Old 12-03-2019, 12:49 PM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
HOLD UP!
Kronenbourg isn't that bad.
- Andrew
Not sure any future builds can have RCE products now.. good job Andrew.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-03-2019, 01:28 PM   #30
Haha, I should have seen that coming.
There's much better beer to be had...maybe your next order will be packed with something tasty.
- Andrew
Dave-ROR (12-03-2019), Opie (12-04-2019)
Old 12-04-2019, 12:13 PM   #31
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 07-23-2020, 11:48 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
ok so I just realized it's been a long time since I updated this thread... mostly because I'm lazy and with COVID I have been really lazy about working on the car.
Since the last update I think the following have been installed...
ACE 350 header/overpipe
ACE front pipe
Swapped to the MXP CompRS dented up exhaust from the flood FRS @Opie and I bought
SPC rear toe arms
SPC rear LCAs
Eibach R2 coilovers
Cusco engine mounts
Cusco trans mount insert
Essex Comp sprint BBK
I still have rear subframe mounts to install.. and a cage that needs to be built.. and a tune that needs to be done.. and seats.. and harnesses... and fire suppression... and a coolsuit system... and a tracbox.. and a switchpanel.....and jdm underpanels and a trans underpanel.. and I'm sure a bunch of other stuff like brake fluid since the pedal goes to the floor right now.
Hopefully taking the car to Watkins Glen in early september.
Anyways here's some updated pics of cage prep and misc crap.
So first, using that little cap on the intake manifold to cap off a coolant line doesn't work really..
Replaced it with this which is sure to leak also
Cusco trans insert
ACE header/OP
Some pics before I removed it and the graffiti Integra Type-R from my garage and moved them to storage
Arrived at the storage place..
Cage prep starting. Dash/etc removed. Removing the blower motor and all the other HVAC crap. This job is absolutely fucking terrible. Beyond the dash you also have to remove the dash bar which is 8 main bolts plus the steering column (2 bolts to the bar, one mounting it to a bracket and then 1 for the bracket to the firewall) plus some pedal assembly bracket.. and then some twisting and pulling.
Fuck this thing.
Then started removing the rest of the interior.. also a pic of the brakes just because.
I'll start working on it again tomorrow to gut the rest then need to figure out scheduling for alignment, tuning/dyno (since it's far from street legal) and the cage builder.. assuming the seat bases and other crap will arrive soon.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
Dzmitry (07-24-2020), JesseG (09-15-2020), Opie (07-24-2020)
Old 07-24-2020, 11:00 AM   #33
Opie
Opie's Avatar
What's T-Tapped into the BIU?
Old 07-24-2020, 11:24 AM   #34
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah I noticed those.. nothing was there and I didn't try to figure out what those wires were for so no clue what would have been tapped in.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-24-2020, 08:15 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Went back to finish ripping the last few things out of the car today and to check a few other things...
Shockingly, the EPS coupler on this 2013 is actually in good condition:
And eliminated the door panels:
Now it's really ready for the cage builder:
And I have a lot of random FRS parts making a huge mess in the storage unit......... anyone need some stuff?
Next.. dyno/cage/corner weighting/alignment/brake bleeding/seat mounting/harness mounting/fire suppression install/some minor aero/who the hell knows what else...
I have a month.. no problem lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
JesseG (09-15-2020)
Old 07-27-2020, 02:51 PM   #36
Opie
Opie's Avatar
Geezus that Type R is not a shelf
The Following 3 Users Say Thank You to Opie For This Useful Post:
Clipdat (08-01-2020), JesseG (09-15-2020), soundman98 (08-03-2020)
Old 07-27-2020, 04:06 PM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Looks like a shelf to me
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2020, 10:12 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Did some more work on the car this weekend. Added metal to the firewall to block off the holes from the HVAC junk, installed the coolsuit mounting bracket, installed the fire suppression system bulkhead connector/passthru, installed a switch panel (to be used for the coolsuit and tracbox) with custom brackets, got the GY SuperCar 3R tires mounted and balanced and then put them on the car. Found that the belt was rubbing my Perrin intake too. At first though maybe the Perrin was the wrong one (17+ or something) but compared it to Will's and it matches exactly. My car does have Cusco mounts so maybe the engine is a little higher but seems weird still. Ended up trimming the tube on the airbox side to make it clear.
Didn't take too many pics - mostly of the switch panel work which is sheet metal bent with a 90 degree bend, some trimming to make it less likely to cut wires, riveted to the OEM stereo brackets and then rivnuts installed to attach the plastic panel. Eventually the fire system pull handle will go in the panel as well.
Brackets:
Close up of one:
Switch panel installed:
Red RPFs1 that I bought from @peaches mounted up:
And of course, the most important track mod ever developed....
Progress for this coming week should be: alignment, tune, seat base delivery so initial bucket seat install, trans/diff fluid changes.. maybe some other misc stuff. Need to get the car to the cage building soon.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 6 Users Say Thank You to Dave-ROR For This Useful Post:
bcj (12-12-2020), JesseG (09-15-2020), Racecomp Engineering (08-03-2020), soundman98 (08-03-2020), Thefalls (08-03-2020), Ultramaroon (12-12-2020)
Old 08-03-2020, 08:58 AM   #39
peaches
Drives: '14 BRZ Limited
Looking good, it was too hot yesterday to be working on cars though
peaches is offline   Reply With Quote
Old 08-03-2020, 11:22 AM   #40
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
True. Unfortunately I need to have this car done in less than 30 days including the cage.. ugh
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-03-2020, 01:40 PM   #41
Opie
Opie's Avatar
Here are some more pics...don't forget all the excess wiring that was removed
The Following 2 Users Say Thank You to Opie For This Useful Post:
JesseG (09-15-2020), new2subaru (08-03-2020)
Old 09-01-2020, 10:11 AM   #42
Opie
Opie's Avatar
Some pics from last nights progress on Dave-ROR's build...supposed to be loaded on the trailer by Thursday night for its first event...the push is on!
Dave-ROR (09-01-2020), JesseG (09-15-2020)
FS: 2013 FRS Track build - FL philooo Tracking / Autocross / HPDE / Drifting 3 02-08-2016 05:19 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Track Schedule and Invitation Feffman Tracking / Autocross / HPDE / Drifting 13 10-16-2013 08:28 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
GPS Track Time- 2013 Autobahn and Blackhawk Farms Dates Here! Chicago Tracking / Autocross / HPDE / Drifting 0 03-09-2013 10:38 AM
