Drives: 2015 Subaru BRZ
BC Racing Coils BR Series (need Help Please)
Alright so i don't know if this is just me or if i need to get this fixed, but ever since i installed coilovers and the adjustible front end links, i cant take tight corners with traction control on around 45 mph with out my traction kicking on and almost killing me, when i was on stock suspension i was taking corners alot faster with no problem just hugging the road. Im on bc racing coils and im running a 18x9.5 +35 offset with a 265/35/18 square tire setup. If anyone can tell me if this is normal and i just need to drive with traction controll off or do i need to invest in lca and it will go away. or do i have something installed wrong. any tips would help. im just tired of take slight rights or lefts at or around 45 + and my car wants to slide out and act like its spinning out.
#2 |
Drives: Crapcan
What are your alignment specs? Ride height? What tire?
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | strat61caster (07-28-2020) |
#3 |
i just got a alignment a couple days ago, and i know im off by like 0.2 of a degree, they said they got it to square as they could with my suspension
i could get you the actual specs tomorrow i have the sheet in my car |
#4 |
Drives: 2014 GT86
0.2 degree for something like toe unevenness might be a lot. For camber, not so much. Though never hurts to post alignment printout to spot possible abnormalities. Ride height & tire questions still stay though, as unrelated to alignment.
#5 |
here the sheet i got from them, let me know if it helps at all?
#6 |
this is my ride height and im running a 265 35/18 tire
#7 |
Rust bucket enthusiast
Looks like you could benefit from more camber up front. Regardless, it sounds like they got toe all set.
Your principal issue may be ride compliance. If these allow you to choose damping, set it to full soft and see if it's any better. |
#8 |
alright so just to make sure im on the same page as you, maybe add some camber in the front, would you have a reccomendation, right now its just evenly in the middle on all four corners. i do have dampening setting on all 4 should i stiffen up the back make the front harder. when im taking these turns around 45 50 it feels like the front is what wants to spin out on me.
#9 | |
#10 | |
Now with the bc coils and bigger wheel and tire, i feel like taking those same turns around 45 50 and my traction control kicks on and makes my car wants to turn into the corner more, almost as if the front is starting to slide out from me when taking the corner. |
#11 | |
#12 |
Drives: Crapcan
That is quite a bit of rear toe.
#13 |
#14 | |
Drives: Crapcan
Could be your tire, I can't tell what those are but I would take compound over size. And then combine that with an overly stiff suspension setup. BR's look like they have 8k springs.
| FS: BC Racing BR Coils 8k F/R (SoCal) | kloy | Brakes, Suspension, Chassis | 0 | 12-31-2019 12:40 PM |
| FS: D2 Racing Circuit Coils SOLD!! | Simply_the_best | Brakes, Suspension, Chassis | 28 | 03-16-2016 02:28 PM |
| FS: BC Racing coils (FL) | Ric0 | Brakes, Suspension, Chassis | 5 | 08-05-2015 09:59 PM |
| Selling Fortune Auto Coils v500 series | piaoyi | Canada Classifieds | 0 | 06-26-2015 03:57 PM |
| BC Racing Coils Group Buy | MrTranxD | Brakes, Suspension, Chassis | 2 | 12-13-2012 12:29 PM |
