Drives: 2014 Subaru BRZ
Throwout Bearing Clearance question?
Apologies if this question has been answered or discussed in another thread. If so just direct me there.
I recently replaced my TOB, Clutch fork, Pressure Plate, etc.., and now I am wanting to ensure that my throwout bearing does not wear prematurely by contacting the pressure plate when it's not in use. I understand that on other manual transmission vehicles with cable operated clutch systems it is very important to adjust the cable to make sure there is a small clearance/gap between the throwout bearing and the pressure plate. That way the bearing isn't spinning when it is not in use. I tried wiggling the end of the clutch fork with the car put back together and it feels like the clutch slave cylinder is applying a constant pressure onto the fork which is pushing the TOB into the pressure plate fingers.... Is this by design? Is this okay? I guess I could go to a dealership and pop the hood on a new car and see if that slave cylinder / clutch fork feels the same. Let me know your thoughts, any feedback is appreciated! Thanks |
#2 |
Drives: 2016 Scion FRS Halo
There's definitely some pre load on the clutch fork from the slave cylinder.
This is not a cable driven system or manual linkage. I don't think there is a spec to set a gap between tob and pressure plate. I have not read or seen anything for this in changing clutch. |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
If you go by the repair manual, I can't recall any specific call out for the TOB.
When I did my clutch job, I didn't think twice about it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Hi ya, Kyle2 and welcome to the tribe -
![]() The TOB on these cars is "active", in other words it is in contact with the pressure plate all the time and spins whenever the engine is running. It's just "working" (under load) when the clutch is pushed in. |
#5 | |
Drives: _
Sent from a potato |
#6 | |
As long as the engine is running the TOB is spinning, however, it's not under load till you push in on the clutch. Actually, that makes more sense than the way they used to be, where the TOB was slammed up against the spinning fingers of the pressure plate every time the clutch was pushed in. Where you been, chipmunk, I haven't seen much of you lately -
#7 | |
Drives: _
Have an usual noise around 5-6k rpm,but goes away as soon as I press the clutch in even a little bit. I don't wanna hijack this thread. I detailed it more in another thread. Dealer says it TOB, but it doesn't make any intuitive sense to me. Sent from a potato |
#8 | |
New daughter - even gooder - ![]() Even though the TOB is active, when pressure is applied it becomes under a load. It's my understanding that a bad TOB can make one noise not under load then a different noise when loaded. |
#9 |
OP, your observation is correct. The self-adjusting, hydraulic clutch operating system is puzzling to a lot of people who are used to a cable.
There's a thin spring inside the slave cylinder that takes up the slack in everything between the piston down to the pressure plate fingers. But we know that, as the clutch wears, the fingers lift away from the flywheel. This pushes the piston further into the slave cylinder. Where does that hydraulic fluid go? When everything is at rest, with the piston in the master cylinder fully extended, a port opens to the reservoir the same way it does in a brake master cylinder. The excess fluid escapes to the reservoir and everything comes to a gentle equilibrium. That's why, with all the pedal adjusting going on in this forum, I occasionally pop in to mention the importance of proper master cylinder adjustment. The piston must be allowed to fully extend when the pedal is released. Otherwise, the system "pumps up," leading to clutch slippage and premature TOB failure.
#10 | ||
#11 | |
I'll defer to ol @Ultramaroon to address your further question.
#12 | |
Anyhow, I digress. The whole self adjusting thing isn't new. Someone figured out that a free-wheeling TOB was no big deal and little spring inside the slave cylinder makes life a whole lot easier. Nissan started doing it around 75. A bit of play at the top of pedal travel is expected but a functional test is educational. Grab the top of the fork and pull it forward. the pin should sink into the slave. It takes a while for it to slip back out on its own. Don't freak out.
| Tags |
| bearing clearance, throwout bearing, throwout clearance, tob, tob clearance |
| Throwout bearing going bad | B-R-Z | Engine, Exhaust, Transmission | 40 | 09-08-2017 09:23 AM |
| Throwout bearing. | bdanisi | Issues | Warranty | Recalls / TSB | 54 | 07-17-2016 06:13 AM |
| 63,000 and throwout bearing ruined everything | riironman | Issues | Warranty | Recalls / TSB | 188 | 05-14-2016 11:02 AM |
| Throwout bearing? | RavioliG | Issues | Warranty | Recalls / TSB | 3 | 10-31-2015 01:17 PM |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
