Old 05-22-2018, 03:31 AM   #43
carlovestela
Drives: 2015 Firestorm FRS
My front has -0.4 camber
-2.2 rear.
Trd lowering springs
Do i need camber bolts and lca?
carlovestela is offline   Reply With Quote
Old 05-22-2018, 04:51 AM   #44
churchx
churchx's Avatar
Drives: 2014 GT86
If you are happy with how your car handles with this alignment, why would you need it.
If you want to change it, you need adjustability. Camberbolts & lca is most common way to get it.
Your own choice/preference, what you want.
Old 05-22-2018, 08:05 AM   #45
ZDan
ZDan's Avatar
Drives: '23 BRZ
-2.2 rear.
LCA's are overprescribed. You don't need them, -2.2° is totally streetable, particularly if you run zero or near-zero toe and rotate tires. IMO -0.4° camber up front is still woefully low, you might get camber bolts to bump that up to -1° (and you'd want a lot more than that for track/autox) but not necessary.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
GoZ21 (05-22-2018), strat61caster (05-22-2018)
Old 05-22-2018, 08:42 AM   #46
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
Yes - What ZDan said. I'd get the SPC camber bolts for the front and aim for -1.5* and keep the rears as is.
2013 FR-S Asphalt Grey
HKS Hipermax IV GT
Sparco Assetto Gara MGC 17x7.5
Invidia N1 exhaust
Scoob is offline   Reply With Quote
Old 05-22-2018, 02:40 PM   #47
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by churchx View Post
Hmm. Somehow missed that thread and was under impression that LCAs/UCAs/bushings are only options for rear. But from it it seems that there are no listed from manufacturer as "native" rear camber bolts somewhat fitting by size, only modified/reused front ones or from other cars?
I dont think anybody has them listed for use on the rear control arms. I didn't need to modify the bolts either.
I have the bolts adjusted to max positive on driver side and max negative on passenger side to even out the camber. In terms of total negative camber gained (left + right side), its none. not much adjustment in them.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
GoZ21 (05-22-2018)
Old 05-22-2018, 08:35 PM   #48
carlovestela
Yes. I dont do track or autox. Only for daily.
I just want like the factory set up. For equal threading of tires.
So -2.2 at rear is set. Then -1.5 in front using camber bolts.
Btw
Trd lowering spring
Stock struts
17x9+38 w 245/40/17 is my setup
Old 07-19-2020, 02:39 AM   #49
tonyprabhat
Drives: FRS
After reading this review, I am going to buy Godspeed coilover. How it is?
tonyprabhat is offline   Reply With Quote
Old 07-19-2020, 02:51 AM   #50
86TOYO2k17
Drives: 2017 toyota 86
Tein Flex A seems to be the only coilover worth getting for under 1k. Other wise just get RCE yellow or TRD lowering springs will be as good or better performance/ride quality as any other coilover under 1k.
Old 07-19-2020, 10:39 AM   #51
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Lol half of the products on that list are trash.
Save your money. Be patient. Buy something that’s actually worth buying.
The KWs are probably the only ones on that link that I’d spend my own money on.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
DarkPira7e (07-19-2020), Tokay444 (07-19-2020)
Old 07-19-2020, 11:41 AM   #52
ZDan
ZDan's Avatar
Drives: '23 BRZ
Bilstein B6/B8 with springs (RCE yellows or tarmac, Swift sport or Spec R) is a great option IMO. I'm really impressed with the Bilsteins/Spec R setup I just put on my car a few months back.
Old 07-19-2020, 11:54 AM   #53
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
How is the high speed damping on the B6/RCE yellow combo? I’m trying to find a more comfortable damper setup than the PP Sachs.
Old 07-19-2020, 12:00 PM   #54
ZDan
ZDan's Avatar
Drives: '23 BRZ
WAY smooover high-speed damping. The ride is much less crashy over bumps, and also there's a lot more bump travel so running 1.25" lower springs is no longer the problem it was for me with PP/Sachs and bump-travel-robbing Raceseng camber plates. The ride is transformed
Also theres more low-speed damping so better compatibility with the stiffer lowering springs like RCE Tarmac and Swift Spec R
Racecomp Engineering (07-19-2020), Yoshoobaroo (07-19-2020)
Old 07-19-2020, 01:04 PM   #55
Yoshoobaroo
TRACKBREAD
Excellent to hear! Looks like B6s are in my future.
Old 07-19-2020, 02:25 PM   #56
TylerLieberman
Drives: '24 GR86
The bilsteins are great. ONLY reason I wouldn’t consider them for myself is because of the larger OD on the springs used. My wheels wouldn’t fit; they’d hit the springs.
I got KW/GReddy. I feel like for the money, they’re hard to beat, along with the RCE SS1, CSG FLAs, and ST XTAs.
coilovers
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 11:34 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
