Drives: 06 Ford Mustang
2013 Scion FRS Modded Pittsburgh PA 3500 obo
CASH ONLY
Modded 2013 Scion FRS 134k Miles Automatic clean title in hand- Car has body damage, would be a good project or possible drift car. Lots of mods. Runs/drives great, passes inspection fine. No check engine lights on. Needs some serious TLC and a damn good detail job. Prob spark plugs sooner than later. Engine has a tune on it, including tuner. Body Damage is all dents (was quoted 3k for bodyshop repair) (refer to photos) - damage to: Drivers Side Door Drivers Side Rear Quarter Front bumper/passenger front fender has been replaced, paint is not an exact match color wise to hood (close but not perfect). Hood has quite a bit of rock chips from 134k miles. Rear of car in better shape paint wise. Interior is still mostly stock. Has oil temp gauge in vent. Rear interior panels have some small holes drilled in from aftermarket speaker brackets. Timing Cover has very slight oil leak, you can smell some oil occasionally. Minor enough that does not require topping up oil. Car has maintenance records for oil changes every 3-6,000 miles since bought. I am the second owner. Includes second set of wheels/tires with winter tires. MODS LIST, OEM PARTS NOT AVAILABLE Drivetrain: Grimmspeed Intake Racer X Oil Cooler Stark Performance Transmission Cooler and front end vent Radium Engineering Catch Can Weir 4.56 Final Gear kit Motul 8100 0W-20 FT86 Speedfactroy UEL catted header JDL Ultra Quiet Front Pipe ARK DTS Catback Openflash tablet, offshelf UEL tune Brakes/Suspension: Centric Posi-Quiet street pads Stainless steel brake lines Grimspeed Master Cylinder Brace Torque brake fluid Bilstein B8 struts/shocks Swift Spec R springs (F: 4.4 R: 5.6 Kg/mm) Racer X Rear Lowe Control Arms Whiteline Front Camber bolts Exterior/Interior: Black headlight housing (High/lowbeams unaffected) 3rd brake light relocation- carbon fiber LED lights- trunk, license plate, dome light P3 Vent Gauge Wheels: Speedline Corse Type 2120 Turini |
| The Following 2 Users Say Thank You to palanza87 For This Useful Post: | Takumi788 (11-07-2019), ZionsWrath (11-07-2019) |
#2 |
JHerbert Racing
Drives: 2013 Scion FRS
3500? Sub'd. I'll PM you.
#3 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
pm'd
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#4 |
Got Rice?
Drives: 37J BRZ-L
Check pm.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
#5 |
Drives: 2016 61K FR-S
PM sent
#6 |
pending sale, will keep thread updated if deal falls through
#7 |
Drives: varies
#8 |
Drives: None... yet!
#9 |
| The Following User Says Thank You to FRS_2016 For This Useful Post: | alphasaur (08-26-2020) |
#10 |
Drives: 2015 Subaru BRZ Limited DGM
still available?
| SBD500X TURBO KIT FOR THE 2013+ SUBARU BRZ/SCION FRS 3500 Shipped | TruRace | Engine, Exhaust, Bolt-Ons | 1 | 06-14-2019 06:45 PM |
| [FS]2013 A/T Ultramarine Scion FRS Modded / Boosted | azynneo | Cars for Sale/Trade | 7 | 08-05-2015 02:25 PM |
| 2013 Scion FR-S Asphalt!! Modded | AZ_Racer_1 | Cars for Sale/Trade | 2 | 08-03-2015 11:36 PM |
| TX: 2013 Scion FRS Slightly Modded | Krimlin | Cars for Sale/Trade | 9 | 01-12-2014 05:53 PM |
