same for the bottom. Then I started to pull the badge off with my fingers and poured Goo Gone while pulling and it just comes right off super easy.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-28-2012, 01:25 PM   #118
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Originally Posted by DarrenDriven View Post
any advice how to take the front emblems off? seems like everybody is having trouble..
imravenit is offline   Reply With Quote
Old 07-28-2012, 04:59 PM   #119
Look great!
As far as taking the front one off, sounds like everyone is doing it through brute force. You have to break the pins on the back, which concerns me although no one seems to be having issues once its done.
Old 07-28-2012, 05:13 PM   #120
JohnATL
JohnATL's Avatar
Drives: 2013 Scion FR-S MT Raven
If you break off the pins from the front badge, where do they end up? On the ground or stuck somewhere in the nose rattling around forever?
JohnATL is offline   Reply With Quote
Old 07-28-2012, 05:24 PM   #121
Synack
Boosted
Synack's Avatar
Drives: Sideways
They fall back into something. Eventually will fall out, hopefully lol.
Old 07-30-2012, 11:35 PM   #122
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
How is everybody taking the scion sticker on top of rear bumper?
Old 07-30-2012, 11:36 PM   #123
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
Just peel it off. It's just clear bra.
Trojan_SC is offline   Reply With Quote
The Following User Says Thank You to Trojan_SC For This Useful Post:
imravenit (07-30-2012)
Old 07-30-2012, 11:38 PM   #124
Trojan_SC
Trojan_SC's Avatar
Problem solved...
Old 07-30-2012, 11:39 PM   #125
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
huh? I already put goo gone and im having a hard time taking it off
Old 07-30-2012, 11:41 PM   #126
lbroskee
lbroskee's Avatar
For 750+ that is def not a airbag solution in my book lol
The Following User Says Thank You to lbroskee For This Useful Post:
Synack (07-31-2012)
teq emblem
Debadging - How difficult will it be? Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 86 06-24-2014 10:49 PM
