Old 07-07-2020, 07:47 AM   #1
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
Eibach Pro-Kit lowering springs
Going to install Eibach Pro-Kit soon. Just checking the orientation. Instructions say the Eibach name printed on the springs should be right side up like in the picture. Is this correct?
Daily86 is offline   Reply With Quote
The Following User Says Thank You to Daily86 For This Useful Post:
alphasaur (07-07-2020)
Old 07-07-2020, 10:27 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You have the front/rear springs mixed up.
The spring you have listed as "front" goes in the rear.
http://www.billswebspace.com/PTR07-18130inst.pdf
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 07-07-2020, 10:33 AM   #3
alphasaur
friendly
Drives: 17' 86
Rtoyo is correct
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 07-07-2020, 10:48 AM   #4
Daily86
Daily86's Avatar
Okay. Thanks. The top bottom is correct though?
Sent from my SM-G930V using Tapatalk
Old 07-07-2020, 04:28 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes, the lower spring perch has a notch for the last coil to sit in nicely, the upper spring perch is flatter so you got it correct.
ineedyourdiddly
Old 07-07-2020, 04:34 PM   #6
Daily86
Daily86's Avatar
Thanks
Old 07-23-2020, 01:37 PM   #7
Daily86
Daily86's Avatar
Got the springs installed finally. I followed the easy coil install method http://www.ft86club.com/forums/showthread.php?t=32414. The front was an easier install than the rear. Happy with the results. Some forum members say the ride is to harsh, others can't tell much difference. I'm with the latter. Might depend on the road though. I drove for about two weeks before getting an alingment. How do my alignment numbers look? Daily driven street car.
Vital (07-23-2020)
Old 07-23-2020, 01:58 PM   #8
Vital
Drives: 2015 BRZ
Looks good get some camber bolts for the front and max out the camber it feel even better after that
The Following User Says Thank You to Vital For This Useful Post:
Daily86 (07-25-2020)
Old 07-24-2020, 06:15 PM   #9
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I would not add more camber unless he's tracking or autocrossing. It's just going to wear out the tires quicker on a DD car that drives straight most of the time.
Otherwise those numbers look good. Though I would have preferred zero front toe or a tiny bit of toe out for quicker turn-in.
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
Old 07-27-2020, 09:33 AM   #10
Vital
Drives: 2015 BRZ
Thats a common misconception, excessive toe is what kills tires. Having some front camber helps this car get some grip in the front end and helps with over steering. My car is DD and i run -1.6 up front and been like that for like 3 years and theres no signs of excessive tire wear.
Agree with the toe settings. Also just FYI- https://www.ft86club.com/forums/show....php?p=2948387
Old 07-27-2020, 10:25 AM   #11
N_Raged
That's actually not a whole lot. The rears are around that much from the factory. I forgot how little just one pair of camber bolts will give you
Vital (07-27-2020)
Old 07-27-2020, 11:50 AM   #12
Vital
Drives: 2015 BRZ
Yep, the camber bolts max out at like -1.75 something like that. Its not enough to cause significant wear. I see people here running like -2 and -2.5 for street without any issue as long your toe settings are in check.
FS: Eibach Pro Kit lowering springs Speck Brakes, Suspension, Chassis 17 07-30-2018 02:23 PM
FS: Eibach Pro-Kit Lowering Springs Jolaessss Northern California 2 09-24-2014 12:27 AM
FS: Eibach Pro-Kit lowering springs Spicer66 Brakes, Suspension, Chassis 2 09-18-2013 12:04 PM
FS: Eibach Pro-Kit Lowering Springs Dispect Brakes, Suspension, Chassis 1 07-15-2013 05:17 PM
